Old 23rd January 2017, 18:09   #1241  |  Link
GMJCZP
GMJCZP's Avatar
Thanks, I will analyze your reply, thank you very much.
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 26th February 2017, 20:07   #1242  |  Link
jones1913
random user
I've just packed a new release and wrote some lines to the wiki.
Have fun!
BeHappy Audio Transcoder > <Doom9 forum> <Gleitz forum> <GitHub>
MP4.tool GUI for MP4Box & L-SMASH muxer > https://www.mediafire.com/folder/3i6y6cbkyhblm/MP4.tool
jones1913 is offline   Reply With Quote
Old 26th February 2017, 21:41   #1243  |  Link
LigH
LigH's Avatar
I will.
New German Gleitz board
Old 27th February 2017, 00:36   #1244  |  Link
tebasuna51
tebasuna51's Avatar
Thanks jones1913.
Old 16th June 2017, 16:43   #1245  |  Link
Richard1485
Posts: n/a
Is it possible to build this nightmode downmix into BeHappy but to normalize the matrix to prevent clipping?
Originally Posted by robertcollier4 View Post
This "nightmode" preset uses the following channel matrix:
FL' = FC + 0.30*FL + 0.30*BL
FR' = FC + 0.30*FR + 0.30*BR
I'm not sure how to normalize the matrix myself. It looks as if it should be something like...
FL'= 0.2929 + 0.1875 + 0.1875
FR'= 0.2929 + 0.1875 + 0.1875
..but the total is significantly below 1.0. (I know that the total doesn't have to be exactly 1.0, but should it be this much less?)
Old 16th June 2017, 21:39   #1246  |  Link
tebasuna51
tebasuna51's Avatar
In FL' = FC + 0.30*FL + 0.30*BL
the max value is 1.6 then the normalized version is:
FL' = (1/1.6)*FC + (0.30/1.6)*FL + (0.30/1.6)*BL = 0.625*FC + 0.1875*FL + 0.1875*BL
Old 17th June 2017, 02:00   #1247  |  Link
Richard1485
Posts: n/a
Thank you! For some reason, I divided the value for FC by the wrong number. I knew something didn't look right. Would this work?
flr = GetChannel(a, 1, 2)
fcc = GetChannel(a, 3, 3)
lrc = MixAudio(flr, fcc, 0.1875, 0.625)
blr = GetChannel(a, 5, 6)
return MixAudio(lrc, blr, 1.0, 0.1875)
Old 17th June 2017, 10:52   #1248  |  Link
tebasuna51
tebasuna51's Avatar
Yes, this is the avs code for that downmix.
Old 18th June 2017, 17:19   #1249  |  Link
Richard1485
Posts: n/a
^ Thanks very much! If it would possible to build it into BeHappy at some point, that would be most useful. :-)
Old 18th June 2017, 19:51   #1250  |  Link
tebasuna51
tebasuna51's Avatar
Done.
Replace ...Behappy\extensions\d_DownMix.ext with the attached one.
You can edit d_DownMix.ext and add your mixes.
Old 18th June 2017, 19:56   #1251  |  Link
Richard1485
Posts: n/a
¡Eres muy trabajador!
Thanks for your help and hard work!
Old 29th June 2017, 22:28   #1252  |  Link
siella
siella's Avatar
I changed url ext. of dts also upmix ext. doesnt have <LoadAvsPlugin> parameter for soxfilter.
I made stereo to 2.1 (lfe) upmix dsp plugin. only dts and ac3 encode give you 2.1 audio. when you dts encode you have to choose channel conf. (L,R) and click to Add lfe channel
Thanks for your effort, jones1913
File Type: zip d_UpMixSt2.1.zip (566 Bytes, 48 views)
Behappy
BePack.v3.3BeHappy,BeSweet,BeLight,BeSplit,BeSliced,BdAC) with last plugin, encoder and extensions.
