Old 4th April 2020, 22:53   #29361  |  Link
Mike-uk
Originally Posted by spotswood View Post
You did Rocky as a BD9 here https://forum.doom9.org/showthread.p...25#post1905725. Was this just a test or do you encode to BD9 as well?
ah ok cool, everyone has there preferred method
yes it was just a test as ive never encoded to that size so was just to see what file size I ended up with, I encode to BD25 keeping audio as is, as BD50 discs are horrendously expensive here ( UK ) and I only use verbatim
Mike-uk is offline   Reply With Quote
Old 5th April 2020, 00:05   #29362  |  Link
jdobbs
I understand that the audio is reencoded or the core is used for BD5/9 for either Dolby or DTS due to size restrictions. In the second log I chose to keep the DTS core which is why it's "keeping original audio". I also switched to Decoding/Frame serving: DGDecNV hoping for a different outcome, not knowing at the time what happens over 8500. If the restrictions are removed at 8500 the bitrate should increase in my way of thinking. If I'm using a custom target over 8500 there should be no restrictions, but BDRB still thinks I'm using DVD-R/+R and decreases the bitrate?
The bitrate is lower because the DTS audio is much, much larger. It has to lower the bitrate to make room for the larger audio.
Website: www.jdobbs.net
Old 5th April 2020, 00:19   #29363  |  Link
Mike-uk
AS Emulgator said in your ini you have AUTO_QUALITY=1
also you have a few other options that I don't have
ENABLE_TEST=1
AUTO_BIAS=2
AUTO_TWOPASSONLY=1
so not sure if any of thouse options are messing with it
if you did a fresh install of bdrebuilder then I guess thouse options shouldn't be there ??
heres my ini
[Options]
VERSION=0.61.0.5
ENCODER=0
MODE=0
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
TARGET_SIZE=8032
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=0
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=3
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=1
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23500
MOVIEONLY_TYPE=0
ALTCRF=23
ALT_TARGET=1024
ALT_CRF_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
PRIORITY_CLASS=1
QUICK_EXTRAS=0
MULTIPROCESS=2
Old 5th April 2020, 10:35   #29364  |  Link
Ch3vr0n
multi-process is a "testing" feature, you need to have that enable_test in there for it to work.
Ch3vr0n is offline   Reply With Quote
Old 5th April 2020, 12:16   #29365  |  Link
Mike-uk
oh ??? I don't have enable test, and I see 2 x264 prosesses with multiprosess 2 ?? also enable_test isn't listed in the hidden ops txt file ?? and even the multiprocess webpage don't mention enable_test, it just says set multiprocess to 1, 2 or 4
Old 5th April 2020, 13:42   #29366  |  Link
MrVideo
MrVideo's Avatar
Because I don't burn to disc, I save all my encodes on hard disks
So why not make MKV files instead? Then you won't have any bitrate issues.
Old 5th April 2020, 13:44   #29367  |  Link
Mike-uk
I guess he wants to preserve menues, which ovs MKV wont do
Old 5th April 2020, 23:08   #29368  |  Link
spotswood
ENABLE_TEST=1
AUTO_BIAS=2
AUTO_TWOPASSONLY=1
so not sure if any of thouse options are messing with it. if you did a fresh install of bdrebuilder then I guess thouse options shouldn't be there ??
Yes, I did a fresh install of everything, but came out with the same result (undersized BD9), so I added my preferred options back in (and came out with the same result again).
AUTO_QUALITY=1: This is not a hidden option that you add to your .ini. BDRB changes this setting when you enable/disable Auto Quality settings. 0=disabled, 1=enabled. I had Auto Quality enabled in this instance.
ENABLE_TEST=1: https://forum.doom9.org/showthread.p...77#post1526277. This enables the Movie and Menu's mode and blanking feature allowing you to remove things you don't want like special features etc. Works independently from the MULTIPROCESS setting.
AUTO_BIAS=2: This is explained here (thanks for the link jdobbs... ;^)) https://forum.doom9.org/showthread.p...51#post1449851
AUTO_TWOPASSONLY=1: This should force two-pass encoding which I prefer and should result in better picture quality. Takes a little longer but my 2700x processor doesn't mind... ;^)
MULTIPROCESS takes advantage of multi-core processors, allowing more than one instance of x264 (up to 4) when using DGDecNV or DirectshowSource which significantly speeds up the encoding process. Works independently of the ENABLE_TEST setting. See http://www.jdobbs.net/freeware/multiprocessing.html.
