Old 5th September 2004, 22:59   #81  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
I release version 1.0 of DePan.
Since version 1.0, DePan can also use more fast FFTW library version 3 (http://www.fftw.org)
as Windows binary DLL (compiled with gcc under MinGW by Alessio Massaro),
which support for threads and have AMD K7 (3dNow!) support in addition to SSE/SSE2.
It may be downloaded from ftp://ftp.fftw.org/pub/fftw/fftw3win32mingw.zip
For fftw using, you must put FFTW3.DLL file from this package to some directory in path (for example, C:\WINNT).
Please post test (speed) report.
Old 6th September 2004, 09:09   #82  |  Link
morsa
the dumbest
WOW!!
A lot faster now on this Athlon XP machine I'm using to test it!!!
As always Fizick, THANK YOU!!
(Taste the Russian advanced knowledge )
morsa is offline   Reply With Quote
Old 9th September 2004, 15:49   #83  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
I get some e-mail from Andreas J. and decide post it here for discussion:
I trying to use DePanEstimate for scene detection & Extraction of JPEG-FIles.
As far as I have tested, It will do what I want.
I would like to do detect the scenes an extract JPEG thumbnails in one step.
My problem is, that I havent found a way to formulate the if-clause because I Havent Found a way to get the "Trust" Value or the dx-value for each frame
As I Understand your Plugin, it is currently not possible to get these values during runtime.
Is it possible to extend DePanEstimate to do this?
My Ideas for this are:
1) getting the "trust" - value as a variable during the processing of the each frames
in AviSynth a condition like
DePanEstimate.Trust < 3.5 ? ExtractKeyframe(currentFrame):nop()
(Okay, I need todo it on every frame with EvaluateFrame() or ScriptClip() but my Scripting Experiance
ist only only 10 Hours with Avisynth ;-):
2) by adding a function "DePanIsKeyFrame" with nearly the same parameters as DePanEstimate
(as far as I understand DePanEstimate SceneChange will come if myTrust-value > Trust(CurrentFrame)
3) another possibility could ba a function (DePanExtractKeyFrames (trust = 3.5, log = "c:\myfilename, KeyFramesEvery=1500, SkipMultiKeyframes=25…)
The log will consist of lines where myTrust <= Trust (Frame) where
"KeyframeEvery" will force-add keyframes(in this case every minute 25fps*60= 1500 and
"SkipMultiKeyframes" will not allow new keyframes for x frames if another (not forced) keyframe was detected before
(it should prevent to get 25 keyframes a second…. )
The log should also contain the trust-value and a info if KeyframeEvery-conditions was positive
4) my last idea is: a extlog="c:\myFilename.log" the result is a the same as the "log=" -LogFile
plus 2 additdional values: the trust value and "Scenechange"-Info.
So it would be goot to parse the logfile with PHP.
But a second step is needed to extract the thumbnails.
A Perfect solution would be a combination out of 1) & 3) & 4)
Sorry for so many ideas, but your tool has so much power….
Do you think you will find / a way to make scene-detection & frame extraction easier?
Here is my current script:
MayBe it ist much easier as I thought…..
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MPEGDecoder.dll")
global ThumbNailPath = "D:\_Szenenerkennung\videos\Bilder\"
global LogFilename   = "D:\_Szenenerkennung\MyLog.txt"
myMPEGSource = MPEGSource("D:\_Szenenerkennung\videos\25.mpg")
myVideo = ReduceBy2(myMPEGSource)
myVideo = ConvertToYV12(myVideo)
function SaveFrame (myClip, myFrameNumber)
###Uncomment to display frame number
 myClip = Subtitle( myClip, string(myFrameNumber))
### Export JPEG Image
  ImageWriter(myClip, file = ThumbNailPath, start = myFrameNumber, end = myFrameNumber, type = "jpeg",info=true)
### WriteLogFile
  WriteFile(LogFilename,  """ "CurrentFrame: " """ ,"current_frame")
return (last)
#myVideo = ScriptClip(myVideo,"depanestimate(myVideo,trust=4,log=""" "scenes.log" """,info=true,show=true)")
myVideo = depanestimate(myVideo,trust=4,log= "scenes.log",info=true,show=true)
###Export KeyFrame
### a Key Frame yould only be exported when myTrust <= (DePanEstimate.Trust(frame))
myRGBVideo = ConvertToRGB24(myVideo)
  ScriptClip(myRGBVideo, "SaveFrame (myRGBVideo,current_frame)")
It would make me very happy to get an Idea how this problem could be solved..
