21st September 2013, 22:57 | #21 | Link |
v1.13, 21 Sept 2013
Fixed ini read/write for JOIN_FILES and EXECUTABLE. Changed default Timeout to 300 seconds See first post. @Minister I took a copy of your zip, although as I cannot support, it will not go on MediaFire. You are welcome to put it in a new thread, I'll help where I can. Alternatively, you could create an attachment in this thread, replace the existing Adrive link if you like. @ All It is possible that there will be a new version DGIndex Batcher soon, am currently playing with possibility of inserting text from DGIndex Information window into the created AVS file. eg source template Code:
# Standard DGIndex Infos VideoFileName = "__vid__" AudioFileName = "__aud__" AudioDelay = Value("__del__") # DGIndex_Batcher Infos DGI_Field_Order = "__Field_Order__" DGI_Stream_Type = "__Stream_Type__" DGI_Profile = "__Profile__" DGI_Frame_Size = "__Frame_Size__" DGI_Display_Size= "__Display_Size__" DGI_Aspect_Ratio= "__Aspect_Ratio__" DGI_Frame_Rate = "__Frame_Rate__" DGI_Video_Type = "__Video_Type__" DGI_Sequence = "__Sequence__" DGI_Frame_Struct= "__Frame_Struct__" DGI_Frame_Type = "__Frame_Type__" DGI_Colorimetry = "__Colorimetry__" DGI_Frame_Rpts = "__Frame_Rpts__" DGI_Field_Rpts = "__Field_Rpts__" return colorbars Code:
# Standard DGIndex Infos VideoFileName = "C:\T\PAL_I_Top_43_P-Cabaret.d2v" AudioFileName = "C:\T\PAL_I_Top_43_P-Cabaret T80 2_0ch 224Kbps DELAY -48ms.ac3" AudioDelay = Value("-0.048") # DGIndex_Batcher Infos DGI_Field_Order = "Top" DGI_Stream_Type = "MPEG2 Program" DGI_Profile = "main@main" DGI_Frame_Size = "720x576" DGI_Display_Size= "720x576" DGI_Aspect_Ratio= "4:3 [2]" DGI_Frame_Rate = "25.000000 fps" DGI_Video_Type = "PAL" DGI_Sequence = "Field/Frame" DGI_Frame_Struct= "Frame" DGI_Frame_Type = "Interlaced" DGI_Colorimetry = "BT.470-2 B,G" DGI_Frame_Rpts = "0" DGI_Field_Rpts = "0" return colorbars
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st September 2013 at 23:02. |
21st September 2013, 23:22 | #22 | Link |
I tried uploading it to here, but unfortunately its a little too large, even when compressed at max settings.
For now I'll leave it active on Adrive. Maybe I will make a thread for it sometime soon as you suggested so others could find it more easily. |
21st September 2013, 23:27 | #23 | Link |
You could just attach the script file.
22nd September 2013, 15:31 | #25 | Link |
Minister's attachment is missing the Common\BatchFunctions.au3 file, can be gotten from either
DGIndexBatcher or MeGUI_AutoEncodeBatcher zips. EDIT: You would need AutoIt to either run the Minister Script under interpreter and best also get SciITe4AutoIt (also available from AutoIt site), it is a better IDE and editor. To compile into an independent executable just click on 'Build' on the Tools menu (just a single click, much easier than using the menu 'Compile' option).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 25th September 2013 at 09:55. |
25th September 2013, 03:12 | #26 | Link |
DGIndex Batcher v1.14, see 1st post.
additional doc (GUI setting) Code:
v1.14, 'Insert Infos' insert some stuff from DGIndex Information Window into AVS template file. (See AVS File) "Correct Illegal Field Transition", causes batcher to give automatic (EDIT: Yes answer, otherwise No) answer to such a dialog box. Any File causing any out of ordinary behaviour, will be sent to the "SaveDirectory\PROBLEM\" folder (AVS) and will NOT be sent to MeGUI Auto Encode Batcher if using that utility. Code:
# Standard DGIndex Infos VideoFileName = "__vid__" AudioFileName = "__aud__" AudioDelay = Value("__del__") # DGIndex_Batcher Infos # Stuff from DGIndex Information Window will be inserted into below '__stuff__' insertion markers. DGI_Field_Order = "__Field_Order__" DGI_Stream_Type = "__Stream_Type__" DGI_Profile = "__Profile__" DGI_Frame_Size = "__Frame_Size__" DGI_Display_Size= "__Display_Size__" DGI_Aspect_Ratio= "__Aspect_Ratio__" DGI_Frame_Rate = "__Frame_Rate__" DGI_Video_Type = "__Video_Type__" DGI_Sequence = "__Sequence__" DGI_Frame_Struct= "__Frame_Struct__" DGI_Frame_Type = "__Frame_Type__" DGI_Colorimetry = "__Colorimetry__" Vid = Mpeg2Source(VideoFileName) Aud = NicAC3Source(AudioFileName,Channels=2) # In some cases ac3, but use 3 letter extension to determine type. AudioDub(Vid,Aud) DelayAudio(AudioDelay) S= \ "Field Order = " + DGI_Field_Order + "\n" + \ "Stream Type = " + DGI_Stream_Type + "\n" + \ "Profile = " + DGI_Profile + "\n" + \ "Frame Size = " + DGI_Frame_Size + "\n" + \ "Display Size = " + DGI_Display_Size + "\n" + \ "Aspect Ratio = " + DGI_Aspect_Ratio + "\n" + \ "Frame Rate = " + DGI_Frame_Rate + "\n" + \ "Video Type = " + DGI_Video_Type + "\n" + \ "Sequence = " + DGI_Sequence + "\n" + \ "Frame Struct = " + DGI_Frame_Struct + "\n" + \ "Colorimetry = " + DGI_Colorimetry SubTitle(S,lsp=0,font="Courier New") Return Last. Trim (100,-500) Code:
# Standard DGIndex Infos VideoFileName = "C:\T\PAL-P_169_P-AeonFlux.d2v" AudioFileName = "C:\T\PAL-P_169_P-AeonFlux T80 3_2ch 448Kbps DELAY -280ms.ac3" AudioDelay = Value("-0.280") # DGIndex_Batcher Infos DGI_Field_Order = "Top" DGI_Stream_Type = "MPEG2 Program" DGI_Profile = "main@main" DGI_Frame_Size = "720x576" DGI_Display_Size= "720x576" DGI_Aspect_Ratio= "16:9 [3]" DGI_Frame_Rate = "25.000000 fps" DGI_Video_Type = "PAL" DGI_Sequence = "Field/Frame" DGI_Frame_Struct= "Frame" DGI_Frame_Type = "Progressive" DGI_Colorimetry = "BT.470-2 B,G" Vid = Mpeg2Source(VideoFileName) Aud = NicAC3Source(AudioFileName,Channels=2) AudioDub(Vid,Aud) DelayAudio(AudioDelay) S= \ "Field Order = " + DGI_Field_Order + "\n" + \ "Stream Type = " + DGI_Stream_Type + "\n" + \ "Profile = " + DGI_Profile + "\n" + \ "Frame Size = " + DGI_Frame_Size + "\n" + \ "Display Size = " + DGI_Display_Size + "\n" + \ "Aspect Ratio = " + DGI_Aspect_Ratio + "\n" + \ "Frame Rate = " + DGI_Frame_Rate + "\n" + \ "Video Type = " + DGI_Video_Type + "\n" + \ "Sequence = " + DGI_Sequence + "\n" + \ "Frame Struct = " + DGI_Frame_Struct + "\n" + \ "Colorimetry = " + DGI_Colorimetry SubTitle(S,lsp=0,font="Courier New") Return Last. Trim (100,-500) EDIT: The above, "DGI_Field_Order = 'Top'" is gotten from a few second Preview in DGIndex as it is not available in the Indexing Information Window (and may well be wrong if a Field Order Transition dialog box is issued). EDIT: Tested on 60 ~350MB ffmpeg VOB cuts, Indexed in DGIndex Batcher, and auto sent through MeGUI AutoEncode Batcher, and on to MeGUI with all 60 VOB's converted to mp4 automatically (EDIT: Only 500 frames trim mp4'ed per VOB).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 25th September 2013 at 10:25. |
23rd February 2015, 13:42 | #27 | Link |
New version v1.15, see 1st post.
2nd June 2015, 01:37 | #28 | Link |
New Version v1.16, See 1st post.
v1.16, 02 June 2015. Allow some special characters in filenames eg '#!+'.
6th February 2016, 12:34 | #29 | Link |
DGIndex Batcher v1.17, Re-compile with AutoIt v3.3.14.2, see 1st post.
17th April 2018, 15:03 | #30 | Link |
DGIndex Batcher v1.18, Re-compile with AutoIt v3.3.14.5, see 1st post.
18th January 2021, 14:43 | #31 | Link |
First: great tool! I've been using it, frequently, for years.
I just tried using the new version of DGMPGDec v2.0.00 (placed in the DGIndex folder ). However, DGIndex Batcher freezes during the second preview scan. Is it worth pursuing this further, i.e.; does the new DGMPGDec v2.0.00 give significantly better performance than the 1.5.8 with DGIndex Batcher? Last edited by Danette; 18th January 2021 at 15:54. |
18th January 2021, 16:57 | #33 | Link | |
also, since BlindPP is part of it, the update added HBD to it?
See My Avisynth Stuff |
18th January 2021, 18:10 | #35 | Link | |||
Useful n00b
* Speed-optimized DGIndex (32-bit). * 64-bit DGDecode that supports Avisynth2.6/Avisynth+/Vapoursynth in a single DLL. Quote:
18th January 2021, 18:56 | #36 | Link | |
I just try register in your forum but didn't get an email
See My Avisynth Stuff Last edited by real.finder; 18th January 2021 at 19:01. |
18th January 2021, 19:04 | #37 | Link |
Useful n00b
Must be your spam blocker. Several people successfully registered in the last few days. Anyway, I manually activated your account and will send the password to you by PM. Your history earns you immediate Moose Approved status.
Please make a new thread in the DGMPGDec subforum. Thank you. I also recommend subscribing to the Binaries Update Notification Thread. Last edited by videoh; 18th January 2021 at 19:29. |
18th January 2021, 21:42 | #38 | Link | |
Danette,
Bit busy at the moment, I'll try get around to it either tomorrow or Wednesday, probably something reasonably simple to deal with [need mod and re-compile]. . @VH, Quote:
I'm guessin' that I just have to make a few changes that will continue to work on old version and also new [hopefully]. Is probably something to do with change in button index or text on button or something like that. [Vista swapped around button index's on FileSelector, so that index of OK and CANCEL were swapped over, we happily clicked on CANCEL all of the time maybe in different ie MeGUI Batcher, or possible DGIndex batcher, not sure, maybe both]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 18th January 2021 at 21:50. |
batcher, dgindex |
