Old 16th September 2012, 02:57   #1  |  Link
Foofaraw
Sox Pal->Ntsc conversion?
I was looking to convert a PAL sound to NTSC, and it was suggested I use Sox, and I found this snippet:
sox in.wav output.wav speed 0.95904
And that sounds right, except the output file grows in duration, which is not what I want.
So I'm guessing I should use the -pitch argument instead - however I have no idea what value is the correction one - anybody know what it should be?
Foofaraw is offline   Reply With Quote
Old 16th September 2012, 18:31   #2  |  Link
Selur
Selur's Avatar
It's unclear what you want, if you have a video stream and you do a 'slow down' from 25fps to 24fps the duration changes, so should the duration of your audio if it is ment to stay synch.
Since you do not seem to want to change the audio length it is unclear what you want sox to do with your audio stream,...
Old 16th September 2012, 18:55   #3  |  Link
sneaker_ger
According to his post in the eac3to thread he really just wants to change the pitch. PAL speedup results in a pitch change of 70.67 cents, but I'm not 100% sure if you can just use -70.67 for the pitch parameter to reverse the effect - maybe someone else can explain.
Though I support Selur's suggestion to slowdown both video and audio to get the original playback speed and pitch. This can be done losslessly for video.
Old 16th September 2012, 19:46   #4  |  Link
Foofaraw
As I wrote, I want to change the audio from the PAL speed to the NTSC speed.
Hi sneaker_ger.
I didn't want to touch the video because I thought that would mean re-encoding, plus it would take 5000% longer than just processing the audio.
But you are saying one can do this losslessly for video?
Didn't know that.
As for using -70.67 I'll try that as soon as I have finished my pizza
Old 17th September 2012, 01:17   #5  |  Link
Foofaraw
Well, it seems to accept -70.67 but it doesn't sound quite slow enough.
And sneaker_ger based on your suggestion of video, I tried putting video and audio in an mkv, and change the video playback speed - it did appear to be in sync - though the subtitles were now out of step. If I have to OCR them and resync it becomes a bigger job :-/
Oh well.
Old 17th September 2012, 06:12   #6  |  Link
sneaker_ger
OCR is not necessary. You can change the subtitle speed in mkvmerge GUI as well, by selecting the subtitle track and entering the following in the "Stretch by" field:
25 -> 23.976: 25025/24000
25 -> 24.000: 25/24
23.976 -> 25: 24000/25025
24.000 -> 25: 24/25
I hope I got the numbers correct. Otherwise you could also re-time the subtitles with programs like BDSup2Sub.
Old 18th September 2012, 01:27   #7  |  Link
Foofaraw
25 -> 23.976: 25001/24000
25 -> 24.000: 25/24
23.976 -> 25: 24000/25001
24.000 -> 25: 24/25
Curious, I tried adding that to the field, but the resulting mkv now displays its duration as one third of the original length!
(and doesn't play)
Hm..
Old 18th September 2012, 07:13   #8  |  Link
sneaker_ger
Stretching a single track should in no way change the duration of the complete file by a third. Re-check and make sure that you're stretching the correct tracks.
Old 19th September 2012, 02:18   #9  |  Link
Foofaraw
I would assume it only stretches the subtitle track not the video?
Anyway, in mkvmerge I click on a S_VOBSUB track (I only keep one), chose the "Format Specific options" and enter something like "24000/1001" in the "Stretch by" field - and that produces an mkv with a wildly different playback length.
Old 19th September 2012, 20:42   #10  |  Link
Asmodian
25001/24000 not 24000/1001
Old 20th September 2012, 00:01   #11  |  Link
Foofaraw
The numbers make no sense to me. Could you explain how you arrived at 25001/24000?
Its much better, but not quite right, by the end it has drifted by about 4 seconds.
Old 20th September 2012, 01:14   #12  |  Link
Asmodian
I just copied what sneaker_ger stated. Are you going to 24000/1001 or 24 fps?
I assume it is just the ratio you want them slowed by.
[START FPS] = [END FPS] * X
Old 20th September 2012, 01:38   #13  |  Link
Foofaraw
Source was originally 25. In Mkvmerge I set the FPS for the video track to 24000/1001 (which then matches the new audio)
Using "25001/24000" as you suggested (sorry Sneaker_ger I'm getting confused over these numbers) on the subtitle track, means it starts out well enough in sync, but it drift over time, showing up too late.
Old 20th September 2012, 01:52   #14  |  Link
Asmodian
Hmm, well 25 / (24000/1001) = 25025/24000 not 25001/24000 so that is probably it.
Old 20th September 2012, 01:59   #15  |  Link
Foofaraw
I tried actually calculating it.
25001/24000=1.041708333333333
Whereas
25/23.976=1.042709376042709
So not the same. I tried using 1.042709376042709 instead and that worked Now the subs didn't drift.
This is black magic
Old 20th September 2012, 02:07   #16  |  Link
Asmodian
It really isn't black magic, sneaker_ger just forgot to multiply the 1 during 1001*25.
1.0427083333333333333333333333333 is more correct.
Old 20th September 2012, 04:31   #17  |  Link
Foofaraw
How many decimals will it take?
Old 20th September 2012, 06:48   #18  |  Link
Asmodian
Just use 25025/24000 or 1001/960.
But your 25/23.976 is only 3.6 ms slow every hour so you might not need to worry about it.
Old 20th September 2012, 15:11   #19  |  Link
Foofaraw
sounds good
Old 24th September 2012, 12:05   #20  |  Link
sneaker_ger
Ah, yes, Asmodian is correct, of course. I did forget the 1...
I corrected my post.
And you can put those fractions directly into the field, no need to calculate them to a float.
convert, ntsc, pal, sox