Old 9th September 2004, 16:00   #84  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
My first answer to Andreas is:
I thinked about implementing scenedetection function some time ago.
For example, I can easy to realize a function DePanScenes(clip, inputlog),
which uses for input either DePanestimate motion data clip, or log file.
DePanScenes output will be clip with all pixels luma (or croma) = 0 for all ordinary frames, and = 255 for scenechanges.
This clip can be analyzed by AverageLuma() for example, and results used in ScriptClip.
But DePanEstimate make some calculation at constructor stage (sinus table for fft etc), and frame processing will be slow.
Old 9th September 2004, 16:38   #85  |  Link
Manao
Thinking of this, I could also quickly make a filter from the ME engine in MVTools, which decides whether a frame is a scenechange or not. I don't know however if the scenechange I get from vectors would be more reliable than those you're getting with your filter.
Anyway, if you want to test the basic scenechange detection in mvtools, you can use the following trick :
mv = source.mvanalyse(isb = false)
mask= source.mvmask(mv, ml = -1, gamma = 100)
white = source.blankclip(color = $ffffff)
black = source.blankclip(color = $000000)
scmask = conditionalfilter(mask, white, black, "AverageLuma()", ">", "0.2")
return scmask
( It's a hack, if there is no motion at all, it will be considered as a scenechange, but anyway, it gives a result )
Manao is offline   Reply With Quote
Old 15th September 2004, 21:46   #86  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
New version 1.1, September 16, 2004 - Added experimental DepanScenes function.
Old 2nd October 2004, 08:46   #87  |  Link
Ark
Aikidoka
Ark's Avatar
I found this script on Depan help file regarding FPS conversion from 16,6 fps to 25 fps:
Avisource("kino.avi")
loadplugin("depan.dll")
i=ConvertToYV12()
data=DePanEstimate(i, range=1, trust=5)
f1_3=DePan(i,data,offset=1./3)
b1_3=DePan(i,data,offset=-1./3)
interleave(f1_3,i,b1_3)
selectevery(6,0,1,2)
But I've some movies at 15 FPS that I want to convert to 25 FPS, how do I have to change values to achieve that?
(the above script result in 22.5 FPS...)
Xvid fan ;)
Ark is offline   Reply With Quote
Old 3rd October 2004, 21:39   #88  |  Link
johnmeyer
When trying to load Depan 1.1 or Depan 1.0, AVISynth 2.5 returns the error message:
Unable to load "depan.dll"
If I copy the version 0.91 depan.dll to the same directory, the dll loads and the script runs just fine. I have no problems loading other dlls, so I assume there is some bug in these two latest versions.
I am running XP Pro (SP1). I am running AVISynth 2.54.
Edit: I upgraded to the latest (AVISynth 2.55) and still couldn't load the two latest versions. I was hoping to use this plugin to generate slow motion from standard NTSC DV video. Can this be done using the DePanEstimate function?
Old 8th October 2004, 23:17   #89  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
Ark,
Here is a possible function for framerate converting (progressive) with factor=5/3, for example from 15 fps to 25 fps :
function fps3to5(clipYV12)
# change FPS from 3 to 5 (or 15 to 25, or 18 to 30 and so on), i.e. with factor=5/3
# uses global motion compensation
# input must be YV12 progressive (or separated fields probably ?)
data = DePanEstimate(clipYV12)
t3_5 = DePan(clipYV12, data, offset=-2./5)
t6_5 = DePan(clipYV12, data, offset=1./5).trim(2,0)
t9_5 = DePan(clipYV12, data, offset=-1./5).trim(1,0)
t12_5 = DePan(clipYV12, data, offset=2./5).trim(3,0)
Interleave(clipYV12, t3_5, t6_5, t9_5, t12_5)
SelectEvery(15,0,1,2,3,4)
AviSource("e:\video.avi")
LoadPlugin("depan.dll")
ConvertToYV12()
fps3to5()
Old 9th October 2004, 00:05   #90  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
johnmeyer,
I have similar reports from some users.
Probably you must have FFTW3.DLL
I will look later.
What is your CPU ?
