Old 23rd May 2010, 17:53   #1  |  Link
Gavino
Avisynth language lover
U and V ranges for valid RGB
Following a conversation with WorBry about the U and V ranges which correspond to valid RGB, I have put together this script which shows, for each value of Y, the valid ranges of U and V (in itself an interesting exercise in the use of MaskTools expressions ).
# Demonstration of valid YUV values, showing (for both TV ranges and PC ranges):
# - ranges of U and V for each possible value of Y;
# - ranges of Y and V for each possible value of U;
# - ranges of Y and U for each possible value of V.
# Requires MaskTools v2
# Support function.
# Given MaskTools expressions for Y, U, and V,
# returns expression which yields 255 for valid RGB and 0 for invalid.
function ValidRGB(string y, string u, string v, bool "pcRange") {
  pcRange = Default(pcRange, false)
  # Normalise Y to [0,1] and U, V to [-1,+1]:
  y = pcRange ? y+" 255 /" : y+" 16 - 219 /"
  u = pcRange ? u+" 128 / 1 -" : u+" 16 - 112 / 1 -"
  v = pcRange ? v+" 128 / 1 -" : v+" 16 - 112 / 1 -"
  # Rec 601 coefficients:
  Kr = " 0.299"  Kg = " 0.587"  Kb = " 0.114"
  Kr1 = " 1"+Kr+" -"  Kb1 = " 1"+Kb+" -"
  # From http://avisynth.org/mediawiki/Color_conversions:
  # R = Y + V*(1-Kr)
  # G = Y - U*(1-Kb)*Kb/Kg - V*(1-Kr)*Kr/Kg
  # B = Y + U*(1-Kb)
  r = y + v + Kr1 + " * +"
  g = y + u + Kb1 + Kb + Kg + " / * * -" + v + Kr1 + Kr + Kg + " / * * -"
  b = y + u + Kb1 + " * +"
  lwb = " 0 >="
  upb = " 1 <="
  and = " &"
  good = r+lwb+r+upb+and+g+lwb+and+g+upb+and+b+lwb+and+b+upb+and
  return good+" 255 0 ?"
function PlotYUV(clip c, string y, string u, string v, bool "pcRange") {
  plot = c.mt_lutspa(yexpr=y, uexpr=u, vexpr=v, U=3, V=3)
  mask = c.mt_lutspa(expr=ValidRGB(y, u, v, pcRange), U=3, V=3)
  c.mt_merge(plot, mask, U=3, V=3)
function PlotUV(clip c, int yIn, bool "pcRange") {
  # Plot valid U and V for given Y
  title = "UV plot    V ^-> U     "+(pcRange?"PC":"TV")+" Range\nY = "+string(yIn)
  y = " " + string(yIn)
  u = " x 256 *"
  v = " 1 y - 256 *"
  c.PlotYUV(y, u, v, pcRange)
  pcRange ? NOP : LetterBox(16, 16, 16, 16, color_gray)
  Histogram("levels")
  StackVertical(last, BlankClip(last, height=4, color=color_gray10),
  \             BlankClip(last, height=44).Subtitle(title, lsp=0))
function PlotYU(clip c, int vIn, bool "pcRange") {
  # Plot valid Y and U for given V
  title = "YU plot    Y ^-> U     "+(pcRange?"PC":"TV")+" Range\nV = "+string(vIn)
  y = " 1 y - 255 *"
  u = " x 256 *"
  v = " " + string(vIn)
  pcRange ? NOP : LetterBox(20, 16, 16, 16, color_gray)
  Histogram("levels")
function PlotYV(clip c, int uIn, bool "pcRange") {
  # Plot valid Y and V for given U
  title = "YV plot    Y ^-> V     "+(pcRange?"PC":"TV")+" Range\nU = "+string(uIn)
  y = " 1 y - 255 *"
  u = " " + string(uIn)
  v = " x 256 *"
  Histogram("levels")
b = BlankClip(256, 256, 256, pixel_type="YV12")
b1 = b.Trim(16, 235)
b2 = b.Trim(16, 240)
bpc = b.ColorYUV(levels="TV->PC")
tv = Animate(b1, 0, 219, "PlotUV", 16, 235)
     \ + Animate(b2, 0, 224, "PlotYU", 16, 240)
     \ + Animate(b2, 0, 224, "PlotYV", 16, 240)
pc = Animate(bpc, 0, 255, "PlotUV", 0, true, 255, true)
     \ +  Animate(bpc, 0, 255, "PlotYU", 0, true, 255, true)
     \ +  Animate(bpc, 0, 255, "PlotYV", 0, true, 255, true)
return tv.ConvertToRGB32() + pc.ConvertToRGB32("PC.601")
The top-left 256x256 area shows the UV-plane, with invalid values replaced by black.
