5th December 2007, 23:50 | #163 | Link |
Caped Crusader
Have you tried Vilvic Media Center You can transfer large files to your PS3 with that . I used to use that to transfer files as large as 20 GB before I started streaming. And talking about streaming, I use twonky and with that if you press triangle on the file from your PS3 you can chose copy and it copy it to the internal HD.
6th December 2007, 00:43 | #164 | Link |
If a file has 2 Audio Lanes - Englisch -German
How do I tell him to use german? And how do I tell him not to use subtitles? The reson why Im asking is because I only have one empty DVD DL Disc left and I dont want to screw up this time. |
7th December 2007, 12:39 | #172 | Link |
Many thanks for this great little application, works on about 90% of the 720p samples I had lying around. One problem I keep finding is an error after tranzcode, it creates .wav's from the DTS/AC3 etc, but I get 'Error creating AC3 from WAV!'.
Any clues as to why this is happening (tranzcode outputs the .wav's no problem). I'm going to try the 1080p format onto a BR disc, as I'd love to crack the 1080p barrier before the holidays. |
9th December 2007, 12:05 | #173 | Link |
Just writing for someone to confirm this ..
I've spent some time playing with encoding 1080p h264 files for PS3. What I have discovered is that the files were playable for level 4.1 only if I have chosen to use at most one reference frame (a setting of x264 application). If I choose more than one ref frame the x264 complains something about DPB size (e.g. x264 [warning]: DPB size (13824000) > level limit (12582912)) for chosen profile but starts encoding a stream which is not playable on ps3. I think this is the problem of changing from avc 5.1 to avc 4.1 just by hex editing - it does not change the internals of the stream, so the stream becomes incorrect. For 720p the problem is less important since references to blocks are reachable within 4.1 profile DPB range. ... Tomek Last edited by zwirek75; 9th December 2007 at 15:37. |
10th December 2007, 07:16 | #175 | Link |
first off lemme say that this is a fantastic program and so far has worked flawlessly on my 720p videos.
i am wireless using my ps3 so streaming a lil bit of a stretch....i can at least see that the video does playback so i know it works. problem for me is for example: superbad 720p ripped as .vob is larger than the actual mkv file so it wont fit onto a standard dvd anymore and i cant put it on my fat32 external hd b/c its over 4gb...so i have 3 questions: 1.) what do u recommend as far as a vob splitter goes? 2.) is there a way to shrink the .vob file down just a touch to get it onto a standard DVD 2.) will the ps3 accept other hard drive formats? like ext2 or ext3? thanks for all ur hard work! |
10th December 2007, 08:35 | #177 | Link | |
Is there (known) any way to detect such situations before starting the conversion process to detect streams which are not "convertible" by mkv2vob ? Tomek |
10th December 2007, 20:59 | #178 | Link |
Ive used your program to convert a couple of mkvs successfully, so thanks for that! I understand the issue with not being able to fast forward (do you think this will ever be fixed, or is it a Sony problem) My question is, even just stopping the playback, going back to the xmb, then resuming playback causes the fast video / sync issue here. Is this normal? Because it makes watching a movie really hard work, if I accidentally exit the film I'm stuffed! Cheers, Jon. |