Old 9th October 2004, 05:45   #91  |  Link
johnmeyer
I'll look into it tomorrow. I have a Pentium P4 2.8 GHz.
Old 9th October 2004, 21:39   #92  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
Version 1.1.1, October 07, 2004 - bug fixed with compensation near right bottom and top corners2,
change from FFTW_MEASURE to FFTW_ESTIMATE for more short init, without speed change (for power-2 windows),
compiled without /G7 flag (as before v.1.0), FPS script functions added to doc.
(not public)
Version 1.1.2, October 09, 2004 - delayed loading of fftw3.dll (now optional). Compiled with VC6.
Old 13th October 2004, 22:25   #93  |  Link
Ark
Aikidoka
Ark's Avatar
Originally posted by Fizick
Ark,
ConvertToYV12()
fps3to5()
Thanks a lot Fizick, I'll try thah script tomorrow!
Xvid fan ;)
Old 14th October 2004, 16:23   #94  |  Link
johnmeyer
fftw3.dll fixes the problem. Thanks!
Old 15th November 2004, 16:15   #95  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
Bug in depanstabilize found:
it produces dark-green frames (I think Y=U=V=0 )sometimes.
also it makes one or two lines at the bottom looking dark green.
the error is reproduceable, but I didn't tried it with another script for now.
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 15th November 2004, 23:16   #96  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
Old 15th November 2004, 23:37   #97  |  Link
scharfis_brain
brainless
you won't like it:
setmemorymax(512)
loadplugin("d:\x\masktools.dll")
loadplugin("d:\x\depan.dll")
loadplugin("d:\x\removedirt.dll")
function repairfieldswap(clip c)
{d=c.swapfields().crop(0,0,0,-1)
d=stackvertical(d.crop(0,0,0,1),d)
e=c.converttoyv12()
global edges=e.yv12convolution(horizontal="1",vertical="1 -2 1",Y=3,U=0,V=0,usemmx=true)
global swapedges=e.swapfields().yv12convolution(horizontal="1",vertical="1 -2 1",Y=3,U=0,V=0,usemmx=true)
ConditionalFilter(e, c, d, "float(averageluma(edges)-averageluma(swapedges))", "lessthan", "0.0")
a=avisource("capture (2004-11-14 at 14-34-24).avi")
b=avisource("capture-55630.avi").converttoyuy2().levels(16,1,235,0,255)
c=avisource("capture-81443.avi")
d=avisource("unblended.avi").changefps(25).killaudio().addborders(2,0,6,8)
a1=a.trim(0,55630)
a2=a.trim(55638,81442)
a3=a.trim(81447,0)
a1+b+a2+c+a3
trim(580,100296)
assumetff()
doubleweave().selectodd()
audiox=last
last.killaudio()
last.trim(0,2205)+d+last.trim(3074,0)
audiodub(last,audiox)
r=2
c=2
mergechroma(crop(0,c,0,0).addborders(0,0,0,c))
repairfieldswap()
crop(2,0,-6,-8)
converttoyv12()
x=depanestimate(last,pixaspect=1.094,trust=0.0,range=1)
depaninterleave(last,data=x,next=r,prev=r,mirror=15)
removedirt()
selectevery(r+r+1,r)
de0=last
de1=de0.depanstabilize(data=x,dxmax=12,dymax=12,zoommax=1.0,rotmax=0.0,pixaspect=1.094,mirror=15) #next=12,prev=12)
de1.trim(0,190)+de0.trim(191,540)+de1.trim(541,0)
Old 16th November 2004, 12:42   #98  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
Confirmed
The bug was becouse of infinite calculated shifts for improperly Depanestimate() parameters setting.
Bug fixed in new version 1.1.3. Now base frame reseted.
Try!
Old 16th November 2004, 13:24   #99  |  Link
scharfis_brain
brainless
Wow, you're damn fast in fixing bugs!
but can you explain this:
"The bug was becouse of infinite calculated shifts for improperly Depanestimate() parameters setting."
a little bit more detailed?
what are infinte shifts?
why improper settings?
Old 16th November 2004, 19:37   #100  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
1. improper settings - some scenechange was not found,
and resulted in very big false pan by Depanestimate.
2. Depanstabilize try calculate shift for these false data,
and internal get divergence of caclulation (infinite shift).
