4th July 2007, 09:30 | #2904 | Link |
Pain and suffering
Please update x264 to revision 663, this x264 revision fixes some blocking issue with certain h.264 decoders.
megui 0.2.5.1007 is on http://x264.nl |
4th July 2007, 18:37 | #2905 | Link | |
What's in a name dude !
5th July 2007, 05:17 | #2907 | Link | |
The port was mostly to see how it ran under mono, so i could report bugs and suchlike to the mono team (i'm currently interning at novell and working on mono ). So hopefully when avisynth does get finished everything will render beautifully.
Nothing to see here... |
5th July 2007, 06:26 | #2908 | Link |
little 'bug' (since latest versions) in Automatic Encoding -> Size and Bitrate:
When entering an average bitrate, filesize is calculated, but not the other way around. Iirc in older versions one could entering a file size and the resulting average bitrate was calculated and shown. Cu Selur Ps.: didn't post this in the tracker since I'm not totally sure if it really was possible in older versions and this is a bug or if it wasn't and it's a feature request. |
8th July 2007, 13:44 | #2913 | Link |
Interested Newbie
Bug?
I hope this is the right place to post this. I noticed that I can't rename the video output file in MeGUI. Regardless what filename I enter the output video is always rendered to the file suggestes by MeGUI by default.
Example: I load my file called nighty_frags.avs MeGUI inserts nighty_frags.mp4 into the output filename textbox I change this to nighty_frags_aqstrength05.mp4 but in the queue there is always nighty_frags.mp4 as output filename and the video is also rendered to that file. I'm using MeGUI 0.2.5.1007 |
15th July 2007, 02:09 | #2915 | Link |
Just curious if it would be possible to support the Logitech G15 keyboard's LCD screen in Megui? Im often times using my monitor for other tasks while encoding, and it would be great to have it display the percentage, time left etc on the LCD screen. Has anyone thought of this?
19th July 2007, 14:59 | #2916 | Link |
With 0.2.6.1001, in the AviSynth script generator,
i always get a ColorMatrix(hints=true,interlaced=true) for progressive sources. This happens when "Deinterlace: Do nothing" is selected, which is the default after analyzing a progressive source... I have to manually uncheck the Deinterlace checkbox to get rid of the interlaced=true option. Other than that, i'm pretty happy with the new 2.6.1001 version, the new worker thing is cool and seems to work fine for me :-) |
20th July 2007, 18:42 | #2917 | Link |
phjbdpcrjlj2sb3h
This thread is not for support, or for reporting bugs, or for suggesting features. This is for megui coding work!
A patch has been made available here to fix mp4box muxing: http://forum.doom9.org/showthread.ph...70#post1026270 |
29th August 2007, 20:47 | #2918 | Link |
bitrate calculator
I have invastigated the calculator, and I don't understand the given DVD sizes. eg:
- if a 1 DVD: 4586496 , - how come a 1/4 DVD : 1126400 (*4: only 4505600; which is 80896 minus KB or 79 MB minus) Is this for the file-overhead of the DVD structure? But 79 MB ? And is this DVD size for DVD+5 discs? Thanks |
30th August 2007, 13:21 | #2919 | Link |
Mr. Sandman
ask doom9. IIRC it was him to code the bitrate calc.
30th August 2007, 20:22 | #2920 | Link |
Swallowed in the Sea
Can we discuss freely the future meGUI development here or should I use my SF account ?
I played with the code during few days last week and I changed several things (mostly redesign and fixed some bugs). I need to play again with the sources though... C# is quite new for me. I plan to add Aften encoder and redesign some other parts... |
development, megui, not a help thread |
