21st July 2011, 18:48 | #17761 | Link | |
rev3445 fix MPEG2 files and DVD with Nvidia PureVideo Decoder. But Internal Filters: MPEG2 Video (DXVA) still can't use. Please tell me what I should do. |
21st July 2011, 20:54 | #17763 | Link |
So what exactly is the purpose of the recent MPEG2 changes?
MPC-HC 2.1.7.2 |
21st July 2011, 21:07 | #17764 | Link |
I have a problem with loading external subtitles. It's ok when the movie is stored on a local HDD.
However, I also have a router with an USB HDD connected to it and shared using SMB (the router uses OpenWRT). Whenever I open a movie from this remote HDD, no subtitle is loaded. Other players (e.g. Potplayer) loads the subtitle correctly and all files are correctly accessible from windows. I have found a similar problem (old...), but no solution: http://www.cccp-project.net/forums/i...?topic=2600.15 |
21st July 2011, 21:11 | #17765 | Link |
Is this the same issue: https://sourceforge.net/apps/trac/mpc-hc/ticket/610 ?
21st July 2011, 22:15 | #17766 | Link |
Could someone be so kind as to give me an answer to these question I've been having. I've tried searching the net but haven't found an answer. When running DXVA (through an external ffdshow's DXVA decoder which uses NV12) and applying the YV12 Chroma Upsampling shader, do I need to enable this shader as a pre-resize shader or post-resize shader or both?
I read that this shader is still needed when running an external dxva decoder on ATI hardware as it still doesn't do proper chroma upsampling. If I run the internal MPC-HC DXVA decoder then the YV12 chroma upsampling is handled correctly thus not needing to use that shader? Thanks!
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S |
22nd July 2011, 01:20 | #17767 | Link |
Guys, how about the fix ticket #1533?
Is it possible? Last edited by Silent Rain; 22nd July 2011 at 01:24. |
22nd July 2011, 05:17 | #17769 | Link |
rev3362
Add : Support DVD Menu marker with DXVA in EVR Custom and EVR Sync renderer, big thanks to judelaw. rev3363 Change : Improved cursor behavior in DVD mode. rev3369 Change : improve OSD message at File/DVD open. Fix : Zoom at open DVD + DXVA decoder. rev3378 Add : Support DVD Menu marker with DXVA in EVR. rev3380 Fix the "Prev Angle (DVD)" hotkey and add an OSD message when changing the angle using the hotkeys or the "Navigate" menu. Patch partially by judelaw. This commit fixes ticket #1509. rev3394 Change : improve normal Zoom at open DVD + DXVA decoder. Fix : Corrupt DVD playback with Microsoft DVT-DVD Video decoder after rev.3362 - Disable "Line 21 Decoder 2". rev3407 Disable DVD subtitle mixing in EVR-CP and EVR-Sync for Microsoft DTV-DVD Video Decoder rev3436 Fix : Disable multiple output pin from internal MPEG2 software decoder, it's broken normal MPG playback. Add : Missing class member in Mpeg2DecFilter, it't improve the debugging. Change : Remove submenu in "Navigate" if no multiple stream present. rev3442 Fix : DVD playback with Nvidia PureVideo Decoder. DVD? |
22nd July 2011, 06:04 | #17770 | Link | |
22nd July 2011, 15:55 | #17771 | Link | |
MPC-HC 2.1.7.2 |
22nd July 2011, 17:22 | #17773 | Link |
I have tested the samples you linked in the ticket and I cannot reproduce your problem using the internal decoder and splitter (I also tested LAVSplitter and it works too). Have you tried the latest nightly ?
22nd July 2011, 18:14 | #17774 | Link | |
On Splash PRO, PotPlayer, The KMPlayer, SPlayer and other video players all works like lightning! Problems with rewinding only in MPC-HC Last edited by Silent Rain; 22nd July 2011 at 19:00. |
22nd July 2011, 18:35 | #17776 | Link |
I just tested it. The trunk build with default codecs and splitters enabled did freeze twice on me (after a whole lot of tries). It basically pauses, until I jumped to some other part again. I couldn't get it to freeze while testing VMR-9 r., with LAVSplitter, or with modified versions of VMR-9 r. or EVR CP. (I did test those a bit less than during the first test run, though.)
development folder, containing MPC-HC experimental tester builds, pixel shaders and more: http://www.mediafire.com/?xwsoo403c53hv |
22nd July 2011, 23:11 | #17779 | Link | |
GPU: ATI HD2600XT RAM: 2 GB OS: Windows XP (SP3) I can't show you the stats as the renderer doesn't support it. |
23rd July 2011, 17:07 | #17780 | Link |
1./ I have updated to new stable build 1.5.2.3456 and i am missing shaders. Specially "Sharpen Complex" shader, which is very usefull for some anime in blurry, low resolution. How to get it back?
2./ I see that new icons are uglier than before. Why is that? You could at least fix them, because i see only 4-bit version of icons, which are very primitive and ugly. |
