20th December 2017, 04:33 | #47841 | Link |
To use full range with the JVC 9900 change the "Input Signal" option "Input Level" to "Enhanced".
Or keep using limited range.
madVR options explained |
20th December 2017, 04:38 | #47842 | Link |
Not to beat that dead horse to death, but, I thought we determined if you need to use limited it was better to have:
madvr: limited gpu: full tv: limited ......right?
20th December 2017, 04:42 | #47843 | Link |
True, but then the rest of Windows is the wrong range.
Having madVR set to full and the GPU set to limited allows everything to be the correct range but at the expense of the GPU drivers compressing madVR's output so you lose the quality dithering and don't have a 1:1 playback chain.
20th December 2017, 04:53 | #47844 | Link |
Right. And in my case, I can do full:full:full EXCEPT when doing 3D. I get horrible ghosting when I have it set like that so I have to do limited:full:limited for everything to work. As for the rest of Windows, oh well in my case. LOL The PC is 99% for HTPC duty anyway. For others that may present a problem for sure.
20th December 2017, 06:11 | #47845 | Link | |
1080p120 input (which I might want to use for fast video games [where image quality is bad to begin with or much less relevant than aiming precision] and/or old movies with software BFI) looks terribly soft (almost like it's 720p) in the PC / ISF modes (PC mode is needed to achieve 4:4:4 chroma and low lag for games) and even though PC / Technicolor looks fine (and similarly flexible to calibrate for this 1080p120 mode which is unique in several ways, so needs it's own calibration settings) there is no way to achieve 2x2 "nearest neighbor" upscaling (which would be nice for games). I don't think it's hard to realize that running additional sharpening on a previously softened image can never be the same (neither in terms of "purity/honesty", nor "raw quality") as simply skipping both. And even if you are willing to make a little sacrifice, I couldn't really find any sharpness/enhancer/superres settings which look "right" to me. When these are presents, I always see the fuzzy/noisy artifacts and/or find the result way too "soft" still. So, I avoid feeding it with <2160p unless 120Hz seems to be important (for example, if I want to play a little bit CS:GO). Last edited by janos666; 20th December 2017 at 06:15. |
20th December 2017, 09:35 | #47846 | Link | |
Do you really watch movies with that script? I thought BFI was only really useful for video games? 24 fps film is already a bit blurry by nature in action scenes, but content I think BFI could be useful with in madVR is 50/60 fps sport with a lot of quick unpredictable action, at which sample-and-hold panels aren't that good (not as bad as with video games, but still). Do all Panasonic OLEDs have that feature? I need to see that by myself in a shop.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
20th December 2017, 10:36 | #47847 | Link | |
Also, of course you would want to avoid a double black frame to ever appear in succession, not sure why you would make a script where this would even be possible to happen in the first place, /me shrugs.
20th December 2017, 12:10 | #47848 | Link |
Before I paste a wall of text with the details of what I'm using, I should ask is anyone having an issue with MadVR, a black screen, and a BSOD that says 'irql_not_less_or_equal' when trying to play content in exclusive fullscreen ?
20th December 2017, 12:39 | #47850 | Link | |
AMD or NVIDIA? WIN 10 creators? |
20th December 2017, 17:25 | #47851 | Link | |
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
20th December 2017, 18:13 | #47854 | Link |
Great news!
And yes, no change in 388.71.
20th December 2017, 18:52 | #47856 | Link | |
(But sometimes they appear a week or two before the new branch lands for Windows.) |
20th December 2017, 20:52 | #47858 | Link |
Thanks Madshi, that's great news for HDR. Do you know if they also fixed the bit depth issue with a custom res (not possible to select 12bits when a custom res is selected) in any driver after 385.28? 12bits can be applied if you switch to a standard frame rate, but it's greyed out with the 23p custom res (displayed as 24p in the nVidia panel). This is one of the reasons why I'm still with 385.28, as it's the last version that fully works.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
20th December 2017, 21:52 | #47859 | Link | |
I've only been using W10 for two months since I just built a new system, and the iso was build 1709 which contains the creators update. I'm also using a GTX 1080 Removing FSE ? |
