Old 2nd December 2011, 00:55   #13681  |  Link
allright
Hi
Yes, I was aware of this, there is enough space for doing this disc, so problem must be somewhere else. I can't understand why the log is doing all the audio streams, only english and danish were selected ...
//JJ
Originally Posted by JJB View Post
Make sure you have enough space on your disc. By the size of it at "Least" 60GB or more. I'm not saying that is the problem but make sure first till Jdobbs or others can help.
Good Luck
JJ
allright is offline   Reply With Quote
Old 2nd December 2011, 01:29   #13682  |  Link
worknstiff
@ allright RE:Source: PROJ424
- Input BD size: 27,67 GB
- Approximate total content: [01:49:54.879]
My Disney Pinocchio shows up in BD_RB as:
-Source: PINOCCHIO_US_D1_BDLIVE
- Input BD size: 28.48 GB
- Approximate total content: [02:02:20.791]
- Target BD size: 23.54 GB
- Windows Version: 6.1 [7601]
Is your version preprocessed or isn't it the US version?
worknstiff is offline   Reply With Quote
Old 2nd December 2011, 01:31   #13683  |  Link
allright
Hi
Mine is Region B, Scandinavia version, no preprocessing, ripped from original with anydvd.
Regards
JJ
Good Luck
JJ
Old 2nd December 2011, 01:47   #13684  |  Link
worknstiff
Just wondering why it was diff, thanks. Mine did a full backup perfectly.
Old 2nd December 2011, 03:45   #13685  |  Link
aquanash
Ok, got it. I modified the same routine I'd used for another audio oddity and did a test (it worked). It'll be in the next release.
Awesome work! Thanks a million for all your dedication
aquanash is offline   Reply With Quote
Old 2nd December 2011, 07:45   #13686  |  Link
jfcarbel
Programmer
Bug in alternate mode?
Not sure how alternate mode should work, but here is what I wanted. Robin Hood Bluray playlist 363 is an hour long making of that is MPEG-2 stream (see mediainfo below). The 3 files in this playlist total 1.7GB. So I thought why not select other movie only playlist, then alternate mode of DVD-5. So assumed it would be no reencode since the content will fit to target. But it recoded the video and the final size of the DVD VIDEO_TS folder was 3.53GB and the audio sync was off. What happened? I thought it should not reencode.
I even tried the config setting of FORCE_NOENDCODE=1 and that had no effect either, just same result.
MediaInfo for one of the m2ts streams:
Video
Menu ID                          : 1 (0x1)
Format                           : MPEG Video
Format version                   : Version 2
Format profile                   : Main@Main
Format settings, BVOP            : Yes
Format settings, Matrix          : Default
Duration                         : 18mn 6s
Bit rate mode                    : Variable
Bit rate                         : 3 692 Kbps
Nominal bit rate                 : 9 800 Kbps
Width                            : 720 pixels
Height                           : 480 pixels
Display aspect ratio             : 16:9
Frame rate                       : 29.970 fps
Standard                         : NTSC
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Interlaced
Scan order                       : Top Field First
Bits/(Pixel*Frame)               : 0.356
Stream size                      : 478 MiB (91%)
Audio
Menu ID                          : 1 (0x1)
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Duration                         : 18mn 6s
Bit rate mode                    : Constant
Bit rate                         : 192 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Stream size                      : 24.9 MiB (5%)
Log files:
[22:55:25] BD Rebuilder v0.39.04 (beta)
  - Source:  ROBIN_HOOD
  - Input BD size: 1.78 GB
  - Approximate total content: [01:02:41.624]
  - Windows Version: 5.1 [2600]
  - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled
  - Mode: DVD-9, 720x480/576, AC3 Audio
  - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640
[22:55:25] PHASE ONE, Encoding
 - [22:55:25] Processing: VID_00364 (1 of 3)
 - [22:55:25] Extracting A/V streams [VID_00364]
 - [22:56:01] Reencoding video [VID_00364]
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 32,551 frames
   - Inverse Telecining in effect (IVTC)
   - Bitrate: 8,776 Kbs
 - [22:56:01] Reencoding: VID_00364
 - [23:04:55] Video Encode complete
 - [23:04:55] Processing audio tracks
   - Track 4352 (eng): Reencoding audio to AC3...
