29th December 2008, 02:51 | #7581 | Link |
Hello madshi and forum members,
I've been away for awhile but am now back to archiving my movie collection. However, I have a problem. I tried to decode the 7.1 DTS-HD audio of the Blu-Ray disc "The Golden Compass" and received an error message about the Arcsoft decoder. I ran eac3to -test and received the dreaded "Arcsoft DTS decoder does not seem to be installed". I have the LATEST purchased (non-trial) version of Total Media Theater (v 2.1.6.128) and my version of the dtsdecoderdll.dll is 1.1.0.0. I've read about some issues with the Arcsoft decoder and eac3to (on page 267 and 268 of this thread) but found no solutions. I am running on Windows Vista 32 and i am using eac3to version 2.84. Can you (or anyone else) offer any help? Thanks The_Keymaker Last edited by The_Keymaker; 29th December 2008 at 03:35. |
29th December 2008, 03:42 | #7582 | Link | |
Chumbo |
29th December 2008, 04:40 | #7583 | Link |
Hello Chumbo! Good to see you here.
I re-read the older posts and found the solution. I had to add the the following to my path statement: C:\Program Files\Common Files\ArcSoft\Bin However, since this issue is prevalent and the solution arcane, I would humbly suggest madshi make note of it in his fist post. Regards, The_Keymaker |
29th December 2008, 10:02 | #7584 | Link | |||||||
Your opinion? Quote:
29th December 2008, 10:47 | #7585 | Link |
We use tsmuxer to build the streams back together again at the end. I've tried to automate this as best I can here:
http://forum.slysoft.com/showthread.php?t=24388 but it would be super if (in the absence of direct .m2ts & .ts support) that you could find a way to dynamically build the meta file based on: Chapter List Video Type Audio Type & Language Thanks, Mike. Last edited by mrr19121970; 29th December 2008 at 10:49. |
29th December 2008, 11:24 | #7586 | Link | |
29th December 2008, 12:05 | #7587 | Link |
yes, for me it's quite simple. my command line is generally:
eac3to q:\ 1) 2: video.* 3: english.ac3 4: german.ac3 i was thinking of some sort of scraping script, but at the moment i can live as is. |
29th December 2008, 13:49 | #7588 | Link | |
29th December 2008, 15:45 | #7589 | Link |
Hello madshi,
My main backup server is nearly Identical (file and program locations) to my workstation but when i run eac3to -test it tells me Surcode, MKVtoolNix and Arcsoft don't seem to be installed. It tells me Arcsoft isn't installed even after I modified my Path environment variable. Can you tell me how eac3to checks for the presence of these programs so I can modify my Path environment and directories so eac3to can find them? Thanks! The_Keymaker |
29th December 2008, 15:59 | #7590 | Link |
Subtitle-Bug in 2.85 ?
There ist a bug in 2.85 obviously: look at subtitle 19, the bolded lines
E:\..\EAC3TO>eac3to j: 3: oc3.vc1 4: oc3_eng.ac3 6: oc3_deu.ac3 19: oc3.sup EVO, 1 video track, 4 audio tracks, 12 subtitle tracks, 2:02:09 "Feature Presentation" 1: Joined EVO file 2: Chapters, 34 chapters without names 3: VC-1, 1080p24 /1.001 (16:9) with pulldown flags 4: E-AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 5: E-AC3, French, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 6: E-AC3, German, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 7: E-AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB "Commentary" 8: Subtitle, English 9: Subtitle, French 10: Subtitle, German 11: Subtitle, German, "SDH" 12: Subtitle, Dutch, "Dutch" 13: Subtitle, Danish, "Danish" 14: Subtitle, Finnish, "Finnish" 15: Subtitle, Norwegian, "Norwegian" 16: Subtitle, Swedish, "Swedish" 17: Subtitle, English, "Forced" 18: Subtitle, French, "Forced" 19: Subtitle, German, "Forced" Track 8 is used for destination file "oc3.sup". [a04] The Nero decoder doesn't seem to work, will use libav instead. [a06] The Nero decoder doesn't seem to work, will use libav instead. [v03] Extracting video track number 3... [v03] Removing VC-1 pulldown... [a06] Extracting audio track number 6... [a04] Extracting audio track number 4... [a04] Removing E-AC3 dialog normalization... [a04] Decoding with libav/ffmpeg... [a04] Remapping channels... [a04] Encoding AC3 <640kbps> with libAften... [a06] Removing E-AC3 dialog normalization... [a06] Decoding with libav/ffmpeg... [a06] Remapping channels... [a06] Encoding AC3 <640kbps> with libAften... [v03] Creating file "oc3.vc1"... [a04] Creating file "oc3_eng.ac3"... [a06] Creating file "oc3_deu.ac3"... [s08] Extracting subtitle track number 8... [s08] Creating file "19oc3.sup"... |
29th December 2008, 16:09 | #7591 | Link |
A little progress...
