Old 5th November 2012, 11:44   #1  |  Link
freakk69
freakk69's Avatar
How to add logo using avisynth and Virtualdub
I have used this virtualdub's logo filter by http://neuron2.net/
But i see some borders when previewing it.
And the logo filter version is 1.7
Is there any one who can help me out with this.
Here is the code i have used
ConvertToRGB()
Logo(700, 0, 255, 5, 0, 0, 0, 0, "C:\Users\ram\Desktop\logoA.bmp", 0, 0, 0, 0, 0, 0, 0)
ConvertToYV12()
freakk69 is offline   Reply With Quote
Old 5th November 2012, 12:17   #2  |  Link
lisztfr9
With overlay
I would use overlay to add some logo.
Without any mask, just blend is, and adjust the opacity.
http://avisynth.org/mediawiki/Overlay
lisztfr9 is offline   Reply With Quote
Old 5th November 2012, 12:40   #3  |  Link
TheSkiller
Does your logo bitmap actually an alpha channel (transparency)?
TheSkiller is offline   Reply With Quote
Old 5th November 2012, 15:55   #4  |  Link
Mounir
Easy, photomasque is the best in my opinion:
ConverttoRGB32(matrix="rec601",interlaced=false)
LoadVirtualdubplugin("C:\Program Files (x86)\virtualdub1.9\plugins\PhotoMasque.vdf","Photomasque",1)
PhotoMasque()
converttoyv12()
Before using the mask in avisynth use it in vdub adjust the opacity, then it'll work. I recommend a white background and .bmp 24bits
download from here
Mounir is offline   Reply With Quote
add logo, avisynth, logo watermark, virtualdub
