Old 10th December 2018, 12:58   #3281  |  Link
kypec
User of free A/V tools
kypec's Avatar
Thank you StainlessS & qyot27 for suggestions. Yes, I fixed the problem by using pip3 install --upgrade cython instead of (legacy?) pip but forgot to reply here. The last obstacle was to resolve issues with environment variables LD_LIBRARY_PATH and PYTHONPATH but finally -> vspipe runs as expected!
kypec is offline   Reply With Quote
Old 20th January 2019, 15:55   #3282  |  Link
Selur
Selur's Avatar
Is there a Vapoursynth plugin which can show the wave front of an audio clip? (I'd like to see the wave front when deciding there to cut/trim a source.)
Old 22nd January 2019, 14:16   #3283  |  Link
F1nkster
Having an issue on Win10 using a custom Python library path with VapourSynth. I add the path to PYTHONPATH and everything works fine from the Python CLI. I then go into VSEdit and add the path in Settings. It works fine only when I run VSEdit as Admin. It fails to find my libraries if I run as my normal user account.
At first, I thought it was an issue with VSEdit. However, I am having the same problem loading a VPY script into VDub2. I have to run VDub2 as Admin for the custom path to work, which makes me think there's something else going on beyond VSEdit.
I gave my user account full rights to the Python37, VapourSynth, and VapourSynth Editor directories and everything in them. And my account already has full access to the custom library path. I reinstalled Python37 with support for All Users. None of this helped.
Btw, my normal user account works fine with the standard Python37\Lib\site-packages\vapoursynth directory. No issues there. So that's my fallback.
Just seeing if anyone else has thoughts.
F1nkster is offline   Reply With Quote
Old 25th January 2019, 04:38   #3284  |  Link
Revan654
Revan654's Avatar
Is there any on going issues currently with Windows 10 that's causing any kind of issues with Python or VapourSynth? It seems like I'm doing nothing but fighting with these two parts. I checked Registry and file locations everything is pointing to the correct path / files. Not even VS Editor wants to load now.
Last night it was fine, then when I booted up today nothing. I know last night Windows updated something, along with VS 2017.
Revan654 is offline   Reply With Quote
Old 25th January 2019, 20:01   #3285  |  Link
Revan654
Revan654's Avatar
Finally Fixed it after hours of Playing around with python. It worked after I installed Numpy & Pillow.
Old 26th January 2019, 09:20   #3286  |  Link
_Al_
crash
Hi, I know this is wrong:
clip = core.resize.Bicubic(clip, vs.RGB24)
but it causes crash for all apps loading script, that error is not caught by script evaluations, perhaps vs.RGB24 is being loaded into wrong place. It gives out legit VideoNode though. RAM overruns even with core.max_cache_size set.
_Al_ is offline   Reply With Quote
Old 26th January 2019, 19:33   #3287  |  Link
Revan654
Revan654's Avatar
Your missing format syntax. You should only leave out the syntax if you know exactly the order of the variables are.
clip = core.resize.Bicubic(clip, format=vs.RGB24)
You could also Use this:
clip = core.fmtc.resample (clip, css="444")
clip = core.fmtc.matrix (clip, mat="709", col_fam=vs.RGB)
clip = core.fmtc.bitdepth (clip, bits=8)
Old 26th January 2019, 22:43   #3288  |  Link
_Al_
Yes, I wanted to bring up if anyone makes this line it freezes and crashes, because Vapoursynth takes 2000010 (id for vs.RGB24) as width.
Argument width, does not have to be explicitly stated, width=something. But that resize is quite complex thing. Color spaces conversions etc., maybe it should be mandatory to state width=something, format=something. Not gravely important, sure.
This is one of those things to repel newcomers to use Vapoursynth. Resize is almost used in every script. So format has to be specified, but not width, not a consistent somehow. It is hard to understand if you are a video guy, not a programmer. But again, I do not expect this to be fixed, I take it as a flag if someone googles it or whatever.
Old 26th January 2019, 23:19   #3289  |  Link
poisondeathray
No pathway . That's the error message.
If "clip" is YUV, you need to specify matrix_in_s="709" (or whatever matrix) , if it's not already specified in the clip props
Old 26th January 2019, 23:40   #3290  |  Link
_Al_
I understand that. It took me some hours though to figure that out last year. It takes that value from props, if it is usable, it uses it. Sometimes it is in props , sometimes not, it depends if source filter registers that taking it from video. If not , it has to be specified, if it is needed and not specified error is returned. Which in a sense is great, because we do not want to have any defaults in background going on. If those values loaded by source plugin taken from video are correct ones is another issue of course.