Avisynth Movie Screenshot, thumbnails creator
siella is offline   Reply With Quote
Old 30th June 2017, 12:50   #1253  |  Link
tebasuna51
tebasuna51's Avatar
Thanks, I updated the link also in Doom9 thread then the e_FFdcaenc.ext update is not necessary.
Thanks, before only work if soxfilter.dll was in autoload plugins folder.
I can't recommend use this upmix function:
l = GetLeftChannel(a)
r = GetRightChannel(a)
lfe = ConvertToMono(a).SoxFilter("lowpass 120","vol -0.5")
return MergeChannels(l,r,lfe)
Any audio player with 2.1 speakers do this job better with 2.0 input, because:
1) Make the lowpass cut (here 120 Hz) with the appropiate frecuency to the attached speakers.
2) Low frecuencies aren't eliminated from FL,FR and the audio player still extract them to subwoofer adding to LFE content.
That addition can cause a over-mix or a sub-mix if there phase shift's in the low pass sox filter.
Please don't mistake LFE channel with subwoofer speaker.
Any 2.1 audio player send to subwoofer the low frequencies present in all channels.
Is always a bad idea create a LFE channels if not present in source.
Never make 2.0 -> 2.1 or 5.0 -> 5.1
If you need 5.1 for some compatibility create a empty LFE.
Old 2nd July 2017, 23:32   #1254  |  Link
siella
siella's Avatar
thank you for information
do you recommend convert 5.1 to 2.1 with using orginal lfe channel ?
You know people doesnt use 5.1 system anymore, usually use soundbar.
Max bitrate of eac3 is variable for each sample rate so i updated eac3 ext.
Behappy
Old 3rd July 2017, 07:18   #1255  |  Link
LigH
LigH's Avatar
I am no expert in this regard ... but for movies, I would possibly keep the LFE (in case it contains extra cinematic effects), and convert the full range audio preferably with DPL-II (IMHO it sounds nice even with stereo speakers). Personal preference.
Old 3rd July 2017, 11:23   #1256  |  Link
tebasuna51
tebasuna51's Avatar
Downmix to save space disk is now not necesary at all, then the downmix is recommended to adecuate the input audio to the audio player:
1) Downmix to stereo 2.0, even with special mix prioritizing Center channel.
Recoded to AAC (or AC3 for very old players)
- To play with stereo TV's, old stereo only players or streaming.
- Is not recommended use the LFE channel in the mix (but you can try it)
2) Downmix to DPL 2.0 only recommended for old audio players without support for 5.1 input but with DPL decoder and surround speakers.
Recoded to 2.0 AC3 dpl marked.
Dolby do not recommend use the LFE channel in the mix (but you can try it)
3) Maybe a downmix 5.1 -> 2.1 for an audio system 2.1 speakers can work fine.
I never test that, but mix front and surround channels can't be bad for low frecuencies (surround channels don't have them normally).
BTW not all audio systems 2.1 have spdif input to support AC3 2.1 (or HDMI to support PCM 2.1), most of them have only 2.0 analog input and a mix 2.1 is unusable.
But I can't recommend a downmix for a soundbar than stand for a 5.1 (at least) input. Try to do their job before can be a problem, let apply their specific downmix.
Old 3rd July 2017, 17:08   #1257  |  Link
siella
siella's Avatar
Well actually i have plan making other language of movies 2.0 channels to 2.1 using lfe from 5.1 audio orginal language of movies. I have soundbar and i ll test if i find spare time
Behappy
Old 3rd July 2017, 17:38   #1258  |  Link
LigH
LigH's Avatar
Every time someone has the great idea to mix channels from different audio streams into one, I can feel Agrajag crying: "Oh no, not again!"
Old 3rd July 2017, 19:29   #1259  |  Link
siella
siella's Avatar
I think it will be fantasy
Behappy
Old 21st December 2017, 13:36   #1260  |  Link
eca2424
BeHappy
Thanks for BePack Tools sir. That is most useful for me. I will Follow the updates for BeHappy and BePack. :-)
eca2424 is offline   Reply With Quote
behappy
