Old 26th April 2020, 18:32   #1561  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 6.7 Beta:
  • Updated icon to one authored by ArtexJay.
  • Added checkbox and radio button control template override to give it predictable coloring in dark mode and with custom OS themes.
  • Updated HandBrake core.
  • Changed in-progress file names from .mp4.part to .part.mp4 to allow attempts to play partial encodes.
  • Reduced Grayscale checkbox hit area to match text and reduce accidental clicks.
  • Updated Fluent Ribbon to fix issue with underscores getting removed from the "open disc" menu items.
  • Fixed issue with title selection on Pickers.
RandomEngy is offline   Reply With Quote
Old 10th May 2020, 21:05   #1562  |  Link
napouser
when a movie has multiple audio tracks with commentarys some times u see something liek "commentary by director blabla"
when u encode this vlc turns it into "track2 stereo"
is there a way to preserve that info?
napouser is offline   Reply With Quote
Old 11th May 2020, 06:34   #1563  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
The v6 Beta should have the ability to preserve the track names.
Old 12th May 2020, 05:44   #1564  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 5.18:
  • Updated HandBrake core to 1.3.2.
  • Updated translations.
Old 25th May 2020, 15:55   #1565  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 6.8 Beta:
  • Applied fix from HandBrake for static preview crashes.
Old 25th May 2020, 17:24   #1566  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 5.19:
Old 27th May 2020, 15:16   #1567  |  Link
napouser
when u say updated core what version is that? the stadard handbrake or the latest nightly beta? and if so whats the number?
i aam asking cauze i want to upgrade - after a whole year - and i need to install linux and compile a new core with fdk aac so i need to know the version to combile
thanks
Old 7th June 2020, 18:21   #1568  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 6.9 Beta:
  • Added ability to edit subtitle and audio track names from the main window.
  • Added ability to preserve subtitle track names from the source video.
  • Added timestamp on seek bar for file sources, to allow easier comparing with source.
  • Updated "Preserve Create/Modify Time on Files" option to also preserve the "Media Created" extended property.
  • Removed the requirement to set a default output folder. The user's Videos folder is now selected by default.
  • Cleaned up leading zero on hours in title dropdown.
  • Improved encode failure error logging.
  • Fixed formatting issues for video durations over 24 hours.
  • Fixed missing x264 log info.
  • Fixed start/end chapters starting out blank when switching to Chapter range select mode after editing a queue item.
  • Fixed "Open App Data Folder" command for Microsoft Store version when a normal app data folder already exists.
  • Fixed screen reader behavior for subtitle lists on main window.
Old 7th June 2020, 19:15   #1569  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
thanks
VidCoder Beta uses HandBrake nighly builds. You can check the version in Help -> About VidCoder.
Old 4th July 2020, 06:40   #1570  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 6.10 Beta:
  • Added new "Recycle" option for "Delete source files when clearing completed items". With this mode, there will be no confirmation dialog, but the source videos will automatically be sent to the Recycle Bin.
  • Increased simultaneous encoding job maximum to 8.
  • Fixed an issue where it was possible to pick 0 for this value.
  • Removed seek bar timestamp, as it was often inaccurate.
  • Fixed picker audio/subtitle "by index" mode not updating immediately.
Old 9th July 2020, 01:17   #1571  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 5.20:
  • Updated HandBrake core to 1.3.3
Old 9th July 2020, 07:22   #1572  |  Link
varekai
Suspended for forum rule violations
Thanks for the update, much appreciated!
varekai is offline   Reply With Quote
Old 10th July 2020, 15:34   #1573  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 5.21:
  • Fixed crash when access to the image cache folder is denied.
  • Trimmed the "extra options" string to prevent errors.
Old 31st July 2020, 05:39   #1574  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 6.11 Beta:
  • Added logging for deleting source files for completed items. This will break down why a file was not deleted.
  • Trim the "extra options" string to prevent errors.
  • Removed explicit rate for Same as Source CFR.
Old 13th August 2020, 22:16   #1575  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Released VidCoder 6.12 Beta:
  • Moved Window.TaskbarItemInfo initialization to the .xaml.cs file so it can be surrounded by a try/catch. Setting this throws an exception for some users.
  • Added code to work around crash caused by Logitech mouse software interacting with WPF WindowChrome.
  • Fixed issue that prevented typing in decimal numbers for users in locales with "," as the decimal separator.
Old 26th August 2020, 22:22   #1576  |  Link
RandomEngy
VidCoder Author
RandomEngy's Avatar
Hey everyone, going to shut down this thread as there hasn't been a lot of engagement, and email notifications never worked here. This project is still active and you can make comments by opening an issue here:
VidCoder on GitHub