Also values in props are numerical (int) and to get corresponding string value, other script lines are needed to put it on screen. Which you of course can mess you up if you are learning it. :-) matrix table of numerical values with corresponding string values:
matrix_ITU = {0:'rgb', 1:'709', 2:'unspec', 3:'reserved', 4:'fcc',
           5:'470bg', 6:'170m', 7:'240m', 8:'ycgco', 9:'2020ncl',
          10:'2020cl' , 100:'OPP',
matrix_USABLE_ITU = ['709', 'fcc', '470bg', '170m', '240m', 'ycgco', '2020ncl', '2020cl', 'OPP']
myrsloik website explains that but those numbers are not matching, I pulled them from here
page 430 Table E.5 Matrix coefficients interpretation
Old 27th January 2019, 00:31   #3291  |  Link
lansing
Yup the error handling is missing, it should return the error instead of crashing the program.
Old 27th January 2019, 01:55   #3292  |  Link
qyot27
qyot27's Avatar
The problem was that the parameter order wasn't obeyed, so when you told it width=vs.RGB24 (which is what you did by omitting actual width and height and then not explicitly declaring format=), it did exactly what it was told and interpreted 'vs.RGB24' as an integer.
video,848,480,vs.RGB24 = this will work
video,vs.RGB24 = this won't work
AviSynth works exactly the same way concerning parameter order - if you drop one parameter in the middle, everything after that requires explicitly declaring the parameter name too for the values to be set to the right option.
The actual source of the immediate crash is that resizing to 2 million pixels wide is going to cause problems *somewhere* in the chain.
Old 1st February 2019, 05:33   #3293  |  Link
asarian
Can you set a (vertical) offset to core.sub.ImageFile? Really looking to lower the subs a bit.
Gorgeous, delicious, deculture!
asarian is offline   Reply With Quote
Old 1st February 2019, 13:01   #3294  |  Link
jackoneill
unsigned int
jackoneill's Avatar
No, but if you pass blend=False you get only the subtitles, and you can use Crop and AddBorders to move them. Of course then you have to blend them manually with your video clip.
http://www.vapoursynth.com/doc/plugins/subtext.html
Hire me to write code!
jackoneill is offline   Reply With Quote
Old 1st February 2019, 15:11   #3295  |  Link
asarian
I tried to whip out the old SupTitle.dll (as I remembered it can do 'relocation'), but that wouldn't run somehow:
core.avs.LoadPlugin ("C:/VS/plugins/SupTitle.dll")
Should still work, right?!
EDIT: Yeah, that's an old 32-bit filter. Nevermind.
Old 2nd February 2019, 02:25   #3296  |  Link
lansing
Would it be a good idea for vapoursynth to implicitly set the value of an argument to its default value when we declared it without giving it a value? Something like this
fm = core.vivtc.VFM(clip, order)
instead of this
fm = core.vivtc.VFM(clip, order=0) # assuming 0 is the default
Sometime when I'm testing a filter, I would display all its arguments with vs editor's autocomplete feature, and I don't want to go into the manual to enter the default value manually for everyone of them.
Old 2nd February 2019, 03:25   #3297  |  Link
HolyWu
HolyWu's Avatar
You can pass None as value to non-mandatory arguments and the filters will use its default values as usual. Passing None to mandatory arguments won't work for obvious reason.
HolyWu is offline   Reply With Quote
Old 3rd February 2019, 13:07   #3298  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I was trying to load pinterf's MVTools2 build in Vapoursynth, but the functions don't appear in the avs namespace (using core.avs.MAnalyze just says that the function doesn't exist). I get this error in the VapourSynth Editor log, is it the reason?
Avisynth Compat: varargs not implemented so I'm just gonna skip importing MStoreVect
Old 3rd February 2019, 18:47   #3299  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Support for avisynth mvtools was removed in R40 due to the ugly hacks needed that slowed down all avisynth filter creation. And and a native version has existed for a long time now.
You can probably grab the avscompat.dll from R39 and use that if you really want to test things though.
Myrsloik is offline   Reply With Quote
Old 3rd February 2019, 19:51   #3300  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks, looks like I'll skip it then. I was just thinking about testing it in case Zopti starts crashing the native plugin which probably doesn't have all the fixes and tweaks from the AVS version. It's been quite some time since the last commit.
speed, vaporware, vapoursynth
