29th October 2008, 19:45 | #6801 | Link |
This is a SkyHD broadcast and I heard from other people that eac3to might have problems with these 'new' ac3 tracks from sky. so is this really only a broken track or are there also other newer sky caps which caused problems?
thats what I was refering to, I was using wavepad. but is the beginning of the ac3 track, for example the same tone or note, exactly the same beginning of a flac track as well? as it was said, flac has a higher quality/bitrate so this 'more' must be manifested somewhere in the graph? |
29th October 2008, 20:32 | #6802 | Link | |
Location: The Great North (the better half of North America)
Hope this helps. |
29th October 2008, 21:02 | #6804 | Link | |
I hope madshi can find the bug in eac3to, then I am more than happy This is also the only file which has failed so far btw... |
29th October 2008, 21:56 | #6806 | Link | |
30th October 2008, 01:59 | #6807 | Link | ||
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 31st October 2008 at 11:26. |
30th October 2008, 08:13 | #6809 | Link | |
30th October 2008, 09:07 | #6810 | Link | |
Maybe its the phase shift in dts es matrix track and arcsoft cant handle 6.1 output in this case? I will test it when im at home. That would explain why some dts es matrix tracks can be decoded with arcsoft -7 and some other dts not (with a crash) |
30th October 2008, 11:01 | #6811 | Link |
Hi all, maybe a dumb question.. i have a BluRay with a Dolby trueHD track i want to extract.. i've read a lot here but still im confused on what to do..
Should i extract the THD to flac and then convert the flac to ac3 640? or should i extract the thd+ac3 and just use the ac3? Any suggestions will be more than appreciated Anac |
30th October 2008, 17:03 | #6813 | Link |
Caped Crusader
Read the last part of Madshi's post.
http://forum.doom9.org/showthread.ph...99#post1207099 |
30th October 2008, 19:27 | #6814 | Link |
[a02] This track is not clean. Processing aborted.
[a02] Please clean the track with delaycut and then retry eac3to. Aborted at file position 16853820240. madshi, can you add a switch to ignore or skip over these types of errors. The only time I ever get them is with Blu-rays, and that message doesn't occur until the VERY end of the file. The error reported above is actually the very last byte of the entire file (total size: 16,853,820,240 bytes) If the error could be skipped over I doubt it would affect the playback sync. |
30th October 2008, 21:18 | #6815 | Link |
IIRC, the answer given for this question was "don't worry", but worry I will...
When I demuxed a BD, the PCM "remapped" channels. When I convert the PCM, it says "oh, this from a bd" and again it "remapped" channels. So, under which cup is the walnut? I thought the first remap was from bd format to a standard windows format, and moved channels around. So, afterwards, they shouldn't have to be moved around again. I think the channels are now in the wrong location. ??? |
30th October 2008, 21:51 | #6816 | Link | |
30th October 2008, 23:14 | #6817 | Link |
[a04] The ArcSoft decoder doesn't seem to work, will use Sonic instead.
[a04] The Sonic Audio Decoder doesn't decode the XXCh channel extension.. It's a 7.1 DTS-HD HR track. I don't want to install Arcsoft so I'll stick with Surcode. The resulting flac is 5.1, what happened to the 2 extra rears, were they dropped or mixed into the surrounds? Last edited by bmnot; 31st October 2008 at 02:00. |
31st October 2008, 07:52 | #6818 | Link | |
31st October 2008, 13:45 | #6819 | Link | |
- When make 'Ls Cs Rs 5.1 ES' (ES 3/3.1 matrix) or 'Ls Cs Rs 6.1 ES' (ES 3/3.1 discrete) the option 'phase shift' is available and default to 'yes' (with a standard 'Ls Rs' 5.1 we can't select 'phase shift') - If 'phase shift' is selected the input channels Ls Rs are modified to: Ls' = +45º phase shift Ls Rs' = -45º phase shift Rs - The mix with Cs is (or LS',Rs'): Ls'' = Ls + 0.707 x Cs Rs'' = Rs + 0.707 x Cs - I always have a crash when decode a ES matrix with -7 (sorry ACrowley I can't confirm your post, the phase shift don't modify this behaviour for me)
1st November 2008, 21:43 | #6820 | Link |
madshi,
Just wanted to drop by and to acknowledge once more the amazing work you're doing with eac3to [and also to others who are also contributing!]. The ever-growing feature list is amazing and I regularly come back to the program for all sorts of things. Thanks a million, frenchglen |
eac3to |
