17th August 2008, 23:11 | #1741 | Link |
A size difference of 3k? It could be that the first pass size results are simply an efficient estimate of the actual output give or take 2kbytes whereas the size reports in second pass are actual size-on-disk reports. This makes sense if you consider the I frame data size was the same in both passes. Could be an artifact caused by the decoder in the second pass. The real test is to perform the test several times with the same first pass stats and see if the 2nd-pass results are identical in all cases.
18th August 2008, 01:27 | #1742 | Link |
thanks czerro, tho I'm not quite sure I follow your logic for the discrepancy...
I will try the same 2nd pass run a couple of times by using the initial STATS file and see what the result is there. I've just updated to the newest x264 .exe and am now using the DXVA-HD-HQ profile with 2 minor mods (No DCT Decimation and No Fast Pskip both set) I don't know how the white-screen glitch happened, but I *really* hope that's not a regular occurrence! By the way, there's no ffdshow side-effects that can interfere here are there? I believe the encoding is only loading Haali & CoreAVC, but how can I be sure? |
18th August 2008, 01:47 | #1743 | Link |
Mr. Sandman
ehrr... could you please open a discussion in the AVC forum?
this issue is not related to megui, but the encoder. thanks.
18th August 2008, 01:55 | #1744 | Link |
sure thing Sharktooth - I wasn't sure myself, but it does seem to be down to x264 at this point...
fyi all, the thread is now here http://forum.doom9.org/showthread.php?p=1171658 |
18th August 2008, 12:11 | #1746 | Link |
Mr. Sandman
it is with default settings. but some settings may brake the determinism (threads > 1 for example).
18th August 2008, 16:03 | #1747 | Link |
Hi again Sharktooth...
this is probably more MeGUI related! When I updated my user-modified (basically a copy of DVXA-HD-HQ) profile to have threads=1, this does seem to have updated the profile .xml file OK, but it doesn't transfer across into the jobN.xml file (for some reason the jobN.xml file always has NbThreads set to 0). I am creating the jobs using AutoEncode. Please let me know if I'm doing something wrong here or if this is a bug. Thanks, m |
18th August 2008, 16:08 | #1748 | Link |
Mr. Sandman
did you update the profile AFTER enqueing the job?
18th August 2008, 16:22 | #1749 | Link |
no, in fact I exited MeGUI after I updated the profile to make sure the profile was updated,
then I restarted MeGUI and enqueued the 3 jobs (pass1, pass2, mux) other profile params seem to have been successfully copied to the jobs, just not NbThreads for some reason |
18th August 2008, 16:24 | #1750 | Link |
Mr. Sandman
ensure to unset "Automatically set number of threads" in the options
18th August 2008, 16:36 | #1752 | Link |
Mr. Sandman
i think we will remove that option in the next versions... or move it into the encoder settings, so to avoid this kind of problems.
19th August 2008, 07:52 | #1753 | Link |
Robert
**If you aren't seeing 100% usage while encoding, remember the problem may lie with your input. Avisynth is single-threaded (usually), and so is often the bottleneck in multicore systems. ** Doesnt Megui only accept avs input?
Also could you please explain "queue analysis pass" and "add prerendering job" I never use them as I dont know what they really do or if Im using them right. Im experimenting now with 'queue analysis pass" I looked on the wikiguide but no dice. Thanks |
19th August 2008, 09:40 | #1755 | Link |
Robert
thanks check, also when anyone updated their megui did they get string length errors.
MeGUI encountered a fatal error and may not b e able to proceed. Reason: startIndex cannot be larger than length of string. Parameter name: startIndex Source of exception: mscorlib stacktrace: at system.String.InternalSUbStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy) at MeGUI.OSInfo.GetOSServicePack() at MeGUI.MainForm.MeGui_Load(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoadEventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIngnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.Control.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Me ssage& m) at System.Windows.Forms.Control.ControlNativeWindow.WmdProc(Mess age& m) at System.Windows.Forms.Forms.NativeWindow.Callback(IntPtr hWnd,Int32 msg, IntPtr wparam, IntPtr Iparam) |
19th August 2008, 09:52 | #1757 | Link |
after updating to latest core_0_3_0_2001, the next queue job won't start, cause the when current job finish it keep a dialog pop up and ask whether you want to shut down worker?
when you click yes or no it won't continue the next job. now i move back to the previous working core 0.3.0.1020 |
19th August 2008, 12:07 | #1758 | Link |
phjbdpcrjlj2sb3h
@rkal: are you checking this FAQ? http://mewiki.project357.com/wiki/MeGUI/FAQ
19th August 2008, 12:12 | #1759 | Link | |
Mr. Sandman
