Old 19th April 2019, 23:28   #16881  |  Link
Viper714
Use Process Hacker or Process Explorer to check if EncodingServer.exe is not being blocked by other program.
https://forum.doom9.org/showthread.p...06#post1862506
Atak,
I've downloaded both apps and for the life of me can't figure out how to check what is blocking the encoding server.exe. I am positing a screenshot of both the app and taskmanager in order to get some help on this.
Thanks
[IMG][/IMG]
Viper714 is offline   Reply With Quote
Old 20th April 2019, 09:54   #16882  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
check if EncodingServer.exe shows up in safe mode.
Old 21st April 2019, 20:07   #16883  |  Link
Viper714
Atak,
So based on your suggestion, The encoding server did indeed run in safe mode. With that said, I decided to turn off all of my "startup" programs in task manager and turn them on a few at a time to find the culprit.
It was not "Everything" as I though it may have been, but a program called "Logitech Gaming Framework." Talk about weird!! No sure how that would interfere. I do have a Logitech Gaming keyboard and Flight sticks. I am going to have to remember to disable this program from starting when I am going to encode movies.
Is there anything that I can provide you to possibly prevent this block from happening. I would be more than happy to provide it.
Thanks for pointing me in the right direction.
Old 21st April 2019, 20:32   #16884  |  Link
Atak_Snajpera
Maybe you could contact logitech support and ask them why they inject to other process and thereby block it? This not a normal behaviour in my book... People behind "everything" seem to fix this because it was doing the same thing in the past according to other user.
Old 22nd April 2019, 14:03   #16885  |  Link
Viper714
Okay, will do. I have a feeling that it is going to take them a while, but I will definitely contact them. I agree with your view. Thanks!!!
Old 22nd April 2019, 17:09   #16886  |  Link
FuzzyNutz
VC-1 Issues
Ripbot is outputting videos with occasional blocky-digital artifacts when the source is VC-1. I get the same result whether ffdshow's video decoder is set to wmv9 or Intel QuickSync.
FuzzyNutz is offline   Reply With Quote
Old 23rd April 2019, 17:18   #16887  |  Link
Ryushin
Ryushin's Avatar
I've found this problem as well. Please see:
https://forum.doom9.org/showpost.php...ostcount=16747
https://forum.doom9.org/showpost.php...ostcount=16631
The recent versions of Ripbot264 fixed the decoding issue though, but does not seems frame accurate.
VC-1 sources are just a pain to deal with.
Ryushin is offline   Reply With Quote
Old 23rd April 2019, 17:54   #16888  |  Link
Atak_Snajpera
Works fine for your recently uploaded sample. Chunks are correctly stitched.
Old 23rd April 2019, 19:30   #16889  |  Link
Ryushin
Ryushin's Avatar
Then perhaps it has something to do with AviSynth, FFDShow, or Haali Media Splitter that is installed the same way on all four machines. What versions are you recommending?
Old 24th April 2019, 11:29   #16890  |  Link
Atak_Snajpera
How do you know that you have issues with frame accurate seeking? Can you again upload sample showing issues at stitching? I assume you are referring to DE mode...
Old 24th April 2019, 11:44   #16891  |  Link
sneaker_ger
I thought you were using ffms2? ffdshow and Haali shouldn't matter, then.
Old 24th April 2019, 12:06   #16892  |  Link
Ryushin
Ryushin's Avatar
Not sure if I'm understanding or not. The link is posted included two encodings along with the times corruption occurred. The DE showed issues at multiple minute marks.
Old 24th April 2019, 13:12   #16893  |  Link
Atak_Snajpera
well I was under impression that you still have issues even with latest update. Like I said latest version works fine with your uploaded sample.
Old 24th April 2019, 13:41   #16894  |  Link
Ryushin
Ryushin's Avatar
I'll have it check for updates and run it again. Thanks Atak.
Old 24th April 2019, 15:37   #16895  |  Link
duffbeer
All this talk of VC-1 problems has me worried. I've encoded dozens of VC-1 sources recently and I haven't got time to watch all of them.
I've watched a few and so far I've seen no issues but I've got at least 20 more to do and I'm worried that they may encode with errors that I won't see for a little while until I get time to watch them again.
What's the real issue here? Is it just with DE or not?
duffbeer is offline   Reply With Quote
Old 24th April 2019, 16:26   #16896  |  Link
Atak_Snajpera
Mainly in DE mode at stitching points (at 1:00 , 2:00 , 3:00 and so on).
My advise is to encode one movie and then check if you see any corrupted frames at above marks. If everything is ok then you are good to go with rest of your vc1 library.
Old 24th April 2019, 16:41   #16897  |  Link
duffbeer
Thanks Atak. I don't use DE at all so I'm hoping it won't affect me. I've watched a couple recently and didn't see any problems at all and I've never had problems with VC-1 in the past either so I'm not sure where the current issues have come from all of a sudden.
Old 24th April 2019, 18:20   #16898  |  Link
archiel
DE and VM
After adding a Hyper-V VM to my PC I can no longer use Distributed Encloding. Hyper-V adds vEthernet(Default Switch) - used for NAT between the VM and the Network - and assigns a 172.17.x.x/28 address, which changes on each reboot and with only NAT connectivity - Connected to unknown network no traffic. The standard PC IP address in this case 10.55.63.115 is assigned to the vEthernet (External Virtual Switch) Hyper-V Virtual Ethernet Adapter #2.
In the Distributed Encoding tab, the IP address for both Client and Servers are set to 10:55.63.115, but the servers always start-up using the 172.17.x.x address. As a result the servers are seen as Offline. Setting the Client and Server IPs to the 172.17.x.x brings them online, but the NAT only connectivity means that there is still no usable connection.
The servers show ADAPTER0:172.17.x.x and ADAPTER1:10.55.63.115, but only connect to ADAPTER0.
Is there a way to run in Distributed Mode without shutting down the VM?
n.b. I am using DE as it is easier to manage the CPU workload this way rather than manually disabling cores from Task Manager.
archiel is offline   Reply With Quote
Old 24th April 2019, 18:56   #16899  |  Link
Atak_Snajpera
Could you post some screenshots to help me visualize your issue?
Old 24th April 2019, 20:22   #16900  |  Link
archiel
ipconfig gives
connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #2
Physical Address. . . . . . . . . : 1C-87-2C-42-1F-38
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2a02:c7f:c038:e300:84cc:9e40:3222:143(Preferred)
Temporary IPv6 Address. . . . . . : 2a02:c7f:c038:e300:7957:24f0:84c9:85f7(Preferred)
Link-local IPv6 Address . . . . . : fe80::84cc:9e40:3222:143%8(Preferred)
IPv4 Address. . . . . . . . . . . : 10.55.63.115(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 18 April 2019 11:26:20
Lease Expires . . . . . . . . . . : 19 April 2019 11:26:24
Default Gateway . . . . . . . . . : fe80::ae9e:17ff:fe45:26f8%8
10.55.63.1
DHCP Server . . . . . . . . . . . : 10.55.63.1
DHCPv6 IAID . . . . . . . . . . . : 320636716
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-BF-CB-2C-1C-87-2C-42-1F-38
DNS Servers . . . . . . . . . . . : 2a02:c7f:c038:e300::1
10.55.63.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter vEthernet (Default Switch):
Connection-specific DNS Suffix . :
Physical Address. . . . . . . . . : AE-15-4A-FF-42-27
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::358c:6941:5f5e:a048%19(Preferred)
IPv4 Address. . . . . . . . . . . : 172.17.2.225(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.240
DHCPv6 IAID . . . . . . . . . . . : 330175818
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
