9th February 2011, 21:18 | #602 | Link | |
- Player Mediaportal. - FFDShow Video Decoder / Microsoft DTV Video Or other. - EVR Renderer. - Screenshot link (Audio Switcher or Not is the same). To make video appear -> Needed Seek or Pause/Play or Switch Audio Stream. (it seems related arround Audio Stream inside Lav but i'm not sure @ 100%) Sometimes it's start or start after a few second between 5 to 60. With MPC Splitter (MKV or MPEG) -> all always start Also all is always working in Graphstudio. Really hard to find why Seb. Screenshot1 Screenshot1
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
10th February 2011, 01:54 | #603 | Link | |
I think i experienced this with the mpc internal splitter. |
10th February 2011, 06:21 | #604 | Link |
Did some testing of the lavc audio decoder and again - looks like a bunch of good work that has resulted in a solid decoder. The following were played from a bunch of different test files in ACI, TS, M2TS, MKV, and MPG containers and the tracks all played well with good lipsync. The following outlines the original Audio Codec --> lavc output (as reported by Reclock). The only filters used in the test were lavf Source Filter --> ffdshow Video Decoder, lavc Audio Decoder --> madVR Video Renderer, Reclock Audio Renderer.
48KHz/16Bit AC3 --> 48KHz PCM IEEE Float 48KHz True HD --> 48KHz/24Bit PCM 48KHz/20Bit DTS --> 48KHz PCM IEEE Float 48KHz/24Bit DTSMA --> 48KHz PCM IEEE Float 96KHz/24Bit DTSMA --> 48KHz PCM IEEE Float 48KHz/16Bit PCM --> 48KHz/16Bit PCM 48KHz/24Bit PCM --> 48KHz/24Bit PCM 96KHz/24Bit PCM --> 96KHz/24Bit PCM 44.1KHz/16Bit FLAC --> 44.1KHz/16Bit PCM 48KHz/24Bit FLAC --> 48KHz/24Bit PCM 44.1KHz/16Bit MP2 --> 44.1KHz/16 Bit PCM 44.1KHz MP3 --> 44.1KHz PCM IEEE Float 48KHz/4Bit ADPCM --> 48KHz/16 Bit PCM From these results I can conclude that the lavc audio decoder is capable of outputting high bit rate (eg 96khz) and sample rate (24 bit) multi channel PCM streams. What I am unsure of is where the output is IEEE Float what internal bit depth was used AND if if the full DTS-MA was decoded or just the DTS "Core". If it is only decoding the Core (which I would expect as to my knowledge there is no open source DTS-MA decoder), can we have an option to disable this support so we can load instead the Arcsoft HD Audio decoder to handle DTS-MA? Thanks Nathan |
10th February 2011, 06:45 | #605 | Link | |
10th February 2011, 08:06 | #606 | Link | ||
I might have figured out the cause of the videos not starting. The MPC-HC splitters all have some funny code to interpolate timestamps when none exist, and i didnt implement anything like that yet. The files i tested all seem to have no proper timestamps on the first few video frames, thus causing the renderer to fail, as it doesnt know when to show them.
Going to investigate some more. Quote:
All the decoders outputting float actually decode in full 32-bit float, there is no conversion being done. Most lossy decoders actually work internally in float, its just a matter of disabling the conversion to int16 that ffmpeg has setup for all codecs. Lossless decoders (TrueHD, FLAC) decode in integer, as you can see in the output as well. Quote:
Are you sure AC3Filter didnt sneak into the playback somewhere?
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 10th February 2011 at 08:13. |
10th February 2011, 09:12 | #607 | Link | ||
Thanks Nathan |
10th February 2011, 10:59 | #609 | Link | ||
10th February 2011, 11:34 | #610 | Link | |
It's really nice, Thanks, Seb
10th February 2011, 13:50 | #611 | Link |
Not quite yet. Maybe one day i will. But video decoding is much more complex then audio decoding.
10th February 2011, 14:01 | #612 | Link | |
http://forum.doom9.org/showthread.ph...12#post1475512 |
10th February 2011, 16:32 | #613 | Link |
I managed to fix two seperate issues that caused some files not to play.