It shows strikingly that most of the YUV space is in fact unused (ie does not correspond to a valid RGB color), especially for low and high values of Y, and that for no value of Y is the entire range of U or V valid.
For Y=0 or Y=255 of course, it shrinks to a single point (black or white) with U=V=128.
None of this is a problem, of course - it's just the way it works, but it might surprise some people. And it's something to be aware of when generating YUV values from scratch, such as when creating YUV color gradients, the topic of WorBry's post. An 'invalid' YUV value will produce clipping to 0 or 255 on one or more colors when converted to RGB.
Edit: Script extended to add YU and YV plots, and to show plots for both TV range and PC range.
Some selected examples (orig script):
Last edited by Gavino; 27th May 2010 at 11:21. Reason: extended to add YU and YV plots, and for both TV range and PC range
Old 24th May 2010, 05:40   #2  |  Link
WorBry
Thanks for that. Very interesting......and revealing.
Originally Posted by Gavino View Post
It shows strikingly that most of the YUV space is in fact unused (ie does not correspond to a valid RGB color), especially for low and high values of Y, and that for no value of Y is the entire range of U or V valid.For Y=0 or Y=255 of course, it shrinks to a single point (black or white) with U=V=128.
I'd reached a similar conclusion looking at U and V spectra with a superimposed greyscale gradient i.e. (using my 'round-about' script):
colorbars().converttoyv12().mt_lutspa(relative=true,expr="x 255 *").greyscale()
GSG    =  colorbars().converttoyv12().mt_lutspa(relative=true,expr="x 256 * ").Greyscale().LanczosResize(640,640)
GSG2   =  GSG.Reduceby2()
GSGL   =  GSG.TurnLeft()
NGry2  =  GSG.mt_lut("x 128 ", y=3).Reduceby2()
UspecG =  YtoUV(GSG2, NGry2, GSGL)
VSpecG =  YtoUV(NGry2, GSG2, GSGL)
Return Interleave(USpecG, VSpecG)
Assuming you can see the 'clipping':
U Spectrum with greyscale gradient
http://www.mediafire.com/file/gjnhzq...USpec_Grad.png
V Spectrum with greyscale gradient
http://www.mediafire.com/file/dq1jnz...VSpec_Grad.png
.......But your function, with the 'invalid RGB value' mask, really nails it.
.......And it's something to be aware of when generating YUV values from scratch, such as when creating YUV color gradients, the topic of WorBry's post. An 'invalid' YUV value will produce clipping to 0 or 255 on one or more colors when converted to RGB.
With that, it would be interesting to see a composite picture for the entire (0 - 255) luma scale i.e. like the 'UV spectra-greyscale gradient' thing I did, but with the 'invalid value' mask applied.
In fact, what would be really useful is if the function could be developed to apply the analysis to 'real' YV12 image frames and map (maybe with separate color coding for U and V) those areas where the chroma values are rendered 'RGB invalid' and clipped. That would be of great practical value. I wonder how many folks, like myself, apply all manner of luma and chroma pixel transformations to their YUV videos, blissfully unaware that the resulting colors may not be faithfully reproduced in RGB display i.e. what they are seeing on the screen may not be the 'true' YUV colors. Pretty significant I think.