 - [23:05:15] Multiplexing M2TS
 - [23:05:15] Processing: VID_00365 (2 of 3)
 - [23:05:15] Extracting A/V streams [VID_00365]
 - [23:05:46] Reencoding video [VID_00365]
   - Rate/Length: 29.970fps, 52,995 frames
 - [23:05:46] Reencoding: VID_00365
 - [23:20:13] Video Encode complete
 - [23:20:13] Multiplexing M2TS
 - [23:20:13] Processing: VID_00366 (3 of 3)
 - [23:20:13] Extracting A/V streams [VID_00366]
 - [23:20:31] Reencoding video [VID_00366]
   - Rate/Length: 29.970fps, 27,190 frames
 - [23:20:31] Reencoding: VID_00366
 - [23:28:13] Video Encode complete
 - [23:28:13] Multiplexing M2TS
[23:28:13]PHASE ONE complete
[23:28:13]PHASE TWO - Rebuild Started
 - [23:28:13] Rebuilding stream 00364 [1 of 3]
 - [23:28:13] Rebuilding stream 00365 [2 of 3]
 - [23:28:13] Rebuilding stream 00366 [3 of 3]
 - [23:28:13] Building ALTERNATE OUTPUT Structure
 - [23:29:36] Converting 1 subtitles to DVD format.
 - [23:30:45] Starting MPLEX.
 - [23:32:56] Multiplexing 1 subtitles into stream.
 - [23:35:01] Building DVD File Structure.
[23:37:35] - Encode and Rebuild complete
 - WORKFILES folder removed.
[23:37:36]JOB: ROBIN_HOOD finished.
MediaInfo of the output DVD stream:
Video
Format                           : MPEG Video
Duration                         : 17mn 47s
Bit rate                         : 7 691 Kbps
Nominal bit rate                 : 8 776 Kbps
Width                            : 720 pixels
Height                           : 480 pixels
Frame rate                       : 23.976 fps
Standard                         : NTSC
Color space                      : YUV
Bit depth                        : 8 bits
Scan type                        : Progressive
Scan order                       : 2:3 Pulldown
Bits/(Pixel*Frame)               : 0.928
Stream size                      : 979 MiB (96%)
Audio
Format                           : AC-3
Duration                         : 17mn 47s
Bit rate                         : 192 Kbps
Bit depth                        : 16 bits
Stream size                      : 24.4 MiB (2%)
jfcarbel is offline   Reply With Quote
Old 2nd December 2011, 11:37   #13687  |  Link
caticl
Hi there! I'm new in this field, maybe you can help me!
I'm using the vista 32 version, and when I'm trying to open bd rebuilder, I've got this error : "component mscomctl.ocx or one of its dependencies not correctly registered: a file is missing or invalid". do you know why? or can you help me to install the missing component? or you can send me somewhere to read about this problem? thank you
caticl is offline   Reply With Quote
Old 2nd December 2011, 14:09   #13688  |  Link
Ch3vr0n
That's all been siad a few dozen times now in this thread. Go to the BDRB install folder and execute "REG_MSCOMCTL.bat" with admin priviledges.
Ch3vr0n is offline   Reply With Quote
Old 2nd December 2011, 14:16   #13689  |  Link
jdobbs
@jfcarbel
When outputting to DVD-5/9, BD-RB does no sizing checks. It assumes it always has to be reencoded (since MPEG-2 is so rare in BD features). I'll take a look at it and see if it might be feasible to do "keep original" checks.
Website: www.jdobbs.net
Old 2nd December 2011, 14:19   #13690  |  Link
jdobbs
Just to add... you do that by right clicking on "REG_MSCOMCTL.bat" and selecting "Run as Administrator".
Old 2nd December 2011, 14:29   #13691  |  Link
[SLiM]D12
@jdobbs
Quick question for ya. I've done a few Cinavia titles, and taken the DVD AC3 and just muxed into the MT2S file that BD-RB had created.
