22nd November 2010, 00:34 | #10761 | Link | |
So far I have seen DTS 6.1 content on 2 BluRay's: Lord of War Disturbia |
22nd November 2010, 01:09 | #10762 | Link | ||
I'm seeing more 6.1 and 7.1 DTS-HD MA recently: Alice in Wonderland; 6.1 Matrix, and Toy Story 3; 7.1 Discrete, come to mind. But all of the 6.1 and 7.1 DTS-HD discs I've seen, whether it was matrix or discrete, has a DTS-ES 6.1 Matrix core.
Windows 7 x64 i7 870 16GB RAM AMD 6870 Last edited by robpdotcom; 22nd November 2010 at 01:15. |
23rd November 2010, 03:04 | #10766 | Link | |
Hmm, seems I have 1.1.0.7. So, do I need to downgrade if I want 7.1 DTS-MA (correctly) converted to 5.1 LPCM?
Gorgeous, delicious, deculture! |
23rd November 2010, 04:02 | #10768 | Link |
Could someone help me with the following error - i demuxed the dts track from dvd using eac3to but converting to 24fps appears to be a challenge.
N:\RipBot264v1.16.3\Tools\eac3to>eac3to dvd-demuxed.dts eac3to-24fps.dts -29.970 -changeTo24.000 -r8brain DTS, 5.1 channels, 2:06:02, 24 bits, 1510kbps, 48kHz Decoding with ArcSoft DTS Decoder... Changing FPS from 29.970 to 24.000... Reducing depth from 64 to 32 bits... Writing WAVs... Creating file "eac3to-24fps.R.wav"... Creating file "eac3to-24fps.LFE.wav"... Creating file "eac3to-24fps.L.wav"... Creating file "eac3to-24fps.C.wav"... Creating file "eac3to-24fps.SR.wav"... Creating file "eac3to-24fps.SL.wav"... Clipping detected, a 2nd pass will be necessary. The ArcSoft DTS Decoder reported an error while decoding. Aborted at file position 290717696. N:\RipBot264v1.16.3\Tools\eac3to> Thanks in advance. |
23rd November 2010, 04:02 | #10769 | Link |
Thanks. I downgraded to 1.1.0.0 anyway, to be safe (I just have the pertinent .ax stuff installed; not the entire bloatware). If I read the reports in this thread properly, there's nothing 1.1.0.7 can do that 1.1.0.0 won't do as well.
23rd November 2010, 04:41 | #10770 | Link | |
Try also with -libav BTW, your parameters are incorrect, to convert a DTS from DVD NTSC you need: eac3to dvd-demuxed.dts eac3to-24fps.dts -23.976 -changeTo24.000
23rd November 2010, 06:06 | #10772 | Link | |
Is your source an NTSC DVD (apparently so, given VOB files and 30000/1001 fps or ~29.97fps video) and your target either a file with inverse telecined (to ~23.976fps) video or a Blu-ray disc? If so, no audio framerate conversion is necessary! In short, only do the contemplated operation (and flag the input as 23.976fps!) if you're sure that you need 24.000fps video. |
23rd November 2010, 06:33 | #10773 | Link | |
Let me summarize what I am attempting to do in layman's [my] terms - I demuxed dts audio track from a dvd [supposedly NTSC] and now attempting to re-mux it with a mkv created from BluRay source. When I muxed the dvd demuxed DTS to the mkv, I experienced gradual audio async - so more 'google' suggested I need to correct for the framerate diff? If you have any advice helping me accomplish this task, I would highly appreciate it. Last edited by sreemv; 23rd November 2010 at 10:42. |
23rd November 2010, 08:05 | #10774 | Link |
I didn't know it was possible to inverse telecine with eac3to. Is the result a progressive, 23.976fps file? And, would you mind giving me an example command line?
Windows 7 x64 i7 870 16GB RAM AMD 6870 |
23rd November 2010, 11:59 | #10775 | Link | |
Check if you have Surcode with: eac3to -test 2) Check with MediaInfo/eac3to if your mkv is exactly 24 fps and not 24000/1001 or 23.976 3) If your dts source is 768 Kb/s maybe you can add a explicit bitrate instead the default: -448 to recode to ac3 -768 to recode to dts 4-1) If your DVD is PAL (check in the cover) you need: eac3to input.dts output.ac3 -25.000 -changeTo24.000 4-2) If your DVD is NTSC you need: eac3to input.dts output.ac3 -23.976 -changeTo24.000 You need correct the audio duration, forget the video fps.
23rd November 2010, 15:42 | #10776 | Link |
I guess its just a temporary thing. already happened I think twice before that there was a rather long break in between development. maybe he just needs some time off then and when. but so far, he has always come back.