Actually, you don't need to add ENABLE_TEST for MULTIPROCESS to work. See above...
What Mike-uk says below... ;^)
Exactly!
Thanks for chiming in everyone. If any of my explanations/understandings are incorrect, let me know!
Last edited by spotswood; 8th April 2020 at 02:05. Reason: addl info/clarification...
spotswood is offline   Reply With Quote
Old 6th April 2020, 05:32   #29369  |  Link
spotswood
My bad! Sorry!
@spotswood
I've been looking at your log in this post. It looks like the reason your bitrate is dropping on "Rocky" is because you'd set a target size that is greater than 8500. When BD-RB sees that, it assumes you are writing to something larger than a DVD-R. So, it removes the restrictions. One of the restrictions is that large audio streams are reencoded to AC3. You'll notice that in the first log you see this:
 - [22:18:17] Processing audio tracks
   - Track 4352 (eng): Reencoding audio to AC3...
for your first encode, while you see this:
 - [19:50:51] Processing audio tracks
in your second log. The bitrate is dropping because you have your audio settings set to not reencode to AC3. When outputting to DVD-R, the audio is always reencoded because of output disc size. Setting the target above 8500 tells BD-RB you aren't using DVD-R.
OK, I've figured it out. It wasn't the audio setting set to not reencode to AC3 that was mucking things up, it was the setting to Keep HD audio for BD25 intact. I normally keep this enabled since it's overridden when encoding to BD5/9, and I don't have to remember to enable it when encoding to BD25. My problem came about when adjusting a custom target size over 8500 MB to compensate for the undersizing I was experiencing (and not understanding what happens over that). I got it now...
As you explain, at 8501 MB the BD5/9 restrictions are lifted and BDRB assumes I am writing to BD25 and keeps the DTS-MA track (or TrueHD/Atmos), rather than reencoding to AC3 like I'm used to, resulting in the very low video bitrates. So my bad everyone. Sorry for taking you on a wild goose chase. I now return you to your regular scheduled "programming".
Stay safe and healthy...
Old 8th April 2020, 00:17   #29370  |  Link
jdobbs
Yeah. The way BD-RB works with audio isn't as obvious as I wish it could be. This post goes into depth as to how BD-RB works with the different settings when outputting to DVD-R and BD-R.
Old 8th April 2020, 02:17   #29371  |  Link
spotswood
Thanks for the link. I understand AUTO_BIAS better now too. I've always used High Quality as my default, at the expense of a little more time. I normally start a job (sometimes two) right before I go to bed anyway, setting shutdown after rebuild, and it's all done in the morning. Thanks again!
Old 10th April 2020, 00:55   #29372  |  Link
AmigaFuture
AmigaFuture's Avatar
Hellraiser: Judgement
Hello,
I noticed what seems like a bug. Select the BD, then export to MKV all lossless. I've repeated this several times and the same result happens. The video is altered or...something is altered in the process. When MKV is made from ripped BD..it looks great, and smooth. After importing the MKV and that is successful I checked IMPORT directory and the resulting BD. That's where the glitch that isn't in the original shows.
There is a video glitch that is not present all the way through the movie. It's like frame are corrupted. JD, I could send you a PM with a link to 2 5MB files so you may check the differences. Audio and subs looks good.
Any thoughts? Suggestions? Shall I send you the link?
[04/09/20] BD Rebuilder v0.61.05
[15:55:49] Source:  HELLRAISER_JUDGMENT_00000
  - Input BD size: 16.38 GB
  - Approximate total content: [01:21:09.906]
  - Windows Version: 6.1 [7601]
  - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled
  - Mode: MKV, Intact Video, Intact Audio
  - Quality: Good (Fastest, BD-25+)
  - Decoding/Frame serving: X264/LAVF
  - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640
[15:55:50] PHASE ONE, Encoding
 - [15:55:50] Processing: VID_00031 (1 of 1)
 - [15:55:50] Extracting A/V streams [VID_00031]
 - [16:02:11] Reencoding video [VID_00031]
 - [16:02:11] Keeping original video (no reencode)
 - [16:02:11] Processing audio tracks
[16:02:11]PHASE ONE complete
[16:02:11]PHASE TWO - Rebuild Started
 - [16:02:11] Building ALTERNATE OUTPUT Structure
[16:10:38] - Encode and Rebuild complete
[16:10:38] JOB: HELLRAISER_JUDGMENT finished.
