14th September 2018, 12:48 | #941 | Link | |
ffmpeg-20180913-1b98bfb-win64 Code:
ffmpeg -threads 4 -i 1080.mp4 -benchmark -f null - ffmpeg version N-91943-g1b98bfb932 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 8.2.1 (GCC) 20180813 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth libavutil 56. 19.101 / 56. 19.101 libavcodec 58. 30.100 / 58. 30.100 libavformat 58. 18.100 / 58. 18.100 libavdevice 58. 4.103 / 58. 4.103 libavfilter 7. 31.100 / 7. 31.100 libswscale 5. 2.100 / 5. 2.100 libswresample 3. 2.100 / 3. 2.100 libpostproc 55. 2.100 / 55. 2.100 [libaom-av1 @ 000001e19c898940] 1.0.0-507-g5d963cb57 Stream mapping: Stream #0:0 -> #0:0 (av1 (libaom-av1) -> wrapped_avframe (native)) Press [q] to stop, [?] for help Output #0, null, to 'pipe:': Metadata: major_brand : dash minor_version : 0 compatible_brands: iso6av01mp41 encoder : Lavf58.18.100 Stream #0:0(und): Video: wrapped_avframe, yuv420p, 1920x1080, q=2-31, 200 kb/s, 29.97 fps, 29.97 tbn, 29.97 tbc (default) Metadata: creation_time : 2018-09-12T19:11:12.000000Z handler_name : ISO Media file produced by Google Inc. Created on: 09/12/2018. encoder : Lavc58.30.100 wrapped_avframe frame= 1736 fps= 19 q=-0.0 Lsize=N/A time=00:00:57.92 bitrate=N/A speed=0.637x video:909kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown bench: utime=88.703s stime=0.938s rtime=90.919s bench: maxrss=233580kB Last edited by marcomsousa; 14th September 2018 at 12:59. |
14th September 2018, 13:51 | #942 | Link |
I am maddo saientisto!
Sure, which was one of the options considered in my post. The 20180913 build with the current ffmpeg HEAD (91943-g1b98bfb932) wasn't out when I tested, so I couldn't be sure.
Still, to double performance in just about 8 days (Zeranoe aom revision: 20180906-5d963cb) is really a LOT, especially considering a lot of the commits are either bugfixes or encoding-related. Turns out the commit that really made the difference is f820da0 - Turn on the row-based multi-thread decoder by default. Code:
# time ./aomdec.850e126ac.exe --threads=4 -o /dev/null "Gus Kenworthy & Tom Wallisch X Games Slopestyle GoPro Preview.1080.ivf" real 1m0,929s user 0m0,000s sys 0m0,000s # time ./aomdec.f820da02b.exe --threads=4 -o /dev/null "Gus Kenworthy & Tom Wallisch X Games Slopestyle GoPro Preview.1080.ivf" real 0m37,947s user 0m0,000s sys 0m0,000s |
14th September 2018, 14:59 | #943 | Link |
New uploads:
AOM v1.0.0-577-g8ae39302e noVO (MSYS2; MinGW32: GCC 7.3.0 / MinGW64: GCC 8.2.0 with -fno-tree-slp-vectorize) AOM v1.0.0-577-g8ae39302e (MSYS2; MinGW32: GCC 7.3.0 / MinGW64: GCC 8.2.0) – no crash in 2-pass for me rav1e 0.1.0 (1fa32bb / 2018-09-14) (MSYS2; MinGW32: GCC 7.3.0 / MinGW64: GCC 8.2.0) Last edited by LigH; 23rd September 2018 at 17:42. |
14th September 2018, 16:12 | #944 | Link |
Artem S. Tashkinov
AV1 in MP4 has been standardized: https://cdn.rawgit.com/AOMediaCodec/...0.0/index.html
14th September 2018, 16:49 | #945 | Link |
Thanks Ligh and Smilingwolf for the builds. For some reason, Smilingwolf's build is considerably faster (finished the same encode in 40 minutes vs 67). I used your unpatched build, Ligh, and 64 bit versions. I don't know if this happens because of difference in the compiler settings, or because Smilingwolf sets CONFIG_LOWBITDEPTH=1. The outputs are identical.
14th September 2018, 20:42 | #946 | Link | |
(I would imagine that AV1 in MP4 would have better compatibility on Apple devices in the future, but I wasn't really concerned about the difference in support as so much if either of the MP4 or WebM containers are objectively "better" on a technological level than the other). |
14th September 2018, 20:52 | #947 | Link | |
14th September 2018, 20:58 | #948 | Link |
Interesting how both of our CPUs have the exact same 4c/8t configuration, yet you're seeing more than 2x the CPU utilization than I am...
