4th June 2007, 17:55 | #1422 | Link | |
Turkey Machine
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
4th June 2007, 18:19 | #1423 | Link |
Didée Fan
Using xxl 1240 FFDshow
http://downloads.sourceforge.net/ffd...5&big_mirror=0 Here's the log http://files.filefront.com//;7690920;;/ Here's a picture of the graph I used FFDshow Mpeg2 libavcodec dvd decoding and the nvidia video decoder. It still showed no back or ahead, buffer was checked in Avisynth. i USED vmr9, DEFAULT OUTPUT IN mpc. The plugins I linked to before. and this code Code:
#debug SetMemoryMax(1024) FluxSmoothT(3) ColorMatrix(Mode="Rec.601->Rec.709",scaling=2,threads=2) MT("SeeSaw(NRlimit=0, NRlimit2=5, Sstr=2.40, Szp=1, Slimit=50, Sdamplo=16, Spower=1, sootheT=95, SdampHi=39)",3) lanczosresize(720, 480)
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. Last edited by Jeremy Duncan; 4th June 2007 at 18:23. |
4th June 2007, 19:26 | #1424 | Link |
Posts: n/a
Sorry if this is the wrong place to post this question about ffdshow usage, but I'm having trouble finding the right place with so many different pages out there. If it is, can anyone point me to the correct place? I've used a lot of different recent builds by various people with different results, and am wondering what is the best build for my particular setup, as I'm aware they are sometimes optimized for various Operating systems and instructions sets. I have an old PIII 1.4ghz with MMX and SSE but nothing above that, and am running XP SP2. I am currently using the ffdshow_rev1099_20070414_xxl.exe build. Any advice on the best build to use, and where to get it would be appreciated. Matt |
4th June 2007, 20:26 | #1425 | Link |
Any of the generic builds will do just fine.
MPC-HC 2.2.1 |
4th June 2007, 20:42 | #1426 | Link |
I have been playing around with the new Leak's patched ffdshow (ffdshow_rev1237_20070603_clsid.exe), and try to accomplish this:
Is it makes sense at all to telecine 23.976 fps progressive content to 59.94 fps progressive one on a LCD TV/monitor running 60 Hz (from my comp) ? If it is: I have tried a 720p-avc content, with MPC, ffdshow decodes H264 and Haali's renderer. Settings: x Avisynth , Ignore Pulldown, Buffer back/ahead: 30/30 (I don't know which values must be entered for ChangeFPS) my avisynth script: # I'm using the modded dll SetMTMode(1,0) # some sharpening, good results with good speed asharp(1,6,-1,true) # telecine to 59.94 fps: it creates a 3232.. pattern from 23.976 fps ChangeFPS("ntsc_double") I doubled the default values in Haali's renderer too: Buffers: 65M , Frames: 82 Without Leak's patch: it stutters like hell. But with it, sometimes it skips frames, maybe my comp is slow for it ... My comp is: Athlon X2 4600, 1GB DDRAM, GeForce 7600GT (256MB) And last: thanks guys for your hard work! |
4th June 2007, 21:04 | #1427 | Link | |
ffdshow/AviSynth wrangler
Anyway setting the buffers to 30/30 is really close to madness; the higher you set them the more lag you'll get and I'd not be surprised if your dropped frames come from that. You *should* see the current best values for ahead and back in the OSD ("AviSynth info"), but you might not since there's something funny going on with it currently that I can't pinpoint... Anyhow, I bet 0/1 (or 0 and a very small number) should be plenty for your use case, but honestly I think your best bet would be to just play your video as-is and let the renderer duplicate frames where neccessary. Of course, setting your monitor to 72 Hz would be best... np: Mouse On Mars - Schlecktron (Double Mix) (Rost Pocks)
now playing: [artist] - [track] ([album]) |
5th June 2007, 06:59 | #1431 | Link |
I think that MPEG1 (both libavcodec and libmpeg2) decode is broken. I tested with this sample and noticed that it stutters a lot (at 0:11 sec, per example), and the aspect ratio isn't correct. The file was verified with MPC internal filter, Windows XP default decoder (with MPC and WMP11), VLC and SMPlayer (MPlayer), and it seems to run very well.
I tried with the build 1245 (inside the 'About' tab is written 1240, hehehe). Last edited by Delerue; 5th June 2007 at 09:21. |
5th June 2007, 08:10 | #1433 | Link | |||
From the manual: ChangeFPS changes the frame rate by deleting or duplicating frames. So I'm think it doesn't produces combed frames. Quote:
ChangeFPS("ntsc_double") is still unwatchable, I'll try ChangeFPS("ntsc_video") which results a 1111211112... pattern. Quote:
Yep, but my TV is only capable of 60 Hz. |
5th June 2007, 08:22 | #1434 | Link | |||
now playing: [artist] - [track] ([album]) Last edited by Leak; 5th June 2007 at 08:30. |
5th June 2007, 08:38 | #1435 | Link |
Angel of Night
SVQ3 with b-frames has had that problem for a while. It definitely sucks, I didn't find the problem last time but I'll look again - it might be a splitter issue though. (Sourceforge's tracker is impossibly bad for searching and sorting, but I think it isn't officially reported there. I'll take care of it. I'd donate if only they'd improve that and the mailing list, but I almost want to install Jira or Trac on the webspace instead.)
Bringing up a cam here was a bad idea though. Struck for rule 6. Last edited by foxyshadis; 5th June 2007 at 12:20. |
5th June 2007, 08:51 | #1436 | Link |
Angel of Night
Put the changefps at the end of the script definitely, and try not to use other ffdshow filters after it. You'll now be (uselessly) filtering everything at 60fps instead of 24. You could also use convertfps (blended instead of jerky). Or make a short function to insert between each cycle a blend of frames 4 & 1 of the next, but that'll only be 29.97fps. I'd probably get too fancy for your tastes, I <3 the script.
Sometimes I really just wish you could have multiple avisynth instances, to run things like this after everything else. |
5th June 2007, 09:06 | #1437 | Link | |
It was traler from one of movie news sites. I just change extension from mov to mp4, so it can be played using Haali Splitter instead a QT. P.S. Can you delete that link from your post too? Last edited by B.F.; 5th June 2007 at 09:40. |
5th June 2007, 09:19 | #1438 | Link | |
*backs away slowly, trying to make no noise* *turns around quietly* *runs like hell*
5th June 2007, 11:16 | #1439 | Link |
All InnoSetup installers are already capable of performing silent installs...
installer.exe /verysilent (changing the options in the installer is possible too with /components="item1,item2,etc" /tasks="item1,item2,etc")
MPC-HC 2.2.1 |
5th June 2007, 21:24 | #1440 | Link | |||
And an interesting thing with MPC-ffdshow_h264decoding on a dualcore CPU (no further filters are applied with the test): 1. start a 720p-AVC content, and see the loads of CPU (at here, core1 is minimal, core2 is very high) 2. stop the playback (don't close MPC), then start the playback again, and see the CPU: at here, the 2 cores is almost the same. Can somebody reproduce this? (I haven't installed AMD's DualCore Optimizer, but I use RMClock for it.) |
