6th July 2009, 21:35 | #1061 | Link |
MKVToolNix author
I cannot reproduce this. I've created a chapter file with dvdxchap from ogmtools 1.5 which contains 36 entries. Then I've merged this file normally into a Matroska file (mkvmerge -o v.mkv v.avi --chapters chapters.txt). The resulting file also contains exactly 36 chapters:
[0 mosu@tionne /tmp] mkvinfo -v -v v.mkv | grep -i 'atom' | wc -l 36 I don't know what MediaInfo thinks happens in that file or what exactly happens on your computer. How did you create that Matroska file? Please re-check with mkvinfo. I don't trust other programs all that much in this regard. What kind of a container format was your source file? If it was a MP4 file which in turn contained chapters (a single entry) then this might explain this behaviour. You can check this with "mkvmerge -i input.mp4".
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
6th July 2009, 21:50 | #1062 | Link |
ffx264/ffhevc author
Hi Moritz,
I checked with mkvinfo and it's reported there as well. This is usually my mkvmerge command line /usr/bin/mkvmerge --attachment-mime-type image/jpeg --attachment-name Cover --attach-file "/home/neutrino/cover.jpg" -A --title "The Bank Job" --track-name 0:"The Bank Job" "/home/neutrino/The Bank Job.avi" --track-name 1:"HE-AACv1 Stereo" --language 1:en --aac-is-sbr 1:1 /home/neutrino/audio.aac --chapters "/home/neutrino/The Bank Job.chaps" -o "/home/neutrino/The Bank Job.mkv" I only take the video from the AVI and an external audio encoded by neroAacEnc which both get muxed into mkv. Code:
neutrino@neutrino:~> mkvinfo -v -v "The Bank Job.mkv" | grep -i 'atom' | wc -l 26 |
6th July 2009, 22:00 | #1063 | Link |
MKVToolNix author
Upload the chapter file somewhere, please, or send me an email to moritz@bunkus.org
6th July 2009, 22:04 | #1064 | Link |
Here it is http://www.mediafire.com/download.php?wemmjcmomdo
btw, could it have something to do that I use -o as last instead of as first parameter? eg, mkvmerge blablabla -o output.mkv VS mkvmerge -o output.mkv blablabla |
6th July 2009, 22:13 | #1065 | Link | ||
MKVToolNix author
2. I still cannot reproduce the problem here with the chapter file you've uploaded. AVI files do not contain chapters (or mkvmerge doesn't support reading chapters from them). So I really don't know what's wrong here. You may upload the AVI file in question to my FTP server if you want, but if not then I cannot really help you. BTW, please post the output of 'mkvmerge --identify-verbose "/home/neutrino/The Bank Job.avi"'. Quote:
The following command line uses dummy files in place of your original ones, obviously: Code:
[0 mosu@tionne ~/dl] mkvmerge --attachment-mime-type image/jpeg --attachment-name Cover --attach-file ~/files/Pictures/Desktop/gilmorewall.jpg -A --title "The Bank Job" --track-name 0:"The Bank Job" ~/prog/video/mkvtoolnix/data/v.avi --track-name 0:"HE-AACv1 Stereo" --language 0:en --aac-is-sbr 0:1 /ftp/.rip/mkv/qtmp4/aac/sbr/sample_44-2-16_HE_AAC.aac --chapters "The Bank Job.txt" -o "The Bank Job.mkv" ... [0 mosu@tionne ~/dl] mkvinfo -v -v The\ Bank\ Job.mkv| grep -i atom | wc -l 25
6th July 2009, 22:35 | #1066 | Link | |
Hi, Moritz
@1 - well, I tried both --track-name 0 and --track-name 1 on the audio.aac file and mkvmerge does not display a warning. All I see in both cases is this Quote:
as for the identify thing... Code:
mkvmerge --identify-verbose "/home/neutrino/The Bank Job - chapter 1-1.avi" File '/home/neutrino/The Bank Job - chapter 1-1.avi': container: AVI Track ID 0: video (h264) [packetizer:mpeg4_p10_es_video] Track ID 1: audio (PCM) |
6th July 2009, 22:40 | #1067 | Link | ||
MKVToolNix author
6th July 2009, 22:55 | #1068 | Link | ||
With --track-name 0 --language 0 Code:
