23rd November 2004, 19:31 | #62 | Link |
Terrific! I always thought the BeSweet GUI was a mess, anyway.
Would it be possible to to show the command line, ala the original GUI? It would be nice to be able to copy and the command line ... to show people "hey, here's how I did so and so ..." I also always wanted to be able to put my cursor in the command line box and make manual changes. Would that be possible? Of course, maybe that wouldn't so much "BeLight" as it would "BeComplicated." Nice work! -abs
The perfect browser is now completely free: Opera. Get it. Love it. |
23rd November 2004, 19:45 | #63 | Link | |
XviD User
23rd November 2004, 20:46 | #64 | Link | |
Swallowed in the Sea
@absinthe :: about your suggestion, yes as I already said before, it's on my todo list. |
23rd November 2004, 21:01 | #65 | Link | |
XviD User
24th November 2004, 00:07 | #66 | Link |
Can BeSweet downmix '2 channel mono ac3' and output mono Vorbis (and maybe HE-AAC too)? I've never been able to get this to work with existing GUI's (either the standard BeSweet GUI or Oagmachine).
The only way I've been able to get true Mono Vorbis is to demux the AC3 to WAV from the vobs with DGindex, and then use OggDropXPD, which has a setting to downmix and does produce true 1 channel output, so you really do only need 1/2 the bitrate. Every other tool I've used that can either work with demuxed AC3 or directly with VOBS can only produce Stereo, even if the source is mono but stored in 2 channel (ie the way most oldies from the 50's and 60's are). Obviously you can't implement the feature if BeSweet itself doesn't support it, but here's hoping it does and none of the GUI's before ever picked it up. Same would go for HE-AAC, although I've not investigated BeSweet's capability so far as Vorbis on that yet.
Cheers, The REAL Joe |
24th November 2004, 08:00 | #69 | Link | ||
For Vorbis output, we can't produce mono files with BeSweet. Maybe with the help of Azid options. I'll check it. Quote:
24th November 2004, 09:50 | #70 | Link | |
L.A.M.E. developer
If you do not want it to resample, you have to use --resample xxx with xxx beeing your sampling freq. |
25th November 2004, 13:37 | #71 | Link |
Nice and very complete work Kurt!!
Bravo!! I've done some compressions and the gui seems to work correctly. Only a problem during AAC conversion: i obtain the same error I had in Danni gui: 'error configuration bsn'...so I'm not able to convert in AAC trought your gui. I'm using last besweet beta 1.5b29... any suggestion? ciao!!
P6T| 12Gb DDR3| i7-920 D0@3.8Ghz@1.168v+NOCTUA NH-U12P| Liberty 620| Stacker|2xRAID0 (4x500gb) Seag.72k.11| Seag. 500gb 72k.12| Seag. 1.5Tb 72k.11| GTX470@668/1843| U2410 24"| Se7en x64 on VRapt 300gb |
25th November 2004, 17:48 | #73 | Link |
BeSweet v1.5b29 by DSPguru. -------------------------- Using Shibatch.dll v0.24 by Naoki Shibata & DSPguru (shibatch.sourceforge.net). Using bsn.dll v0.24 by DPeshev,Richard,E-Male,DSPguru (DSPguru.Doom9.org). Logging start : 11/25/04 , 17:47:48. BeSweet.exe -core( -input F:\Burner_Temp\w6.wav -output F:\Burner_Temp\w6.mp4 -logfile F:\Burner_Temp\w6.log ) -azid( ) -bsn( -2ch -vbr_streaming -aacprofile_lc ) -ota( -G 1 ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : F:\Burner_Temp\w6.wav [00:00:00:000] | Output: F:\Burner_Temp\w6.mp4 [00:00:00:000] | Floating-Point Process: No [00:00:00:000] | PostGain normalize to : 1.00 Error 84: error configuring bsn! Quiting... [00:00:00:000] Conversion Completed ! Logging ends : 11/25/04 , 17:47:48.
25th November 2004, 21:25 | #75 | Link | |
now it works perfectly nice work and many thanks!
26th November 2004, 13:47 | #76 | Link | |
26th November 2004, 13:59 | #77 | Link | |
Posts: n/a
http://www.dvd2dvd.org/ or all versions and how to extract the audio( Part 4: Audio menu)here: http://forum.doom9.org/showthread.php?s=&threadid=59272 ! |
27th November 2004, 00:14 | #78 | Link | |
0.18 is out...
Changelog Quote:
1°) There is a Settings folder now...So, the right thing can be to copy all the BeSweet folder (exe + dll) into BeLight directory. 2°) I included also the file to make the translation. Feel free to test it.. |
28th November 2004, 02:25 | #79 | Link |
Hi --
Some nice improvements in .18. Text fixed in main window, but the end of several lines of text are still missing in the advanced settings window. Main window size better now, although it's still a bit too tall for 1024x768 screens -- everything below the bottom edge of the word "Start" on the start button is cut off. You may also consider adding a "Save As" option for settings, in order to create multiple ini files containing configurations for various purposes. Best regards. |