Nostalgia's not what it used to be
WorBry is offline   Reply With Quote
Old 24th May 2010, 06:04   #3  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Animated GIF version.
Old 24th May 2010, 06:06   #4  |  Link
WorBry
Way-Hey !!! Where's the pause button ?
Old 24th May 2010, 14:27   #5  |  Link
pbristow
pbristow's Avatar
It's built into VirtualDub.
(I've never tried loading an animated GIF straight into Vdub before. Works like a charm! )
pbristow is offline   Reply With Quote
Old 24th May 2010, 15:11   #6  |  Link
2Bdecided
Note to anyone who hasn't actually read the script:
It defaults to PC range, with TV range part commented out. However, valid YUV is always in TV range, so the default behaviour is misleading (to say the least)!
Very cool script though. Nice use of masktools!
Cheers,
David.
2Bdecided is offline   Reply With Quote
Old 24th May 2010, 15:13   #7  |  Link
WorBry
I was joking. The function script itself is animated.
Old 24th May 2010, 17:31   #8  |  Link
Gavino
Yes, the values displayed in the histograms and the subtitle are PC range, 0-255 for both luma and chroma. I left it that way because WorBry was using PC range in his work.
However, the calculation for valid/invalid RGB takes that into account, being done on normalised/scaled values in the range [0, 1] for luma and [-1, +1] for chroma. And the colors are converted with matrix PC.601 for output. So the general behaviour is exactly the same for TV range YUV, if you take the UV plot to represent the entire available range (16-240 for TV) and the displayed Y value in brackets to be the fraction of 'full-range'.
I'll have a go at both those. Watch this space.
Last edited by Gavino; 24th May 2010 at 17:45. Reason: typo (had a -1 instead of +1)
Old 27th May 2010, 11:26   #9  |  Link
Gavino
I have now extended the script in the first post to add plots of YU (for each valid V) and YV (for each valid U), and to show plots for both TV range and PC range. The TV range plots have a grey border marking the smaller overall ranges available (16-235 for luma, 16-240 for chroma).
Next job will be to create a function (as requested by Worbry) to analyse arbitrary YV12 images and map the areas with 'RGB invalid' chroma.
Examples from new script:
Old 27th May 2010, 22:07   #10  |  Link
WorBry
Once again, a very enlightening demonstration, not only of the 'RGB-invalid chroma effect', but also the psycho-visual basis of YUV color perception. I've made it my new screen-saver
Thanks for your work - looking forward to the 'applied' function
Old 29th May 2010, 05:01   #11  |  Link
WorBry
While Gavino is working on the 'applied' function, I have been thinking (ahead) about possible strategies to avoid/minimize/resolve RGB-invalid YUV values.
Came across this earlier thread on the subject
http://forum.doom9.org/showthread.ph...lack+overshoot
The cited (fairly dated) BBC paper on 'Limiting of YUV digital video signals', is interesting reading, although I cant pretend to understand all of it
http://downloads.bbc.co.uk/rd/pubs/reports/1987-22.pdf
As a general (software) strategy, the author advocates a 'constant hue' approach, whereby the luma is not touched and the U and V values are scaled back (limited) to the maximum 'valid' values having the same hue as the invalid U and V values before limiting.
Seems reasonable, although I cant see it being the optimum solution in all cases, for example, if one is dealing with an already under-saturated source (as was the case in the aforementioned thread). Also, if 'invalid' values are a result of deliberate alteration of the luma (for example, through creation of a contrast luma curve) a more logical approach might be to settle on a trade-off between desired luma effect and chroma (de)saturation. Maybe the selective saturation and hue (SelSah) function that I put together (allows saturation and hue control to be applied to a defined luma range) will be helpful in this regard (see the thread referred to in Gavino's first post) - we'll see.
