Old 22nd March 2012, 17:46   #12841  |  Link
DragonQ
Originally Posted by mbordas View Post
Can somebody do a little sanity check for me on this file:
https://rapidshare.com/files/2764315045/clip_0.wtv
It's a plain vanilla video recording, but regardless of whether I set deinterlacing: if in doubt activate, or automatic source detection: force film mode, I get the same result - it leaves the display in 60hz and leaves deinterlacing off. I can manually turn on deinterlacing or IVTC from the keyboard, but I can't tell if that results in a better picture. What's the preferred behavior in this case?
How does one even play that file? MPC-HC doesn't recognise it for me (using LAV Splitter).
Old 22nd March 2012, 20:19   #12842  |  Link
mbordas
you have to enable wtv in lav splitter and then set StreamBufferSource to "block" in external filters in mpc-hc options. But there's really nothing special about the file, it's just a windows tv recording.
mbordas is offline   Reply With Quote
Old 22nd March 2012, 21:05   #12843  |  Link
cyberbeing
Broadband Junkie
Originally Posted by aufkrawall View Post
AFAIR it's possible via Nvidia driver.
Forced off means off, no matter what applications want.
Even in windowed mode.
Last time I tested this on WinXP a few months back, force-off VSync only had an effect in Fullscreen exclusive mode with my NVIDIA card. I'd expect Win7 with Aero disabled function the same, but maybe not.
If it wasn't for the fact that my PC/FileServer with the NVIDIA GPU had its motherboard die last month (at the moment waiting on Ivy Bridge, since I'm being forced into a full CPU/Mobo/RAM rebuild...), I would check things out for myself and post debug logs. At the moment, I'm just curious to find out what madshi finds the underlying cause to be.
Old 22nd March 2012, 21:31   #12844  |  Link
aufkrawall
Maybe I will temporary go back to the 296 driver to test it.
But I'm pretty sure that windowed mode and Aero shouldn't matter.
The new Vsync options of the new driver can be completely turned off, btw.
Old 23rd March 2012, 01:20   #12845  |  Link
deado
Hang on, aren't you all using the 300 drivers with modified .inf files with older cards? The current 300 drivers are only designed for 680's only. Maybe this is why madVR is giving issues?
deado is offline   Reply With Quote
Old 23rd March 2012, 05:55   #12846  |  Link
TheShadowRunner
TheShadowRunner's Avatar
yes, I already asked for this...for the very same reasons as you ^^
+1
XP SP3 / Geforce 8500 / Zoom Player
TheShadowRunner is offline   Reply With Quote
Old 23rd March 2012, 13:03   #12847  |  Link
aufkrawall
If everything else is working fine, most likely not.
Nvidia has changed something and this requires either a fix by Nvidia or madshi, I'm very sure.
Old 23rd March 2012, 20:25   #12848  |  Link
Xello
Edit: I wonder is this even occurs with an actual GTX 680.
Confirmed, Black screens r us. Just got mine today, apart from this issue quite impressed with it so far
Xello is offline   Reply With Quote
Old 23rd March 2012, 23:05   #12849  |  Link
Budtz
I have bin having problems with some external subtitles displying wrong in mpc with madvr. (They work fine in vlc) The folowing is how they look in the film and when opened in notepad.
1
00:02:08,000 --> 00:02:11,200
ÒÚÐÃÎÂÑÊÈ ÂËÅÊÀ×
"ÍÎÑÒÐÎÌÎ"
2
00:02:11,300 --> 00:02:13,000
ÅÊÈÏÀÆ: ÑÅÄÅÌ ÄÓØÈ
3
00:02:13,100 --> 00:02:17,000
ÒÎÂÀÐ: ÐÀÔÈÍÅÐÈß,
ÏÐÅÁÐÀÁÎÒÂÀÙÀ 20000000 ÒÎÍÀ ÐÓÄÀ
4
00:02:17,100 --> 00:02:19,200
ÊÓÐÑ: ÂÐÚÙÀÍÅ ÍÀ ÇÅÌßÒÀ
5
00:06:57,500 --> 00:07:02,500
Äà èìàø áèñêâèòè?