One was related to the seeking code. The seek logic preferred to seek to a keyframe, but in some files seeking to time 0 does not work when the first frame starts with a slightly different time, but ffmpeg didn't set the proper start time. This seemed to primarily affect AVI files. The second issue was treating timestamps of the value 0 as "broken" and nulling them out. Now if a file happens to start with exactly time 0 (not many do, actually), it would null this value out, and the renderer would receive an invalid time. I'll test some more samples, maybe there are more bugs in there somewhere.
10th February 2011, 17:04 | #614 | Link |
LAV DirectShow Filters 0.14
General - The project and filters have been renamed slightly for consistency LAV Splitter - The settings have been moved to a different place in the Registry. You will need to re-apply them. - Improved MPEG-TS duration calculations. - The settings will now always be properly saved and loaded. - Disabled the limit of 20 Streams per file. - Fixed two seperate issues that caused files to not start playing. LAV Audio Decoder - Property Page for Configuration and Status has been added - Dynamic Range Compression is now off by default, but configurable. - Media Type creation has been improved, fixes filter connection issues. - Processing of UINT8 Samples has been fixed. - Fixed a crash with some Audio codecs. - Fixed Channel Order for 7.1 Streams - Increased the decoders Merit - Added support for decoding QT PCM Known issues: - TrueHD in m2ts files cannot be decoded by LAV Audio when using the MPC-HC internal MPEG Splitter. (This will most likely never be fixed, the splitter is just doing it wrong). Download: 32-bit & 64-bit First off, like mentioned above: The registry key for LAVSplitter has changed. I did not bother to write some migration logic, because there is only like 3 settings. Remember to redo them if you had something specific in there. Also, the files have been renamed again for consistency, so remember to register the filters again with the included .bat files. (I should do an installer, huh) This version adds a property page for the Audio Decoder. The main purpose is to get some statistics displayed, which will hopefully help in debugging. Additionally, you can configure DRC on there. Requantization, and therefor disabling of certain output formats, has been moved to the next version. I hope most of the "does not start" issues have been resolved!
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 10th February 2011 at 17:20. |
10th February 2011, 17:42 | #616 | Link |
A small issue with the audio decoder.
It doesn't work with Expression Encoder and AC3, EE reports file type not supported. EE works fine with AC3Filter and ffdshow (except for the fact that they don't always return exatcly the same data so 2-pass encoding using AC3 as source fails).
This is a damn cool signature :) |
10th February 2011, 17:52 | #617 | Link | |
In ffdshow config, turn off every output format, except Floating Point, and see if it still connects. If it doesn't, thats it.
10th February 2011, 18:02 | #618 | Link |
Does the audio filter require ffdshow to be installed? Or am I misunderstanding something?
Also, another bug, and a rather serious one I think. There seems to be a big memory leak in the splitter for large MKVs. Expression Encoder errored out pretty fast on a big 2 hour long 1080p MKV (H.264 video, AAC audio) with an out of memory error on the very first pass (I have 8GB ram, but EE is a 32bit process I think). That does not happen with Haali's Matroska splitter (EE stays at around 400MBs)
10th February 2011, 18:03 | #619 | Link |
Thanks for the new version, nevcairiel.
A small, cosmetic bug - properties tab should read "LAV Splitter", not "LAVFSplitter". |
10th February 2011, 18:16 | #620 | Link |
Yes, thanks indeed. I guess it's LAVS and LAVAD (or LAVA?) for short now then.
All of my previously affected AVIs start normally now. Don't have any mkv/other files with the black screen issue so I'll leave the feedback on that to someone else. On another note, if you want another "rare material challenge", I do actually have a weirdly muxed mov with a black screen issue, but that is not related to the newly fixed stuff. The issue in this case is that there are several video tracks listed (mjpeg, qtrle and mpeg4), and the one selected by default by the splitter (mjpeg) doesn't seem to contain any actual video, so manually changing to the highest bit rate video track (mpeg4) shows the video. I guess one or both of those listed low bit rate video tracks are actually text (shown when this file is started with the MPC-HC splitter). Maybe the splitter can be changed to prioritize mpeg4 over mjpeg and qtrle as the default video track, or prioritize the highest bit rate video track if that makes more sense? Another issue is that all tracks, audio, video and subs seem to be listed twice by LAVS. MediaInfo only lists them once. FWIW, the header says "Compiled by Revver Inc. TMS v2.0", whatever that is. |
