Old 6th May 2011, 17:33   #41  |  Link
sexus
sexus's Avatar
good work guys keep it up how bout some new contributions to get this thread back up and runnin, rock on!!!
sexus is offline   Reply With Quote
Old 7th May 2011, 07:57   #42  |  Link
burfadel
Originally Posted by Fluffbutt View Post
I've just found out about this whole button thing - very nice!!
Razoola - they are grey until you load a movie becasue they are 'grey-out' as in unusable without a movie loaded.
When you load a movie, only play is blue, then when you press play the rest go blue too - showing that they are now active buttons.
Well, that's what happens here..
Same here
Its the one I've been using since it was first put on here. I do actually believe this should have been made the default one, at least until a much needed UI revamp is done. There's no point having a great media player if new users are put off by a truly archaeic snorefest of a UI!
Old 8th May 2011, 02:46   #43  |  Link
Dark Eiri
Originally Posted by burfadel View Post
Same here
I agree but sadly, most people seem to think it should remain a Windows 95 app.
Dark Eiri is offline   Reply With Quote
Old 13th September 2011, 12:00   #44  |  Link
blaster00
Made a ugly one.
Icons made by webdesignshock and oxygen-icons.
Download 16x16
I will make more as soon as I get some new pretty icons.
blaster00 is offline   Reply With Quote
Old 14th September 2011, 03:45   #45  |  Link
blaster00
Another one.
Download mpc_toolbar_light_16 [16x16]
Old 14th September 2011, 20:44   #46  |  Link
Dark Eiri
Originally Posted by blaster00 View Post
Another one.
This one looks really nice! Maybe should be the new standard and come with the original package?
Old 15th September 2011, 01:05   #47  |  Link
blaster00
The edge of buttons need more work. The current one has white line around it. This will cost some time on the alpha channel and I'm lazy... And I think it is a little too light. Will work on it later.
Since I am not a designer, I just put them together. Any advice of where can I get pretty icons will be appreciated.
Old 27th November 2011, 10:26   #48  |  Link
GIR
GIR's Avatar
mpc_silver.zip (24x24)
GIR is offline   Reply With Quote
Old 27th November 2011, 11:49   #49  |  Link
burfadel
MPC-HC desperately needs at least one of these as a new standard toolbar. Should be one with big buttons! At least then it looks like its meant to be minimalist, the standard buttons are so antiquated that they just make he program look old and outdated, and not minimalist which would be much more ideal.
Old 28th November 2011, 22:35   #50  |  Link
vkapartz
Here's what in my opinion doesn't fit the minimalistic approach:
* The dated yellow volume icon (should be black and minimal)
* The 1-pixel "3D" border of the status bar (should not be there at all)
* The etched borders in the "Playlist" and "Subresync" panels (should mimic the ones in "Shader Editor")
Otherwise, I think MPC looks fine (and that everything, except the seek bar, is not really needed). A "standard" appearance is better than a skin that some people may love and others completely hate.
vkapartz is offline   Reply With Quote
Old 29th November 2011, 08:01   #51  |  Link
tetsuo55
MPC-HC Project Manager
Everything the devs at the time could change we changed. The icons are not the same as they used to be, we remade them from scratch. You obviously notice we kept most of the original style just made them a bit bigger and smoother.
As always if anyone can improve the looks of MPC-HC on a deeper level than just replacing the button images: Patches are welcome.
tetsuo55 is offline   Reply With Quote
Old 29th November 2011, 08:29   #52  |  Link
Mercury_22
Then maybe you can do something about this http://sourceforge.net/apps/trac/mpc-hc/ticket/1598 cause I really can't see a reasonable reason for why it's not yet in the SVN
Windows 10 1809 x64, HD7790 Adrenalin 2019 Edition 19.1.2, HDMI Full RGB 4:4:4
Mercury_22 is offline   Reply With Quote
Old 29th November 2011, 08:52   #53  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
probably coz it's ugly...
Old 29th November 2011, 09:15   #54  |  Link
nevcairiel
Because no-one provided a updated patch, all i see in the ticket are pre-patched code files, which is not acceptable for easy review and commiting.
Old 29th November 2011, 10:10   #55  |  Link
Mercury_22
The patch it's against 3862 (follow the mediafire link http://www.mediafire.com/?nbb4gclb828ax) so to me it seems to be updated
But if needed it can be more updated thanks to Blitzker
@Kurtnoise it's a matter of taste but anyway it's OPTIONAL so nobody it's forcing you to use it (it's NOT enable by default)!
Old 29th November 2011, 10:34   #56  |  Link
nevcairiel
Like i said, its not a patch.
He has a zip with modified source files, thats not a patch. How do i know which lines are modified?
A patch is a special file that just holds the information about what actually changed, much easier to review changes and apply them.
Old 29th November 2011, 10:54   #57  |  Link
Mercury_22
So the BE_Mod_r3830.diff it's not what you're looking for ? cause I've used this to "Apply patch " (using TortoiseSVN) and it's working fine here
EDIT Ouch sorry! I've jut downloaded the new 3862 patch and you're right that one has no diff file but the old one(in the "OLD" folder) has one and also if needed I can provide a diff file too
Old 29th November 2011, 12:46   #58  |  Link
tetsuo55
Mercury_22 if you can provide us with a proper .diff based on a very recent revision I'm sure it will get committed asap(assuming it does not need any comments).
You can attach a diff to the ticket so it can be reviewed on trac itself.
Old 29th November 2011, 12:55   #59  |  Link
Mercury_22
My BE_3864.patch http://www.multiupload.com/8PWOUO2PJ4 (also added to https://sourceforge.net/apps/trac/mp...1598#comment:5)
Thanks to Blitzker
Old 29th November 2011, 18:37   #60  |  Link
Blitzker
Sorry about that, i forgot to include the patch in my last update. I made a new one with r3864 available here: http://www.mediafire.com/?nbb4gclb828ax
for the patch file and the submit to the trac!
Latest dev builds of AssFilterMod can be found here: https://www.mediafire.com/folder/w1w...s/AssFilterMod
Blitzker is offline   Reply With Quote
icons, mpc-hc, toolbar