For Arcsoft, I had to add the following to the environment path: C:\Program Files\Common Files\ArcSoft\Bin AND Manually register filters AsAudio.ax, AsAudioHD.ax and AsAudioEffectHD. The_Keymaker |
29th December 2008, 17:11 | #7592 | Link |
@madshi
regarding silence edit/insertion - I agree, these insert points should be short and at 'quiet' moments - I've only ever had to use such a feature when the audio has been b0rked, e.g. by a bad TV commercial edit or some other error/glitch I happened to hear from Tebasuna51 about this and it was mentioned that to insert silence requires lots of individual samples at all different rates and encoding types to have 'at hand' for use by the tool, so it wasn't straightforward, whereas looping merely requires duplicating what is already there, so I think it would be a bit of an effort to do for now - I guess delaycut can do the job, it was just a "nice to have included in eac3to" option in my way of thinking - if it could all be automated in the one tool (and eac3to is rapidly becoming the swiss-army-knife of all tools!) thanks for giving it some attention anyway - bottom line is I use it quite infrequently and can use delaycut instead! |
29th December 2008, 17:17 | #7593 | Link | ||
The_Keymaker: I've been having the same issue as you - surcode, mkvtoolnix and arcsoft aren't being recognized by eac3to. madshi offered this advice in an earlier post if you happened to miss it:
29th December 2008, 17:54 | #7594 | Link | |||
Search for "environment path" on google. |
29th December 2008, 18:43 | #7595 | Link |
@madshi,
sorry for any confusion - I only meant to convey that I use it *very* infrequently and I can't think of a compelling reason to add it into eac3to vs. using delaycut/other - except my own laziness (which I freely admit was my main reason for proposing it) in having to use 2+ tools instead of 1 :-) ...others who may be interested in this facility may want to add their 2 cents if they want it for specific reasons looping is perhaps not as good as silence insertion in long edits where you have to otherwise loop so many packets as to end up looping preceding/following non-silent packets in the insert, but like I said, this is only useful if the audio is quite badly b0rked and is therefore a very infrequent occurrence... (specifically, I was playing around with a broken TV episode yesterday which needed a +200ms adjustment at one point, and the eac3to edit looping thing just didn't avoid repeating audible stuff around the gap - in the end I used Audition to insert silence at the exact (short but already silent) point in the stereo signal and took the 'lossy' hit and reencoded the ABR mp3) so there it is - I am but one user of your fabulous free product, so I leave it to others to add their voices as to if they think it would be something really worthwhile and why thanks! m |
29th December 2008, 19:05 | #7596 | Link |
Can we find a specific edit size where looping stops being useful? E.g. everything smaller than 1 second: Looping. Everything larger than 1 second: Silence? I'm asking because I'm trying to avoid adding another option. Every additional option makes using eac3to more complicated. But if there's no specific edit size we can agree on, then maybe adding an option for silence is necessary...
29th December 2008, 19:55 | #7597 | Link |
One of the the guys here:
http://forum.slysoft.com/showthread....122#post159122 is wanting to convert DTS-Express. there is nothing about it on page #1 here, so I just tried it. It doesn't work with libav/ffmpeg. i was wondering if this was by design ? regards. mike. |
29th December 2008, 20:22 | #7598 | Link | |
PATH=C:\Program Files\Common Files\ArcSoft\Bin ? |
29th December 2008, 20:44 | #7599 | Link | |
Highlight the Path Variable and click the edit button, at the end of the others items in the path, add ;C:\Program Files\Common Files\ArcSoft\Bin the semicolon(; ) separates the other directories in the path |
30th December 2008, 03:47 | #7600 | Link |
ThanKs to Wolfbane, chumbo and madshi eac3to can recognize all the necessary filters. Now I have two questions.
1. I can decode and playback a demuxed DTS-HD audio track using Zoom Player and the Arcsoft AudioDecoderHD directshow filter. My question is, can I remux this audio track into MKV with demuxed video? Does MKVtoolNix support this? If this is possible, then there is no need to decode this track into FLAC to get lossless audio during playback. 2. When playing back the DTS-HD audio track using Zoom Player, the ArcSoft directshow filter seems to default to 2 channel and I have to pull up the filter's properties and select 5.1 or 7.1 channels. Is there a way to automatically enable this filter to output 5.1 or 7.1 as default? Thanks in advance. The_Keymaker |
eac3to |
