3rd January 2009, 16:56 | #322 | Link |
I just updated the first post of this thread to link to BD Rebuilder v0.17.13. Here are the changes:
- Corrected an error in which a source that uses LPCM input was crashing with MOVIE-ONLY mode. - Fixed a "Runtime Error 9" that could occur when a source did not have a language code set. - Added a temporary setting in the config file, example: SPECIAL_DEBUG_FILE="C:\PATHTO\DEBUG.TXT" This is meant to list all files and sizes found in the BD Source path individually in the selected output text file so I can debug incorrect sizing that has been reported. - Updated AFTEN to the most recent SVN version. - Other minor corrections and cosmetic fixes. Last edited by jdobbs; 3rd January 2009 at 17:11. |
3rd January 2009, 17:40 | #323 | Link |
Target size problem fixed
I fixed my problem with the target size problem. I made a image file with imgburn from the decrypted files and loaded that image file into deamon tools. Now the pc thinks Ì have a bluay disc inserted but this one is allready decrypted so rebuilder can work with it.
P.s my decoding speed is 0.19x I have a dual core amd 4200+. Last edited by pbeumer2001; 3rd January 2009 at 17:45. |
3rd January 2009, 18:18 | #325 | Link | |
3rd January 2009, 18:20 | #326 | Link |
No the disc was decrypted but the files were just in a folder on my desktop. Now I created an image file of those decrypted files and mounted the image file. Then anydvd asked me which region. I selected region free and everythink works fine.
3rd January 2009, 18:23 | #327 | Link |
DVD Magistrate
I tried Dark Knight....for some reason the vc1 came out garbage...nothing to see. How should ffdshow be set up for vc1? I thought I had it ok.
Also, can proggy be set so you ca nencode right away to be sure ffdshow set up ok? that is one pass encode right away? |
3rd January 2009, 18:43 | #328 | Link | |
3rd January 2009, 18:52 | #329 | Link | |
SPECIAL_DEBUG_FILE="c:\DEBUG.TXT" Then just close BD-RB, open it again, and point to the directory. It will create a file called DEBUG.TXT that will record all the files in the path and their sizes. I'd really like to see why it is doing this. The DEBUG.TXT file may be large, so please mail it to dvd-rb@dvd-rb.com Thanks. Last edited by jdobbs; 3rd January 2009 at 18:54. |
3rd January 2009, 19:04 | #330 | Link | |
will do. I`ll do it when rebuilder coompletes. 4200+ is 2.42 Ghz each core. first pass of main movie file is doing 0.33 now. |
3rd January 2009, 19:49 | #332 | Link |
"x264 r1067: Add support for SSE4a (Phenom) LZCNT instruction
Significantly speeds up coeff_last and coeff_level_run on Phenom CPUs for faster CAVLC and CABAC." I have amd phenom 9850be and my speed on 2nd pass is 0.24-0.26 on 1080p and 0.15 on 1080i I use x264 r1071 and i don`t have change on my phenom speed encoding....bd rebuilder is optimised for cpu phenom??? sorry for my english...and tks |
4th January 2009, 00:27 | #335 | Link | |
If you limit the path to 128 characters or less it will work correct. In the meantime, I will change my code to use an alternate API function. |
4th January 2009, 00:33 | #336 | Link |
finally got the first one working. Tinkerbell works on the PS3 with audio. I'll check it out fully later on. I've upgraded to latest beta and unchecked the option to "do not convert DTS/AC3" to see if that lets my encodes work in the PS3 with audio.
[SLiM] |
4th January 2009, 00:39 | #338 | Link | |
Is that Full Backup or Movie Only Mode? |
4th January 2009, 01:14 | #340 | Link | |
P.s Transformers has dolby true HD sound. What does rebuilder do with that? Does it reconvert the sound or does it simply copy the sound from the original? |
