Old 2nd March 2015, 17:48   #1  |  Link
pyrobooby
pyrobooby's Avatar
How to use ffmpeg to extract a Dobly E track from a ts file?
ffmpeg  -i Vienna\ Philharmonic\ Orchestra\ -\ New\ Year\'s\ Concert\ \ 2015\ Guests#1\ -\ MPEG2\ \ 422HD\ +DolbyE\ -\ UPLINK\ \[SRSL\].ts
ffmpeg version 2.5.4 Copyright (c) 2000-2015 the FFmpeg developers
built on Feb 15 2015 21:43:03 with gcc 4.8 (Ubuntu 4.8.2-19ubuntu1)
configuration: --extra-libs=-ldl --prefix=/opt/ffmpeg --enable-avresample --disable-debug --enable-nonfree --enable-gpl --enable-version3 --enable-libpulse --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-decoder=amrnb --disable-decoder=amrwb --enable-libx264 --enable-libx265 --enable-libfdk-aac --enable-libvorbis --enable-libmp3lame --enable-libopus --enable-libvpx --enable-libspeex --enable-libass --enable-avisynth --enable-libsoxr --enable-libxvid --enable-libvo-aacenc --enable-libvidstab
libavutil 54. 15.100 / 54. 15.100
libavcodec 56. 13.100 / 56. 13.100
libavformat 56. 15.102 / 56. 15.102
libavdevice 56. 3.100 / 56. 3.100
libavfilter 5. 2.103 / 5. 2.103
libavresample 2. 1. 0 / 2. 1. 0
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
[mpeg2video @ 0xaf4dee0] warning: first frame is no keyframe
[mpegts @ 0xaf4a2c0] PES packet size mismatch
Last message repeated 1 times
Input #0, mpegts, from 'Vienna Philharmonic Orchestra - New Year's Concert 2015 Guests#1 - MPEG2 422HD +DolbyE - UPLINK [SRSL].ts':
Duration: 00:11:04.32, start: 6642.099244, bitrate: 41171 kb/s
Program 1
Stream #0:0[0x200]: Video: mpeg2video (4:2:2) ([2][0][0][0] / 0x0002), yuv422p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], max. 37500 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1[0x1010](ger): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 384 kb/s
Stream #0:2[0x1020](ger): Audio: s302m (BSSD / 0x44535342), 48000 Hz, stereo, s32 (20 bit), 2304 kb/s
At least one output file must be specified
Then, I tried to extract it from the ts container.
ffmpeg  -i Vienna\ Philharmonic\ Orchestra\ -\ New\ Year\'s\ Concert\ \ 2015\ Guests#1\ -\ MPEG2\ \ 422HD\ +DolbyE\ -\ UPLINK\ \[SRSL\].ts -map 0:2 -c:a copy audio.ac3
it repeated the errors like this with process info poping up from time to time.
[mpegts @ 0x9732980] max resync size reached, could not find sync byte
Last message repeated 45 times
Last message repeated 44 times
Last message repeated 43 times
pyrobooby is offline   Reply With Quote
dolby e, ffmpeg
