Old 25th April 2018, 18:25   #3061  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by Selur View Post
@foxyshadis: I get what max_cache_size is meant to do, what I don't get is why setting it to two times your RAM size is the right thing.
It's really not. It can easily eat all the RAM you have when the script is initialized and it takes quite a lot of time for VS to release the excess memory so your computer is pretty much frozen. I've settled down for 10240 on my 16 GB system as I can just manage that with BD to 720p encodes.
Old 26th April 2018, 04:42   #3062  |  Link
HolyWu
HolyWu's Avatar
Originally Posted by DJATOM View Post
I found a bug. Well, not sure if that's really a bug, but might be unwanted behaviour of resizer.
You probably need to provide an script to demonstrate what you really do, if you want the developers to resolve your doubts.
HolyWu is offline   Reply With Quote
Old 26th April 2018, 10:00   #3063  |  Link
DJATOM
Okay. Script below is just stripped version to reproduce my problem.
PHP Code:
import havsfunc as haf
import mvsfunc
as mvf
import descale
as dsc
clip
= <some 1920x1080 clip>
descale_str 0.32
kernel
'bicubic'
descale_h 540 # 1080/2 to reproduce the problem
clip.width
clip.height
descale_w
haf.m4((descale_h) / h)
descale_natural dsc.Descale(clipdescale_wdescale_hkernel=kernel)
descale_aa core.resize.Spline36(clipdescale_wdescale_h)
descaled core.std.Merge(clipb=descale_naturalclipa=descale_aaweight=descale_str)
dx w
dy
h
ux
descale_w 2
uy
descale_h 2
rescale
core.eedi3m.EEDI3(descaledfield=1dh=Truealpha=0.2beta=0.25gamma=1000.0vcheck=3sclip=core.znedi3.nnedi3(descaledfield=1dh=Truensize=0nns=4pscrn=1))
rescale core.std.Transpose(clip=rescale)
rescale core.eedi3m.EEDI3(rescalefield=1dh=Truealpha=0.2beta=0.25gamma=1000.0vcheck=3sclip=core.znedi3.nnedi3(rescalefield=1dh=Truensize=0nns=4pscrn=1))
#rescale = core.fmtc.resample(rescale, dx, dy, -0.5, -0.5, ux, uy, kernel='spline36').fmtc.bitdepth(bits=8) # always fixes eedi3 shift, but I need to call bitdepth function, that's not convenient.
rescale core.resize.Spline36(rescaledxdysrc_left=-0.5src_top=-0.5src_width=uxsrc_height=uy# leaves eedi3 shift untouched if rescale clip's width and height matches the source.
Me on GitHub | My Telegram
DJATOM is offline   Reply With Quote
Old 26th April 2018, 11:09   #3064  |  Link
HolyWu
HolyWu's Avatar
Indeed, the internal resizer doesn't do the shifting if you don't change the dimensions at the same time. I use fmtconv to do the shifting in santiag so never notice this problem.
Here is a much simpler script to reproduce:
PHP Code:
clip core.std.BlankClip(width=640height=360length=1format=vs.YUV420P16color=[655353276832768])
clip core.std.AddBorders(clipleft=40right=40top=60bottom=60)
clip core.std.Interleave([core.fmtc.resample(clipsx=-32sy=-32), core.resize.Spline36(clipsrc_left=-32src_top=-32)])
Old 26th April 2018, 11:16   #3065  |  Link
ChaosKing
You could also use edi_rpow2.py https://gist.github.com/YamashitaRen...7524e794779d9c (or just copy the shifting code)
Search and denoise
ChaosKing is online now   Reply With Quote
Old 26th April 2018, 11:50   #3066  |  Link
DJATOM
zimg way is most likely broken, I didn't checked.
PHP Code:
Y=core.std.ShufflePlanes(clips=clipplanes=0colorfamily=vs.GRAY)
Y=core.resize.Spline36(clip=Y,width=clip.width,height=clip.height,src_left=hshift,src_top=-0.5
clip.width = Y.width, clip.height = Y.height, so resizer is just copying whole plane without doing the job. Another planes should be fixed if colorspace is not YUV444.
Old 28th April 2018, 02:49   #3067  |  Link
hydra3333
Yay, vapoursynth ffmpeg integration seems to be in its way.
http://ffmpeg.org/pipermail/ffmpeg-d...il/229137.html
I also hold some hope for "for dummies" vapoursynth library build instructions leading to building of a static ffmpeg.exe (including python libs and any other dependencies) ...
Old 28th April 2018, 06:57   #3068  |  Link
Selur
Selur's Avatar
... leading to building of a static ffmpeg.exe (including python libs and any other dependencies) ...
I highly doubt that will happen, since you would probably need to include a whole Python portable environment (or at least a huge portion of it).
To open .vpy-scripts you at least some sort of a Python (runtime) environment.