Mathmatically that would mean that you're utilizing at least 5 threads, which would equal out to being something like 4 cores and 1 SMT thread. I do know that that my Nehalem predates AVX and that newer CPUs also have stronger SMT (this is particularly true with Zen cores), so I've got to wonder if something between those two variables is resulting in AV1 utilizing multiple threads much better on your Kabylake i7 than it does on my Nehalem Xeon. I mean, I know that Sky/Kaby/Coffee lake will have anywhere from 30% to 50% higher single core IPC than Nehalem, but I wouldn't think that would account for any difference in how many cores are being utilized at any given time (outside of SMT threads being used, but I'm not even seeing any utilization on my fourth hardware core let alone SMT). Last edited by Nintendo Maniac 64; 14th September 2018 at 21:11. |
14th September 2018, 21:54 | #949 | Link |
15th September 2018, 04:31 | #951 | Link |
Well then, as someone with much more expertise in audio than video, Opus not being compatible with MP4 is a big win for WebM in my book.
...unless you do streaming in the same manner that YouTube does whereby you just deliver completely independent streams for audio and video, therefore allowing you to use MP4 and WebM streams concurrently (sometimes a recently-uploaded video will have VP9 video encodes but only AAC audio encodes for whatever reason; here's an example video of such that has VP9 video yet only AAC audio as of this comment). |
15th September 2018, 07:38 | #952 | Link | |
Derek Prestegard IRL
I believe YouTube uses DASH by default on modern browsers. I know you can do fMP4 and webm via DASH but I didn't realize you could mix both in a DASH manifest, but YouTube is clearly doing this with their AV1 + Opus streams. I do imagine that YouTube's JavaScript player is quite specialized though. I wouldn't expect this to work OOTB on other DASH clients like a Roku or something like dash.js (even if the underlying audio / video decoders supported AV1 and Opus) - but then again I've never tried |
15th September 2018, 12:59 | #953 | Link | |
As for container, WebM and MKV just aren't used for mainstream commercial content or streaming outside of YouTube. MP4 has a huge and mature ecosystem that is already deployed, and there's nothing about WebM that would justify the cost of switching ALL those components to ones that support WebM. There are so many components for transport, muxing, demuxing, encryption, decryption, fragmentation, ALL of which would have to be updated for WebM to be viable. All it takes is a few legacy-but-supported devices that can't use WebM to keep an organization from even contemplating switching. And even if all the components were updated, what would switching from MP4 improve? I can't imagine any container format replacing MPEG-4 for at least a decade. If new container features are needed, they'll most likely be done as an official extension of MP4 by MPEG. |
15th September 2018, 15:27 | #955 | Link |
From what I understand, the main point of AV1 is to have a good royalty free codec. Why associate it with an audio codec that require licensing like xHE-AAC, when an equivalent royalty free codec like opus exist ?
Compatibility is not an issue, as nothing is compatible with AV1 today, so you can just add both together. |
15th September 2018, 17:50 | #956 | Link | |
xHE-AAC, Opus, HEVC and VP9 were all standarized at the same time. VP9, HEVC and Opus were adopted in many applications. xHE-AAC? Name me one functional encoder. 6 years and counting. No market for its licensing (Opus did it), awfully late and too little. xHE-AAC is dead. |
15th September 2018, 19:40 | #957 | Link | |
Or, if you are in a subway, or on airport WiFi. |
15th September 2018, 21:33 | #958 | Link |
Hey, has anyone tried decoding AV1 on a CPU that lacks AVX and seeing what the resulting CPU utilization is? (for reference, even the newest 2c/4t Coffee lake Pentiums lack AVX) I'm starting to wonder if my Xeon's under-utilization is due to the fact that my CPU completely predates AVX...
I know that a similar thing happened in the past where VP9 had some heavy optimizations for SSSE3 (I don't believe this is the case anymore) which resulted in something like a 2.5x performance gain simply by having SSSE3 support (which wasn't present on AMD CPUs until 2011). |
15th September 2018, 22:25 | #959 | Link | |
Everyone will probably end up using ffav1 anyway, so this shouldn't really matter.
https://github.com/MoSal Last edited by MoSal; 15th September 2018 at 23:14. |
15th September 2018, 22:46 | #960 | Link |