[16:17:59] Importing MKV: HELLRAISER_JUDGMENT
  - Collecting audio/video streams from source...
  - Building pseudo-BD source structure...
[16:29:01] Video import completed successfully.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 11th April 2020, 11:50   #29373  |  Link
Mike-uk
have you tried with another source file ?? have you tried the failing file with a different frame server ?
Old 11th April 2020, 20:36   #29374  |  Link
AmigaFuture
Yup, X264's internal LAVF and DGDecNV. Both have same results. I have used other BDs, and noticed it. I was making MKV USB HD and then decided to rerender it smaller so I was prepping for DVD-9 to use less space when I checked it. I've not "gone that route" before so I was surprised to see that. My Windows 7 Pro is also also a pretty fresh install.. I installed AviSynth 2.60 but I doubt that's it.
Update: I'll remove it and used 2.58.. That didn't help. Heh.
Old 12th April 2020, 01:59   #29375  |  Link
jdobbs
Originally Posted by AmigaFuture View Post
Hello,
I can't imagine how that could even happen. The problem is presented in the imported BD folder after importing an MKV that BD-RB created? Please send me the link -- and also post the contents of your INI so I can see if there is anything that might help identify the cause.
Old 12th April 2020, 02:56   #29376  |  Link
AmigaFuture
I'mmmmm as surprised as you! Okay, was holding on to link until you agreed.
BD to MKV. Nope.
MKV to Import - Yes.
[Options]
VERSION=0.61.0.5
ENCODER=0
MODE=3
ENCODE_QUALITY=5
ENABLE_TEST=1
FORCE_ENCODE=1
MULTIPROCESS=0
IVTC_SELECTION=1
ONEPASS_ENCODING=2
AUTO_QUALITY=0
ENABLE_BLANKING=0
QUICK_EXTRAS=0
TARGET_SIZE=8032
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=0
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AUDIO_DRC=0
DECODER=2
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
MOVIEONLY_TYPE=28
ALTCRF=23
ALT_TARGET=1024
ALT_CRF_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
[Paths]
WORKING_PATH=O:\OUTPUT\
SOURCE_PATH=O:\OUTPUT\IMPORTS\HELLRAISER_JUDGMENT\
DGIndexNV=C:\Users\User\Desktop\BD_Rebuilder\nVidia\2053\DGIndexNV.exe
DGDecNV=C:\Users\User\Desktop\BD_Rebuilder\nVidia\2053\DGDecodeNV.dll
Last edited by AmigaFuture; 12th April 2020 at 03:01. Reason: Dyslexia correction.
Old 23rd April 2020, 15:24   #29377  |  Link
musiclover
Track does not show-up in the stream window
I want to replace the audio track in 00006.m2ts from the bluray 'Script For A Jesters Tear'. But the problem is that BD_RB does not show this track in the stream window. Further problem is that this track has no stand alone playlist. It shares a playlist with 00004.m2ts, 00005.m2ts and 00007.m2ts. Only 00004.m2ts shows up in BD_RB's stream window. I tried composing the track with tsMuxer and replacing it in the STREAM directory but that did not work. How do I get 00006.m2ts to show-up in the stream window so BD_RB can work on it and I can replace the audio track?
I have 'BLANK_THRESHOLD=0' set in the .ini file but 00006.m2ts, 00005.m2ts and 00007.m2ts do not show. The files are 312, 343 and 395 Mb in size.
What do I overlook? How can I get it to work?
musiclover is offline   Reply With Quote
Old 23rd April 2020, 20:52   #29378  |  Link
CraigWally
try the following
MIN_M2TS_SIZE=0
MIN_PLAYLIST_MINS=0
CraigWally is offline   Reply With Quote
Old 24th April 2020, 09:37   #29379  |  Link
musiclover
Originally Posted by CraigWally View Post
try the following
MIN_M2TS_SIZE=0
MIN_PLAYLIST_MINS=0
Thanks CraigWally for your reaction.
But that did not work either.
Old 24th April 2020, 14:49   #29380  |  Link
Mike-uk
demux 0006.m2ts with tsmuxer, demux the file with the track you want, then remux vid from 0006 and the audio from the file you want the audio back to m2ts ??