I'm now trying 30 Minutes or Less and a bit of an issue is that the main MT2S file has 2 video tracks. Whenever i mux with tSmuxer, the wrong stream shows up, even though i have not changed the order, just replaced the Cinavia infected AC3 with one from the DVD.
I know that BD-RB re-encdes and remuxes this file without incident, so could you please let me know what you think i should do to make this work? already googled for "mt2s secondary video" and "tsmuxer secondary video" to no avail.
Thanks in advance
[SLiM]
[SLiM]D12 is offline   Reply With Quote
Old 2nd December 2011, 15:24   #13692  |  Link
kenbra
help
FFDSHOW VC-1 set incorrectly: [0]
what do i do to fix this
kenbra is offline   Reply With Quote
Old 2nd December 2011, 15:30   #13693  |  Link
jdobbs
Originally Posted by [SLiM]D12 View Post
@jdobbs
Thanks in advance
Are you getting the wrong video stream, or the wrong audio stream? The selected stream is identified by its PID (packet identifier). If the wrong one is being played, that means the wrong PID is being assigned to it during the remux. Normally the stream PIDs are assigned sequentially/incrementally in the same order as they are listed (in the TSMUXER metafile). For secondary video files you have to have the ", secondary" parameter included in that video files's line so its PID starts in the correct range... I'm not sure you can do that in the GUI. But you can always cut and paste from the GUI into Notepad and add the parameter, and then run the CLI:
c:\path\to\bdrebuilder\tools\tsmuxer.exe createdmetafile.meta d:\output\path
Old 2nd December 2011, 15:46   #13694  |  Link
[SLiM]D12
Wrong video file. I'll give this a try. thanks.
[SLiM]
Old 2nd December 2011, 16:46   #13695  |  Link
jdobbs
From the first post of this thread:
1. Download and install FFDSHOW and the Haali Matroska Splitter. They are required for BD-RB to work and are free. After the install, run "Video Decoder Configuration" for FFDSHOW from the "START/Programs" menu, and make sure MPEG2 decoding is enabled. Do the same using "Audio Decoder Configuration" to ensure "Uncompressed" is set to "All Supported".
8. Recommended for Windows XP only: Download and install WMV11 from Microsoft, and set VC-1 decoding to "disabled" in FFDSHOW (allowing the WMV11 codec to be used). This seems to be the codec with the fewest problem on VC-1. For Vista or Windows 7 -- select "wmv9"
Old 2nd December 2011, 17:40   #13696  |  Link
JJB
Originally Posted by allright View Post
Hi
//JJ
Then I would suggest that it is a defective disc. Swap it for a new one.
JJB is offline   Reply With Quote
Old 2nd December 2011, 17:45   #13697  |  Link
allright
Hi
The disc is playing okay in my Pioneer stand alone player and burner, and I have no errors when ripping it?
To me it looks strange it takes all audio, when I only choose Danish and English?
Good Luck
JJ
Old 2nd December 2011, 18:34   #13698  |  Link
jdobbs
Hi
I can assure you that if it processed all the languages -- they were all selected. You may not think so -- but they were. An important note to remember is that if you resume a job, the original audio selections from the time the job was first started are used (not any changes you may have made in the interim). This is necessary to prevent wild sizing errors due to mid-stream changes. Another possibility is if the stream isn't an original and/or the stream languages aren't properly marked or are set to undetermined ("und"). In that case they are assumed to be the default language. That means they could be kept when that language was selected.
Old 2nd December 2011, 18:40   #13699  |  Link
allright
Hi
No problem, I'll rip, and start a new job, will return with the result.
Regards
JJ
Good Luck
JJ
Old 2nd December 2011, 19:30   #13700  |  Link
jfcarbel
Programmer
@jfcarbel
For catalog titles its more common then you think, they generally just port over the DVD extras content and throw its MPEG-2 into an m2ts container.
That would be a nice feature if you can add the check, then it makes it possible to create a true DVD bonus disk from the extras on Bluray.