Either way, I'm anticipating that the 'applied' function will prove to be a useful visualization tool for guiding such corrective measures. If it does, maybe some auto-corrective option could be incorporated in the future. I'm jumping the gun, of course. No pressure.
Old 29th May 2010, 07:50   #12  |  Link
Die*wrek*show
DefaU1tABuser
woooo! I love this.
for making that, D.S.
all of my friends and loved ones are doomed...
Die*wrek*show is offline   Reply With Quote
Old 29th May 2010, 14:27   #13  |  Link
WorBry
Also came across this, more recent, article, proposing an improved approach to the resolution of out-of-gamut YUV values:
http://sas-origin.onstreammedia.com/...r%201/Chan.pdf
I wonder if his 'in-range chroma reconstruction' model is something than could be tested with AVISynth (MaskTools maybe), although, in my minds-eye, both methods (Spill and Proportion) seem tantamount to chroma blur.
Old 29th May 2010, 23:50   #14  |  Link
Gavino
Here are two functions which can be used to test any YV12 clip for 'invalid' RGB values. See the comments for details.
# Returns a mask with 255 where YV12 clip has valid RGB and 0 elsewhere
function RGBMask(clip c, bool "pcRange") {
  c2 = c.BilinearResize(2*c.width, 2*c.height)
  return c.mt_lutxyz(c2.UToY(), c2.VToY(), ValidRGB(" x", " y", " z", pcRange))
# Shows the areas of a YV12 clip which contain 'invalid RGB';
# good pixels are replaced by 'color', default black.
function ShowBadRGB(clip c, bool "pcRange", int "color") {
  mask = c.RGBMask(pcRange)
  c.mt_merge(BlankClip(c, color=color), mask, U=3, V=3, luma=true)
Both require the ValidRGB() function from the first post.
Script loading is very slow because of the mt_lutxyz function (which has to create a lookup table with 2^24 entries).
Below I have shown the results of applying ShowBadRGB to (the equivalent of) your USpec and VSpec clips, using the following code:
BlankClip(2, 320, 320, pixel_type="YV12")
USpec = mt_lutspa(yexpr="1 y - 255 *", uexpr="x 255 *", U=3, V=-128)
VSpec = mt_lutspa(yexpr="1 y - 255 *", vexpr="x 255 *", U=-128, V=3)
Interleave(USpec, VSpec)
ShowBadRGB(pcRange=true)
return ConvertToRGB("PC.601")
In effect, the result is basically the converse of the 'valid' area plots shown earlier.
The papers you referenced look interesting, although I haven't had time to study them in detail.
The BBC one gives a fairly good explanation of the shape of the plots shown earlier.
Results from ShowBadRGB():
Old 30th May 2010, 04:17   #15  |  Link
WorBry
Excellent. As you say, very slow to load, but it gets there. Thanks so much for doing this. Now to set about doing some testing.
Old 1st June 2010, 04:54   #16  |  Link
WorBry
For testing, I'm using clips from a variety of sources, including some AVCHD camcorders (Panasonic HMC-41 and HMC-151). For compatability with the test system, they need to be converted from Rec.709 to Rec.601 and scaled for 'TV' and 'PC' ranges. Trouble is that, like many consumer/prosumer camcorders, the luma scale is effectively 16 - 255 i.e. allows 235-overshoot (super-white). Here's an example:
http://www.mediafire.com/file/qm5yti...20Original.png
(Probably not the best example, in terms of black-point, but it serves to illustrate the 235-overshoot)
The following offers a solution:
AVCSource("C:\...........Test clip.dga")
clp=last
PCY    = clp.YLevels(16, 1.0, 255, 0, 255)
UV601  = clp.ColorMatrix(mode="Rec.709->Rec.601")
PCUV   = UV601.ColorYUV(levels="TV->PC")
mt_lutxy(PCY, PCUV, y=2, u=4, v=4)
#LanczosResize(1024,576) #Resized for Histogram
#Histogram(mode="levels")
Result:
http://www.mediafire.com/file/yiqdmm...9to601toPC.png
ShowBadRGB analysis:
http://www.mediafire.com/file/xiwowt...ge%20PC601.png
But, it seems a little convoluted and I am wondering if there is a simpler, more direct solution.
