Old 6th September 2014, 00:12   #21001  |  Link
Ch3vr0n
been using 2048 for a while now
Ch3vr0n is offline   Reply With Quote
Old 6th September 2014, 00:34   #21002  |  Link
AmigaFuture
AmigaFuture's Avatar
Updated the Dirty Dancing post. I hope you're able to repeat it with that BD or another. I'm able to repeat it with Toy Story 3..
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 6th September 2014, 00:40   #21003  |  Link
soneca
Thanks guys. I think everything should be all right with the latest version.
jdobbs, why not do some tests the latest versions of ffdshow and Haali Media Splitter?
I've been testing the latest versions and seem to be 100%.
Unlikely to be updated again, and it also helps prevent certain problems.
soneca is offline   Reply With Quote
Old 6th September 2014, 02:25   #21004  |  Link
HWK
HWK's Avatar
Hmm.. guess I need to get up-to-date. I'm using 2046.
Donald has changed license system in 2047 and beyond. Just wanted to give you heads up.
Here is link to generate license
http://rationalqm.us/licensing.html
If you fail to plan; you plan to fail, would you not agree? Think about it.
HWK is offline   Reply With Quote
Old 6th September 2014, 11:43   #21005  |  Link
andref4
Originally Posted by daberti View Post
Huge thanks
Can Multiprocess be used with Threads is (in my case) at 8?
A little bit OT: can we expect H265 any soon on your program?
in new dvdfab you can use H265. You can try it free for 30 days.
andref4 is offline   Reply With Quote
Old 6th September 2014, 11:51   #21006  |  Link
andref4
I don't now how "isn't recommended version" is ok...
BD-RB doesn't care about FFDSHOW folders or where it is installed. It looks at the registry key (32 bit and 64 bit):
HKLM\Software\GNU\ffdshow
HKLM\Software\Wow6432Node\GNU\ffdshow
If it exists... then FFDSHOW is installed correctly. If not, then it isn't.
I just installed the July 2014 (ffdshow_rev4532_20140717_clsid.exe) version of FFDSHOW and it is working fine (although it hasn't been tested and therefore isn't recommended). So the version has no impact (they all set the registry entry). That tells me something else is the issue (not the version) on your system.
I dont know. Now I use your old 0.48.03 for 2d and a few 3d bds and dvdfab for mkvs and 3d copy. I cant format my machine only whily new bd-reb wont work. On my brothers machine is the same thing. 0.48.05 wont work with ffdshow. And all other Frame Servers are to slow and dont work with cropping black borders. You can remove this option if other Frame Servers are selected. It doesnt work.
Old 6th September 2014, 13:59   #21007  |  Link
jdobbs
The problem with those is that, in the past, I've found that it sometimes takes a month or two of running it before you pick up on something that is a deal-breaker. So it's not just a matter of "Ok I ran it on a few jobs, let's ok it for general use."
Website: www.jdobbs.net
Old 6th September 2014, 14:00   #21008  |  Link
jdobbs
The point is to be able to do it forever, not 30 days.
Old 6th September 2014, 14:02   #21009  |  Link
jdobbs
You're distorting the facts. It works on everybody's machine but yours... because you refuse to follow the installation instructions. How many other posts do you see in this thread that supports your contention? I'll give you the answer: none.
Also... this is a BD Rebuilder thread. Throwing other software into your comments because you are unhappy is inappropriate and off topic.
Old 6th September 2014, 14:31   #21010  |  Link
laserfan
Aging Video Hobbyist
Be wary of 2048, I think it might no longer be compatible with older video cards such as my 9600GT.
But I haven't tested it.
laserfan is offline   Reply With Quote
Old 6th September 2014, 14:56   #21011  |  Link
Ch3vr0n
doubt it, ya could ask him on his forum
Old 6th September 2014, 15:07   #21012  |  Link
soneca
It seems that these cards below do not work with version 2048.
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce GT 340
GeForce GT 330
GeForce GT 320
GeForce 315
GeForce 310
GeForce 9800 GT
GeForce 9600 GT
GeForce 9400GT
Old 6th September 2014, 15:16   #21013  |  Link
jdobbs
Originally Posted by AmigaFuture
I'm testing with an almost stock INI. I stopped the reencode process, and entered FORCE_NOENCODE=1 via the Edit Config. After the refresh I select Preview and the screen grab is what was displayed.
Then I exited BD-RB, then reran...and had it preview again. The file is displayed correctly. It has done it a couple times now with the Red Text. I'm attempting note how to get it to show the text again every time..I'll add to this when I get it.
I don't know what "...the screen grab is what was displayed" means?
I just opened "Toy Story 3" and previewed one of the parts. I then edited the config/ini and set FORCE_NOENCODE=1. I then previewed again. No issue.
I tried it again by starting a job, stopping it, and then setting FORCE_NOENCODE=1 -- still no issue.
Old 6th September 2014, 15:41   #21014  |  Link
Video Dude
Senior Member
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce GT 340
GeForce GT 330
GeForce GT 320
GeForce 315
GeForce 310
GeForce 9800 GT
GeForce 9600 GT
GeForce 9400GT
Don wanted to still support those cards, but because NVIDIA changed/updated the CUDA library he can't. The new CUDA drops support of the older cards.
Video Dude is offline   Reply With Quote
Old 6th September 2014, 16:05   #21015  |  Link
jdobbs
So what's the advantage of the newer library? Faster?
Old 6th September 2014, 16:30   #21016  |  Link
jdobbs
By the way. If you want to get it to work, even with your bad install, just use the registry editor and add the two keys I told you about.
Old 6th September 2014, 16:47   #21017  |  Link
Video Dude
Senior Member
The advantage is for NVIDIA, people will have to buy new cards. It should be mentioned that NVIDIA will soon be dropping driver support for the cards listed above, its not just CUDA support. That means those cards will no longer work with the upcoming driver release.
Anyone interested can read Don's inquiry on the Nvidia forum:
http://devtalk.nvidia.com/default/to...y-version-6-5/
Old 6th September 2014, 18:29   #21018  |  Link
daberti
Thanks, nighly builds of Handbrake offer it.
I gave it a try, but at current moment it is NOT yet ripe enough (H265) IMHO
daberti is offline   Reply With Quote
Old 6th September 2014, 18:30   #21019  |  Link
daberti
Agreed !
Old 6th September 2014, 18:44   #21020  |  Link
Ch3vr0n
@jdobbs: looks like you will have "no choice" but to implement x265 support at some point in the future
http://www.myce.com/news/4k-blu-ray-...nfirmed-72606/
The 4K format will also offer an expanded color gamut, higher frame rates (up to 60fps), high dynamic range (HDR), and will use the H265 video codec for the most efficient compression on the discs.
but ofcourse in the end it's your software, you decide if you'll implement support or not