- Åòî òè öàðåâè÷íà ïèòêà.
6
00:07:05,100 --> 00:07:06,800
Ñòóäåíî ìè å.
I dont know if this has anything to do with madvr. Or is it some reginal settings. how come vlc works fine?
can any1 help?
Budtz is offline   Reply With Quote
Old 23rd March 2012, 23:08   #12850  |  Link
G_M_C
Did Nv get HDMI output working as intended on the 680? I mean like
- no .inf fiddling anymore to get fullrange luma in stead of always being in TV-range,
- output frequency stable, so no more tweaking to scanlines/overscan with rivatuner to exact (or very near) 23.976xxxxx output rate ?
Cause on the HDMI output 'side of things'; AMD's cards work out of the box for me, on both video and audio (incl. high-res/lossless audio + bitstreaming). I find that up till now Nv's card are to much hassle to get just right, maybe thats changed. Hence the question.
G_M_C is offline   Reply With Quote
Old 23rd March 2012, 23:53   #12851  |  Link
Xello
Never experienced the issues you mention on the 580, and the 680 seems the same so far. They did switch from mini to full size hdmi out though, and no cable in the box this time so gonna have to order another one.
Old 24th March 2012, 00:25   #12852  |  Link
aufkrawall
I hope the fan doesn't raise when the card is in p0 state with just little load.
I wait for the Asus CUII design.
Old 24th March 2012, 01:15   #12853  |  Link
aufkrawall
With 296 driver there's only tearing in windowed mode if Vsync is forced off.
In new FSE there's no tearing.
Old 24th March 2012, 02:35   #12854  |  Link
cyberbeing
Broadband Junkie
Thanks for testing that on Win7 aufkrawall. Since you specified new FSE, was there tearing with old FSE?
I looked back in this thread, and it seems my last post on the subject was when I observed this behavior with the old FSE mode and VSync Forced-Off. The new FSE mode was always unusably slow on that GPU, so while I know I've tested the new FSE VSync behavior, it doesn't appear I made a meaningful record of it anywhere.
When you find time, could you post a madVR Debug log? Without at least that, madshi won't be able to begin troubleshooting the issue.
Could you also run madNV12Test? Even though that test is very outdated, it'd still be interesting to see the performance results on Kepler.
What language are the subtitles supposed to be? It looks like the character encoding of the subtitle file is set to a non-native ASCII encoding which is different form your regional settings. Could you upload the original subtitle file somewhere? To avoid such issue in the future, you should author your subtitles in a Unicode space such as UTF-8.
Old 24th March 2012, 02:53   #12855  |  Link
Xello
debug log:
https://rapidshare.com/files/2812914673/madVR_-_log.txt
that test:
http://pastebin.com/dF1HTFyk
cheers
Old 24th March 2012, 06:36   #12856  |  Link
Budtz
The subtitle is in english. Here it is. just remove the ".txt" extention. i tried to change the encode to utf-8 but it seems to have no effect. when i open it in a subtilte editor it is just gibberish regradles of what i change. how come vlc can read it?
Old 24th March 2012, 07:59   #12857  |  Link
cyberbeing
Broadband Junkie
It's usually quicker to upload such files to mediafire or some other file hoster. Attachments sometimes take awhile to get approved.
If it's indeed an english subtitle, it seems possible that the subtitle was saved as UTF-16 or similar without a signature, causing it to incorrectly be viewed as ASCII or UTF-8 without conversion (gibberish). I'll take a look later after the attachment is accessible. It's possible that VLC (libass) may auto-detect and correct these sorts of encoding issues.
Old 24th March 2012, 08:10   #12858  |  Link
Budtz
here is a proper link for the subtitle file
http://www.mediafire.com/?36a2ujdps51fpx6
Old 24th March 2012, 08:15   #12859  |  Link
cyberbeing
Broadband Junkie
Those were Bulgarian subtitles using Cyrillic (Windows-1251) ASCII encoding. Here they are converted to UTF-8:
http://www.mediafire.com/?memxydcxvo47jsd
Old 24th March 2012, 14:31   #12860  |  Link
Budtz
ah thx. i figured it out. the english subs were elsewere and my player was set up to use external files first.