Similar considerations apply for 'TV range'.
A simple ColorMatrix(mode="Rec.709->Rec.601") conversion clips the overshot luma to 235:
Result:
http://www.mediafire.com/file/dymdt4...ec709to601.png
http://www.mediafire.com/file/uzinjx...e%20Rec601.png
So, again, would it be valid (for these tests) to scale down the luma from 255 and 235 and take the chroma from Rec.709->Rec.601
clp=last
TVY    = clp.YLevels(16, 1.0, 255, 16, 235)
TVUV   = clp.ColorMatrix(mode="Rec.709->Rec.601")
mt_lutxy(TVY, TVUV, y=2, u=4, v=4)
Result:
http://www.mediafire.com/file/nxmnjb...20709to601.png
http://www.mediafire.com/file/mywkfc...e%20Rec601.png
Would appreciate advice.
Edit: Also added the results of the 'ShowBadRGB' analysis for each of the above. Interesting that the 'PC Range' and 'TV Range' (using the 255->235 downscaled clip) analyses give very similar patterns - RGB-invalid values associated with the shiny glare on the knights armour (presumably the source of the overshot luma). The straight 'Rec.709->Rec.601 converted' clip however shows more extensive 'bad-RGB', presumably due to the 235 clipping. I've started to do some tests with applied luma contrast curves. Predictably, invalid values then begin to appear on the more saturated colors e.g. the bright reds on the knights tunics, and to a lesser extent the greens.......Edit: not surprising since the rec.601 YUV values for (true) red are stated to be 81, 90, 240
Is it just me, or are the knights getting shorter?
Old 1st June 2010, 17:37   #17  |  Link
Gavino
I'm not sure your approach is valid as you seem to be mixing Rec.709 luma with Rec.601 chroma, which does not seem correct.
Assuming the input chroma is TV range (am I right to assume this?), then for TV range output, I think you want:
and for PC range, simply extend this with:
Another possibility is to extend my function to work with Rec.709 and avoid doing any colorimetry conversions at all.
A reminder in case you need it: for viewing the results of all these things, or producing screenshots, be sure to add ConvertToRGB(matrix=whatever) to your script unless you are viewing them in something that knows it is not dealing with TV-range Rec.601 input.
PS. Once a knight, always a knight; ...
Old 1st June 2010, 17:45   #18  |  Link
WorBry
clp=last
.......But, it seems a little convoluted and I am wondering if there is a simpler, more direct solution.
I guess an alternative would be to convert the Rec.601 chroma to luma and use YLevels to upscale from 16-240 -> 0-255 and then back to chroma, but again, that's rather convoluted (more rounding errors etc). I dunno, maybe I'm over-complicating matters. What is a/the 'correct' way to re-scale YUV chroma 'directly' with MaskTools ?
Old 1st June 2010, 17:58   #19  |  Link
Gavino
Not sure if your last post was in response to mine or if you missed it in passing.
Old 1st June 2010, 18:30   #20  |  Link
WorBry
Just missed it in passing.
I was wondering about that.
Ah yes, that way the luma overshoot is 'preserved' (i.e. not clipped, and then crushed in the upscale to 255). AFAIK, the ('TV') chroma range (16-240) is the same in Rec.709 and Rec.601, and I assume that these AVCHD camcorders are Rec.709 compliant.
True, especially if folks are post-processing their AVCHD videos in Rec.709 with a view to displaying on HDTV.
True, I didn't do that with the clip + histogram frame-shots. Thanks for the advice.
Yes, but the downside to medieval pageantry is having to work the knights on weekends.