Cu Selur
Ps.: To open .avs-scripts you need the avisynth.dll (and dependencies).
Old 28th April 2018, 07:05   #3069  |  Link
hydra3333
Ah. I'd hoped, since youtube-dl manages to do it resulting in a standalone .exe ...
For some, unless maybe it could use vapoursynth portable in the same folder, non-static would be as useful as teats on a bull
Old 28th April 2018, 07:26   #3070  |  Link
Selur
Selur's Avatar
youtube-dl isn't statically compiled it seems to wrap all the dependencies it requires.
Yes once could also wrap a whole hdd this way and create one large binary, but that isn't statically compiling that is basically the same thing Mac does with it's .app files.
(Provide mostly standalone packages which are basically a folder structure which contains dependencies&co.)
Cu Selur
Old 30th April 2018, 00:36   #3071  |  Link
ChaosKing
Is it possible to compare the value of f.props.PlaneStatsAverage in a FrameEval function with the previous and the next frame (n-1 and n+1)? Sould I use get_frame_async() for that?
def g(n, f, clip, d_clip):
	clip=clip.text.Text("current: "+ f.props.PlaneStatsAverage)
	clip=clip.text.Text("\nPrev: "+ ???)
	clip=clip.text.Text("\n\nNext: "+ ???)
	return clip
clip = clip.std.FrameEval(functools.partial(g, d_clip=d_clip, clip=clip), prop_src=x)
Edit
This works but feels more like a hack.
x= clip.std.PlaneStats()
x1= clip.std.PlaneStats().std.DuplicateFrames(0) #prev
x2= clip.std.PlaneStats().std.Trim(1) #next
clip = clip.std.FrameEval(functools.partial(g, d_clip=d_clip, clip=clip), prop_src=[x, x1, x2])
Search and denoise
Old 1st May 2018, 22:39   #3072  |  Link
amayra
Quality Checker
amayra's Avatar
Python development mode
A new command-line switch for the Python interpreter, -X, lets the developer set a number of low-level options for the interpreter. With Python 3.7, the option -X dev enables “development mode,” a slew of runtime checks that normally have a big impact on performance, but are useful for a developer during the debugging process
as vapoursynth user is this benefits me ?
I love Doom9
amayra is offline   Reply With Quote
Old 1st May 2018, 22:44   #3073  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
	return clip
Edit
That's the right way.
Myrsloik is offline   Reply With Quote
Old 1st May 2018, 23:03   #3074  |  Link
LigH
LigH's Avatar
@ amayra:
Users will probably not benefit directly from debugging switches, because users will usually prefer the fastest possible execution. You may have read that these additional runtime checks will "have a big impact on performance" (see your quote), which means that it will run a lot slower and report a lot of warnings, even of less probable conditions.
But if a developer can use this mode to discover risky code and fix bugs (possibly even before they cause noticeable issues), then users may benefit indirectly from an advanced release build.
New German Gleitz board
Old 2nd May 2018, 14:16   #3075  |  Link
ChaosKing
@Myrsloik
Ok, thx.
I found a strange behaviour while playing with FrameEval func.
The very same function gives different output if it's called within FrameEval.
Is it a bug or did I miss something?
Here's an animated gif of my problem (correct output is in the middle):
And my script (You'll need also Single Precision MVTools https://github.com/IFeelBloated/vapo...h-mvtools-sf):
import sys
import os
import functools
import vapoursynth as vs
import mvsfunc as mvf #https://github.com/HomeOfVapourSynthEvolution/mvsfunc/blob/master/mvsfunc.py
import mvmulti as mv #https://github.com/IFeelBloated/vapoursynth-mvtools-sf/blob/master/src/mvmulti.py
import fvsfunc as fvf #https://github.com/Irrational-Encoding-Wizardry/fvsfunc/blob/master/fvsfunc.py
core = vs.get_core()
def myFilter(clip):
	pre = haf.SMDegrain(clip, tr=2, pel=2, contrasharp=False, thSAD = 1200, thSADC = 1200, prefilter=2)
	pre = pre.flux.SmoothT(temporal_threshold=6)
	pre = haf.DitherLumaRebuild(pre, s0=1)
	pre = fvf.Depth(pre, 32, range_in=1)
	clip = mvf.Depth(clip, 32)
	super = core.mvsf.Super(pre,16,16,1,0)
	vectors = mv.Analyze(super, blksize=16, overlap=8, search=4, tr=6)
	super = core.mvsf.Super(clip,16,16,1,1)
	blur_clip = mv.DegrainN(clip, super, vectors, thsad=600, tr=6)
