Old 4th November 2007, 12:32   #121  |  Link
Anime
(i cannot find another newer muxman thread... so have to bumbp this....) sorry
hello everyone (a feedback from a poor user)
actually i had never ever seen muxman fullbody before on my monitor due to i use my actual TV, RGB input for PC
it only supports 640x480, due to my room is so small with full of DVD and stuff, i actually have no space for a new monitor unless i buy a NEW TV with higher resolution RGB input but it isn't cheap.... below image is all i can see but not touching any muxman button.....
all along my usage of muxman is CLI by subtitle creator....
thats the only way i could get it running....
because {tab} to change selection is also not working in muxman
will there be a day that...muxman have capabitly to resize for smaller resolution or making {TAB on keyboard} work (so i can tab to destination button? because i wanted to use .sst because of subtitle flickering issue but too bad subtitlecreator doesn't support it or will never.....?
http://radkongo.wordpress.com/2007/1...thout-flicker/
lastly i also like to mention if above process can be done by muxman
> "-" for same {END_TIME} -> {START_TIME} that will save alot people alot of time
thanks for making muxman.
any sugestion is welcome......
Anime is offline   Reply With Quote
Old 4th November 2007, 18:41   #122  |  Link
kumi
Straight to video
kumi's Avatar
In the meantime you can press Alt-Space + Move, and use your arrow keys to move the window past the edges of your viewable area.
kumi is offline   Reply With Quote
Old 20th January 2008, 12:15   #123  |  Link
Politiken
MuxMan
MuxMan ver. 0.15R defaults to "NTSC 720x480 MPEG-2 4:3" if using a bitmap as the videopart !
How do I change this to "PAL 720x576 MPEG-2 4:3" or "PAL 720x576 MPEG-2 16:9" ?
regards Pol
Politiken is offline   Reply With Quote
