13th March 2009, 23:52 | #1502 | Link | |
For my tests with multiavchd, I've convert mov audio aac with ripbot (launch a convert job and catch the audio ac3 created on the temp folder). Select Bluray output. |
14th March 2009, 02:18 | #1503 | Link | |
14th March 2009, 05:57 | #1505 | Link |
When I try to create the DVD, I get an error that says "mplayer.exe missing. Background for title #1 skipped! (XMB)"
I did install mplayer today. Is it looking for it in a specific directory? (I have it in C:\program files\Mplayer for Windows\MPlayer.exe.) Is it a version issue? (I have version 0.0.9.0 created Jan 14, 2009)? Is there more than one program called mplayer, and I have the wrong one? This must be something I did wrong, as noone else has reported this issue. Thanks. |
14th March 2009, 08:49 | #1506 | Link |
Request: More than 40 titles (movies) support.
Hi Deank, me again ;-)
Do you think you'll find some time or reason to extend your great software to allow / support more then 40 titles / movies on one disc? I wonder that noone else seems to have this request. But for only 40 non-HD movies, a BluRay is just too big :-) Thanks for all your work! |
14th March 2009, 09:01 | #1507 | Link | ||
Programmer (or just 教务长)
@Dave5118: How did you understand they are @5mins but not @10? Do you see a log message "Using external chapters"? XMB chapter thumbnais don't follow real chapter marks, but jump points should be correct. Last edited by deank; 14th March 2009 at 10:02. |
14th March 2009, 12:02 | #1509 | Link |
Programmer
LOL, was just wondering the same here today. I have a file of the 81st Academy Awards and its bigger than 5GB so it will not fit on a DVD-R. Tried a burn to DVD dual layer and it would not work in my Panasonic BD30. But I do have an 8GB SD card now that would work out perfect. Heck I would be happy if we could only get one title playing for now on it.
14th March 2009, 12:06 | #1510 | Link |
No there was no "Using external chapters" message in the log. When I tried the created AVCHD (usb) on the PS3, I could see the 'jump points' were still 5 mins by pressing 'select' on the controller.
14th March 2009, 12:08 | #1511 | Link |
Then what do you see? Post your log...
Select [x] Add chapters each 5min... You should see a log message. Code:
[13:11:17] Converting mkv file to AVCHD (D:\Downloads\__TEST\The Matrix 480p.mkv). [13:11:17] Detected video: ID#1:V_MPEG4/ISO/AVC:720x480 23.976fps (AR:1.5) [13:11:17] AR of 16:9 will be set for this title. [13:11:17] Detected audio: ID#2:A_AC3:audio (48000Hz/6ch) Language: eng [13:11:17] Generating meta file for tsMuxer... [13:11:17] M2TS stream split set at 4000MiB... [13:11:17] Adding subtitles (The Matrix 480p.srt) (und) [13:11:17] Adding subtitles (The Matrix 480p.sup) (und) [13:11:17] Checking for external chapters (D:\Downloads\__TEST\The Matrix 480p.txt)... [13:11:17] Using external chapters... [13:11:17] Detected frame reference count: 3 (max:24). [13:11:17] Compliant with L4.1 for 720x480p. [13:11:17] Creating BluRay folders (tsMuxer)... [13:11:20] Done! Last edited by deank; 14th March 2009 at 12:14. |
14th March 2009, 13:14 | #1513 | Link | |||
Hi Dean, this is my log.
14th March 2009, 13:25 | #1514 | Link |
Enable [x] Verbose logging and post back.
There is something wrong that you do... If you have your movie: F:\movie\movie.mkv and chapters F:\movie\movie.txt You should see a log message. You can also execute multiUPDATE.exe and try again... Last edited by deank; 14th March 2009 at 13:35. |
14th March 2009, 15:24 | #1516 | Link |
Dean,
If you implement the Carousel or Cover flow menu that Atak_Snajpera first suggested, will you be able to make it compatible with TVs with up to 5% overscan? The XMB menu is great, but on my HD TVs the top menu is half gone and the bottom line doesn't show at all, which is very typical for HD TVs that were produced before 2007 (at least in the US). So even if I upgrade my TV, it's likely if I bring my videos to show somewhere else, the overscan will cut the menu. Thanks. |
14th March 2009, 16:08 | #1517 | Link | |
Yes, it worked this time, got chapters(jump points) at 10 mins I did also, tick the 'verbose logging' box as well, but doubt that would have fixed it LOL Cheers, Dave. |
14th March 2009, 16:25 | #1518 | Link | |
14th March 2009, 17:19 | #1520 | Link |
Most fixed pixel HDTVs prior to 2007 don't have any over-scan adjustments. I have the service manual for my model, and the question for my model has been ask many of times on the message boards. No over-scan adjustments.
We are not asking for much adjustment to the menus. The footer line is gone, the header line is just about all cut off on my TV. The first few letter on the Title are cut off on the left edge. Calibration discs show you how much overscan your TV has (not tell you how to adjust for it). And 3-5% is the normal range. |