23rd November 2010, 16:27 | #10777 | Link |
I don't believe you can do that except with soft-telecined VC-1 content, where eac3to discards the pulldown flags. I was thinking about the usual Avisynth route for the video, which the OP indicated is coming from an NTSC DVD.
23rd November 2010, 16:33 | #10778 | Link | |
Caveat: If your DTS file had a delay value on the DVD, you will need to add that delay to the final Matroska file, again using MKVMergeGUI, to get the correct sync. Otherwise, your final file will have some small amount of constant desync as if you were watching the DVD without the correct audio delay added to the disc. |
23rd November 2010, 21:44 | #10780 | Link | ||||
N:\RipBot264v1.16.3\Tools\eac3to>eac3to -test eac3to (v3.24) is up to date Nero Audio Decoder (Nero 6 or older) doesn't seem to be installed http://www.nero.com/eng/store-blu-ray.html CAUTION: You need Nero 7. Nero 8 won't work with eac3to. ArcSoft DTS Decoder (1.1.0.0) works fine Sonic Audio Decoder (3.24.0.0) doesn't seem to be installed Haali Matroska Muxer (2010-05-19) is installed There's a new version (2010-11-21) available http://haali.net/mkv Nero AAC Encoder could not be located http://www.nero.com/eng/nero-aac-codec.html Copy NeroAacEnc.exe to the eac3to or to the Windows folder. Surcode DTS Encoder (1.0.29.0) is installed MkvToolnix (3.4.0.0, release version) is installed There's a new release version (4.4.0.0) available http://www.bunkus.org/videotools/mkvtoolnix There's a new beta version (4.4.0.0, 2010-11-15) available http://www.bunkus.org/videotools/mkvtoolnix/win32/pre N:\RipBot264v1.16.3\Tools\eac3to> But surcode with eac3to keeps failing and I am unable to decipher the reason: N:\RipBot264v1.16.3\Tools\eac3to>eac3to "eac3to-demux.dts" N:\24fps.dts -23.976 -changeTo24.000 -libav DTS, 5.1 channels, 2:06:02, 24 bits, 1510kbps, 48kHz Decoding with libav/ffmpeg... Changing FPS from 23.976 to 24.000... Reducing depth from 64 to 32 bits... Writing WAVs... Creating file "N:\24fps.LFE.wav"... Creating file "N:\24fps.SR.wav"... Creating file "N:\24fps.SL.wav"... Creating file "N:\24fps.C.wav"... Creating file "N:\24fps.R.wav"... Creating file "N:\24fps.L.wav"... Clipping detected, a 2nd pass will be necessary. libav ERROR: block code look-up failed libav L libav a libav s libav t ................................................ ...............................................[truncated] libav Didn't get subframe DSYNC libav ERROR: block code look-up failed [truncated] libav Didn't get subframe DSYNC Starting 2nd pass... Decoding with libav/ffmpeg... Changing FPS from 23.976 to 24.000... Reducing depth from 64 to 32 bits... Writing WAVs... Applying -12.53dB gain... Creating file "N:\24fps.R.wav"... Creating file "N:\24fps.C.wav"... Creating file "N:\24fps.SL.wav"... Creating file "N:\24fps.L.wav"... Creating file "N:\24fps.SR.wav"... Creating file "N:\24fps.LFE.wav"... libav ERROR: block code look-up failed libav L libav a libav s libav t libav m [truncated] libav Didn't get subframe DSYNC Encoding DTS <1536kbps> with Surcode... Found Surcode DTS Encoder version 1.0.29.0. Pressing the Surcode "Encode" button didn't seem to work... Closing Surcode... N:\RipBot264v1.16.3\Tools\eac3to> I checked the FAQ and amde sure there were no long path/names and yet surcode part keeps failing. As I mentioned above, surcode by itself works fine. Is there a way to save the frame converted "wavs" and use the "surcode" independently? eac3to keeps deleting them after the above failure. BTW, -libav has more success than the default - so, thanks for that! Quote:
MKV, 1 video track, 1 subtitle track, 2:11:21, 24p /1.001 1: h264/AVC, 1920x818 24p /1.001 (960:409) 2: Subtitle (SRT) N:\RipBot264v1.16.3\Tools\eac3to> Quote:
DTS, 5.1 channels, 2:06:02, 24 bits, 1510kbps, 48kHz N:\RipBot264v1.16.3\Tools\eac3to> Quote:
VOB, 1 video track, 2 audio tracks, 1 subtitle track, 0:01:53 1: MPEG2, 480i60 /1.001 (16:9) 2: AC3, 5.1 channels, 448kbps, 48kHz 3: DTS, 5.1 channels, 24 bits, 1510kbps, 48kHz 4: Subtitle (DVD) N:\RipBot264v1.16.3\Tools\eac3to> Thanks again for all the help! Last edited by sreemv; 23rd November 2010 at 21:51. |
eac3to |
