Old 17th November 2017, 14:43   #61  |  Link
zub35
ABDO He was referring to - apply filters to remove artifacts from compressed video of my example crf=25 and upload them in a png and jpeg and compare them with the results without filters removal of artifacts.
But I think (not tested) that removing artifacts, will not allow the algorithm to recover the details. Since the compress-artifacts contains information about the original content.
The presence of an artifact indicates that this place was something else, unlike those places where artifacts are not.
zub35 is offline   Reply With Quote
Old 17th November 2017, 16:45   #62  |  Link
ABDO
i am sorry, i realy did not understand the question right.
yeah, Unfortunately i am not sure, as i not technical man or programer, but as you said the technology is extremely promising, so i think the future will bring an Improvements to it.
ABDO is offline   Reply With Quote
Old 22nd November 2017, 16:41   #63  |  Link
feisty2
I'm Siri
feisty2's Avatar
Very good, thank you! I've de-rotated/de-mirrored your images and here they are for easy comparison:
no modification - | - rotated left - | - rotated right - | - mirrored horizontally
If you compare these images, you'll see that the texture changes a lot in all 4 images, it's completely different in each frame. It still has an overall similar look to it, but the changes are still much bigger than any dithering, so in motion this will look extremely noisy/unstable.
For still images it might not matter too much, but for video this type of "texture hallucination" is IMHO currently not feasible in motion, because it is not stable when the image content changes slightly. I'm not sure if the algorithm could be changed to fix this problem. I kind of doubt it because the algo by design doesn't even try to restore the original texture (which is technically impossible, anyway), it just tries to hallucinate a texture which hopefully has a similar look to the texture the original hi-res image had before downscaling. So the algo is by design not able to maintain a stable "position" of the texture in motion.
Even worse, if you look at the very bottom of the image, the alphalt texture is changing its brightness very strongly from frame to frame, this will actually produce visible flickering in motion. That said, these brightness fluctuations should be fixable with better neural network training.
the loss function defined in SRGAN has 2 sections, content loss and adversarial loss, the content loss is defined as a perceptual loss which is a high level VGG feature loss rather than pixel loss (SAD/MSE), the adversarial loss would try to make the reconstructed image look as close to a native high res image in general as possible and probably 80% of the magic comes from this section, so this section stays put, now a different content loss function would not affect the "hi res" magic much, but would determine the level of the "richness" of details in the generated image, and here u could remove the perceptual loss function and replace it with MSE, the perceptual loss function gives rich but unstable details while MSE gives blurry but stable details, adversarial loss paired with MSE would give u a slightly blurry and stable result that still looks native high resolution in general, I guess u could try with this and see if it works out alright
feisty2 is offline   Reply With Quote
Old 22nd November 2017, 16:49   #64  |  Link
madshi
Thanks. Do you happen to know any papers/projects which do it that way? Would like to see if the resulting images look pleasing enough to make it worth spending the time.
Old 22nd November 2017, 17:31   #65  |  Link
feisty2
I'm Siri
feisty2's Avatar
page 8 of the original SRGAN paper, the author compared the results of different loss functions
SRResNet: MSE
SRGAN-MSE: adversarial loss + MSE (what I suggested)
SRGAN-VGG22: adversarial loss + lower level of perceptual loss
SRGAN-VGG54: adversarial loss + higher level of perceptual loss
Old 22nd November 2017, 17:54   #66  |  Link
madshi
Thanks, doesn't look too bad. Might be worth a try. It does seem to do some sort of texture sharpening, though. I wonder what that will do to video sources with compression artifacts...
Old 11th May 2018, 19:21   #67  |  Link
zub35
neural network in restoration old films
(rus) https://yandex.ru/blog/company/oldfilms
example: 1 2 3 4
Old 13th May 2018, 02:07   #68  |  Link
poisondeathray
example: 1 2 3 4
This is cool, thanks
Any more info on what process was used ? Some things lost in google translation too
