20th October 2005, 09:31 | #61 | Link | |
PgcEdit daemon
20th October 2005, 11:55 | #62 | Link |
Country Member
Yeah, it is infuriating. Right now, I am in the habit of doing Incremental backup before cell operations - especially add blank cells.
(WooHoo - 1,500 totally unhelpful and useless posts!) Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
21st October 2005, 02:51 | #64 | Link | |
Lurker
21st October 2005, 08:40 | #65 | Link |
PgcEdit daemon
Right. You need VobBlanker to recover the space used by the VOB cells.
However, it is possible to blank a whole domain at once in PgcEdit. See Domain -> Blank Out all PGCs in Domain. It patches the IFOs, and replace the VOB(s) by one single black frame. In the menu domain, it is even possible to remove completely the VOB, by converting all PGCs to dummies. If you don't need to keep anything in a domain, I recommand to use this option. It's faster, and it recovers even more space than with VobBlanker.
21st October 2005, 12:53 | #66 | Link | |
PgcEdit daemon
21st October 2005, 13:41 | #67 | Link | |
PgcEdit daemon
21st October 2005, 13:58 | #68 | Link | |
PgcEdit daemon
When you don't backup the VOBs, the procedure continues as expected. If you use the Cancel button when requested to backup the VOBs, or in the overwrite confirmation dialog, the procedure is not executed at all. In both cases, it's normal. Could you please explain what you did exactly?
21st October 2005, 15:31 | #69 | Link |
Lurker
I have never seen this bug in my usage of the program, either in removing the checkmark to backup the VOB when blanking a cell or when leaving it marked and then saying no to overwriting the already backed up VOB. Each time it correctly updated the cells for me. Note that I have not tried leaving it checked and click no to overwrite in 0.6.1, only in 0.6.
21st October 2005, 16:00 | #70 | Link |
PgcEdit daemon
Thanks for the confirmation.
However, blutack is talking about the Create New Blank Cell feature available in the PGC Editor. There is no checkmark to backup the VOBs. It's a dialog window that is opened when needed. I suppose you are speaking of the Blank All PGCs in Domain function. But you're right. Since both methods are similar, the same bug should occur in both functions, or never. (But the add cell function is more complex...)
21st October 2005, 20:31 | #71 | Link |
Lurker
Whoops, my bad, assumed when he said "say no to updating the VOB in the backup folder" to be him referring to blanking cells and the backing up of original VOBs.
One thing I've noticed, when the fix streams macro is run when opening the DVD, it doesn't seem to fix the problems it finds. When I reopen that DVD, it comes up with the same "there are 2 discrepancies..." no matter how many times I run the macro. Last edited by Z-95; 21st October 2005 at 20:34. |
22nd October 2005, 00:36 | #72 | Link |
PgcEdit daemon
The fix streams macro fixes the discrepancies on the data stored in memory, but doesn't save the DVD automatically. You have to save it manually.
22nd October 2005, 06:10 | #74 | Link |
Country Member
@r0lZ - all I did was try to add a few blank cells. Unofrtunately you have to do this one at a time, but so be it (maybe easier to use AddChapter for bulk adds). So, I add the forst one no probs. Saves the DVD autmatically (I think). Add another blank cell. Asks if I want to overwrite the backup VOB (I don't). Then the little 10k is added to the VOB but the cell table is not updated, so the third time around, I'm in trouble.
Regards
22nd October 2005, 10:27 | #75 | Link |
PgcEdit daemon
Thanks. Will try this procedure...
22nd October 2005, 13:18 | #76 | Link |
PgcEdit daemon
I have updated my homepage with links to new guides (including 2 brand new german PDFs by Tobi), and to the newest plugins (including the anti-ARccOS plugin by the Mad Monk.)
See the hemepage for details...
23rd October 2005, 11:32 | #78 | Link |
Country Member
A note on the Anti-ARccOS plugin - it is still under development and does not work for everything out there (Episodic DVDs still require a little development). But give it a try - it works on the vast majority of ARccOS disks in circulation.
Regards
25th October 2005, 04:03 | #79 | Link |
mad computer-scientist
request: 32k pad via CLI
r0lZ, could you add a cli-option (or make a seperate cli-tool) that allows just patching a VIDEO_TS folder to have the 32k padding between video_ts.ifo and .bup, so it can then be used with mkisofs?
would be great to have for batch-files and front-ends also: could you please post the correct mkisofs parameters to use after the patching? |
25th October 2005, 06:58 | #80 | Link |
PgcEdit daemon
Well, PgcEdit is a front-end for MkISOFS. And doing a little cli-tool is not easy. I will have to extract many things from the main program...
But there is a trick. When PgcEdit starts (with a DVD folder name passed as argument), it loads the DVD, and then loads the plugins. So, if you want, copy PgcEdit somewhere in a new directory, and create a little plugin to save automatically the DVD just after it has been loaded. Be sure to enable the 32K gap option, and enable expert mode to suppress the confirmation dialogs. If you call this copy of PgcEdit, it will load the DVD, and save it with the 32K gaps, then exit. However, note that all setup values are saved in the same folder, regardless of which copy of PgcEdit is used. This means that you will have to leave the options above when you work with the 'normal' copy of PgcEdit. Also, PgcEdit may display some warnings, even when the expert mode is enabled. The plugin should contain those lines: Code:
set rc [::main::Write_DVD false] ;# save DVD, and remember error code cleanexit $rc ;# and quit PgcEdit with error code [EDIT:] It is even possible to hardcode the setups you need in the plugin. Insert the following lines before the lines above: Code:
set ::config(save_setups_on_exit) false set ::config(save_BUP_with_gaps) true set ::config(expert_mode) true set ::config(auto_create_backup) false set ::config(auto_fix_streams) false set ::config(auto_launch_menubuttons_parser) false (I'm not sure if the last 3 lines are useful, since the DVD will be already loaded when they are executed.)
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 25th October 2005 at 07:22. |