mkvmerge -A The\ Bank\ Job\ -\ chapter\ 1-1.avi --track-name 0:"foobar" --language 0:en audio.aac -o output.mkv mkvmerge v2.9.7 ('Tenderness') built on Jul 2 2009 03:11:06 'The Bank Job - chapter 1-1.avi': Using the AVI demultiplexer. Opening file. This may take some time depending on the file's size. 'audio.aac': Using the Quicktime/MP4 demultiplexer. 'The Bank Job - chapter 1-1.avi' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 313/176. 'The Bank Job - chapter 1-1.avi' track 0: Using the MPEG-4 part 10 ES video output module. 'audio.aac' track 1: Using the AAC output module. Warning: 'audio.aac': A track with the ID 0 was requested but not found in the file. The corresponding option will be ignored. The file 'output.mkv' has been opened for writing. Progress: 100% The cue entries (the index) are being written... Muxing took 3 seconds. Code:
mkvmerge -A The\ Bank\ Job\ -\ chapter\ 1-1.avi --track-name 1:"foobar" --language 1:en audio.aac -o output.mkv mkvmerge v2.9.7 ('Tenderness') built on Jul 2 2009 03:11:06 'The Bank Job - chapter 1-1.avi': Using the AVI demultiplexer. Opening file. This may take some time depending on the file's size. 'audio.aac': Using the Quicktime/MP4 demultiplexer. 'The Bank Job - chapter 1-1.avi' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 313/176. 'The Bank Job - chapter 1-1.avi' track 0: Using the MPEG-4 part 10 ES video output module. 'audio.aac' track 1: Using the AAC output module. The file 'output.mkv' has been opened for writing. Progress: 100% The cue entries (the index) are being written... Muxing took 6 seconds. Quote:
6th July 2009, 23:03 | #1069 | Link |
MKVToolNix author
You can stop the upload(s). The audio.aac file is actually a MP4 file and not a raw AAC file. That's why the track ID starts at 1 for you and not at 0, and that's probably where the lone chapter entry comes from. Reading chapters from MP4 files is a rather new feature, that's why you don't see the problem with older versions.
You can verify this with "mkvmerge -i audio.aac"; it should show chapters. You can turn off copying chapters from that file with the "--no-chapters" option, e.g. "mkvmerge -o ... --no-chapters audio.aac". You'd better rename the file to audio.mp4, too
6th July 2009, 23:11 | #1070 | Link | |
I'll be using --no-chapters in the future then. Thanks for the great support |
6th July 2009, 23:17 | #1071 | Link |
MKVToolNix author
You're welcome.
8th July 2009, 00:51 | #1073 | Link |
I tried adding a PCM file but it keeps thinking it's an h.264/avc MPEG4 part 10 elementary stream. Here's the eac3to info for the file.
eac3to v3.16 command line: eac3to audio.pcm -log=pcm.info.txt ------------------------------------------------------------------------------ This might be a RAW/PCM file. Trying to figure out the details. This will probably take a while. Please be patient... The RAW/PCM file seems to be big endian. The RAW/PCM file seems to have a bitdepth of 16 bits. The RAW/PCM file seems to have 6 channels. RAW/PCM, 5.1 channels, 0:00:47, 16 bits, 4608kbps, 48khz
Chumbo |
8th July 2009, 08:27 | #1074 | Link |
MKVToolNix author
Raw PCM files are not supported and never will be.
8th July 2009, 10:59 | #1075 | Link |
attachment loss after remuxing
I have two files:
1. a.mkv with one ASS track and 3 attaches fonts. 2. b.ass Look at the following sequence: 1. add a and b into mmg 2. uncheck ASS track (from a.mkv) 3. remux the result into c.mks After this sequence I get c.mks without attached fonts. Don't think it's intended behaviour. This workaround works ok: 1. add a and b into mmg 2. remux the result into t.mks 3. reset mmg; add t.mks 4. uncheck old ASS track 5. remux the result into c.mks If this description isn't enough, I can provide all necessary test files |
8th July 2009, 13:36 | #1076 | Link | |
8th July 2009, 13:44 | #1077 | Link |
MKVToolNix author
You might also make sure that you're testing this with mkvtoolnix 2.9.7 as I have changed the way that "track-less" files are handled in one of the latest releases due to the change how mmg presents attachments, chapters and tags present in source files.
8th July 2009, 15:34 | #1078 | Link | |
Samples: http://nwfiles.gorodok.net/a.mkv http://nwfiles.gorodok.net/b.ass |
