10th January 2020, 22:49 | #601 | Link | |
Win10 Pro x64 MPC-HC/LAV/MadVR Laptop w. Geforce GTX1060 > Denon AVR-X2600H > Epson Home Cinema 5050UB |
10th January 2020, 23:49 | #603 | Link |
Haha, people always expect 10 bit to be significantly better but almost everyone needs to use very specific test patterns or bad settings to be able to notice a difference even while pixel peeping with their nose up against the screen.
10 bit output from madVR is not important unless your GPU or screen behave badly with 8 bit HDR.
madVR options explained |
11th January 2020, 05:50 | #604 | Link |
I just tested my 4k 32" monitor to see if I can see a difference with 10-bit via displayport output. Beside madVR I also watch videos in browsers.
One thing I noticed is that though I'm able to set 10-bit 4k@60Hz RGB Full in Nvidia CP and Windows reports 10-bit, but in madVR settings, devices, identification, bitdepths has 8-bit value. I'm not sure what that means, since when connected via HDMI it has 8, 10 and 12-bit values. Also I almost see no differences by playing test patterns in the first page. Last edited by nsnhd; 11th January 2020 at 06:15. |
11th January 2020, 10:46 | #605 | Link | ||
10 bit shows exactly the same banding, but as I understand the colours should blend much more smoothly in this mode. Has things changed since #0 since . you say that it is expected to see no difference between 8 and 10 bit?
11th January 2020, 10:48 | #606 | Link |
Finally, with the Test Patterns from this AVS thread, I can see clearly the difference of 10-bit to 8-bit on my 4k 32" 10-bit monitor. Played with madVR in PotPlayer and toggled 8/10-bit in NCP.
https://www.avsforum.com/forum/139-d...-patterns.html |
11th January 2020, 13:57 | #607 | Link | |
this test file is flawed even the 10 bit has banding.
the file is not dithered from let's say 16 bit it is rounded to 8 bit on the bot and 10 bit on the top so both have banding. beware that nvidia has an very very old bug in the driver where 10 bit WSF with nvidia set to 8 bit will produce a lot of banding. Quote:
11th January 2020, 15:19 | #608 | Link |
Do you guys notice when using the gradient in the first post, when switching display modes in the NVidia Control Panel, madVR will get stuck in "D3D11 windowed (8 bit)" mode, until you reopen the player / redrag the png into the mpc window? Made testing very confusing until I noticed that.
11th January 2020, 21:49 | #610 | Link |
Testing for 8-bit vs. 10-bit has always been flawed, but testing for banding can be done easily. The files from the AVS thread mentioned by nsnhd are perfect for that.
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex |
12th January 2020, 03:58 | #611 | Link |
Less banding for 10-bit but now madVR can't auto switch refresh rate any more. It's fixed by 60Hz and lots of repeated frames, rendering times get higher. I'm not sure if that comes from DP instead of HDMI connection.
LE: I have fixed the stuck 60Hz issue by creating 23, 50, 59Hz custom mode. Now I have a full 10-bit path madVR-GPU-Display with less banding. Last edited by nsnhd; 13th January 2020 at 04:08. |