	grain = blur_clip.grain.Add(var=1200.0, constant=True)#.std.BoxBlur(hradius=1, hpasses=1, vradius=1, vpasses=1)
	#return grain
	diff_clip = core.std.Expr([clip, blur_clip], 'x y - abs').std.Inflate(threshold=200/255).std.Inflate(threshold=200/255)
	mask_clip = diff_clip.std.Binarize(threshold=[3.3/219, 3.3/224], v0=0, v1=80/255)
	clip = core.std.MaskedMerge(clipa=blur_clip, clipb=grain, mask=mask_clip)
	return mvf.Depth(clip, 8)
clip = core.std.BlankClip(format=vs.YUV420P8, width=120*2, height=80*2, length=100, color=[206,235,135])
g_static  = clip.grain.Add(var=100.0, constant=True)
g_dynamic = clip.grain.Add(var=100.0, constant=False)
clip = core.std.StackHorizontal([
	core.std.StackVertical([g_static, g_static]),
	core.std.StackVertical([g_static, g_dynamic])
goal = core.std.StackHorizontal([
orig=clip
def asd(n, c):
	return myFilter(c)
feval = clip.std.FrameEval(functools.partial(asd, c=clip))
def comp(a, b, crop=0):
	return core.std.StackHorizontal([
		core.std.CropRel(a, crop,crop,0,0), \
		core.std.CropRel(b, crop,crop,0,0), \
nofeval = myFilter(clip)
clip = comp(feval.text.Text("Function inside FrameEval").std.AddBorders(right=2), nofeval.text.Text("No FrameEval").std.AddBorders(right=2), crop=0)
clip = comp(clip, orig.text.Text("unfiltered"), crop=0)
clip.set_output()
Search and denoise
Old 2nd May 2018, 14:22   #3076  |  Link
Myrsloik
Myrsloik's Avatar
@Myrsloik
Ok, thx.
The same function gives different output if it's called within FrameEval.
Here's a animated gif of my problem (correct output is in the middle):
Should be identical in theory, yes. Unless some filter stores temporal state incorrectly. Then you get this. Gradually remove each filter and see when the output is once again identical, then report which filter it was. I'm going to bet mvtools or fluxsmooth right away.
Old 2nd May 2018, 14:31   #3077  |  Link
ChaosKing
Seems it only happens if mvtools-sf is in the filter chain.
Edit:
Is there a way (hack) to avoid this problem without modifying mvtools? I mean except putting it outside of FrameEval, bcs it's very slow and I need it only for many short scenes.
I will report this bug to feisty2 but who knows when and if he's gonna fix it.
Search and denoise
Old 2nd May 2018, 15:31   #3078  |  Link
HolyWu
HolyWu's Avatar
Generally I don't recommend invoking filters within FrameEval unless unavoidable, because that introduces extra overhead.
PHP Code:
from vapoursynth import core
import vapoursynth
as vs
import functools
def frame_eval
(nclip):
    return
core.misc.AverageFrames(clipweights=[1] * 5)
clip core.std.BlankClip(width=720height=480format=vs.YUV420P8length=10000)
#clip = core.misc.AverageFrames(clip, weights=[1] * 5)
# I get 1014.60 fps
#clip = core.std.FrameEval(clip, functools.partial(frame_eval, clip=clip))
# I get 566.09 fps
clip.set_output()
You should assign the filtered result to a variable outside FrameEval and then pass it in via functools.partial() as additional argument if possible.
Old 2nd May 2018, 15:39   #3079  |  Link
ChaosKing
PHP Code:
import vapoursynth
as vs
import functools
def frame_eval
(nclip):
    return
# I get 1014.60 fps
# I get 566.09 fps
clip.set_output()
Why didn't I think of that... it works perfectly.
Search and denoise
Old 2nd May 2018, 16:24   #3080  |  Link
HolyWu
HolyWu's Avatar
Sorry, the above sample was invalid. Because one called FrameEval but the other didn't, the comparison was not under fair condition. So here is another proper sample.
PHP Code:
import vapoursynth
as vs
import functools
def frame_eval1
(nfclip):
    if
f.props['_Combed']:
        return
core.std.BoxBlur(clip)
    else:
        return
clip
def frame_eval2
(nfblurredorig):
    if
f.props['_Combed']:
        return
blurred
else:
        return
orig
blank
core.std.BlankClip(width=720height=480format=vs.YUV420P8length=5000)
non_combed core.std.SetFrameProp(blankprop='_Combed'intval=0)
combed core.std.SetFrameProp(blankprop='_Combed'intval=1)
clip core.std.Interleave([non_combedcombed])
#clip = core.std.FrameEval(clip, eval=functools.partial(frame_eval1, clip=clip), prop_src=clip)
# I get 1033.63 fps
#clip = core.std.FrameEval(clip, eval=functools.partial(frame_eval2, blurred=core.std.BoxBlur(clip), orig=clip), prop_src=clip)
# I get 3073.43 fps
clip.set_output()
speed, vaporware, vapoursynth
