3rd May 2006, 20:51 | #1201 | Link | |
Swallowed in the Sea
3rd May 2006, 23:15 | #1203 | Link | |
The Internet: where men are men, women are men, and children are FBI Agents |
5th May 2006, 04:28 | #1204 | Link | |
ID3 Tag problem MP3 to OGG
Using: *ogg vorbis dlls using libVorbis v1.1.2 2005-12-08 *BeLight-0.22beta9 *BeSweetv1.5b31 The original files are MP3 with ID3Tag 2.30 Log: Quote:
5th May 2006, 19:11 | #1205 | Link |
@Kurtnoise
Could you test this build...Be sure that cmd.exe isn't already using by an other app. somehow that build doesn't work @ i deleted belight.ini and reset the besweet.exe path but pushing Start Processing nothing happens ?
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
5th May 2006, 19:44 | #1206 | Link |
Yes...sorry. Some functions were disabled in the last build. Should be ok now.
http://corecodec.org/frs/?group_id=4...se_id=283#r283 |
5th May 2006, 19:47 | #1207 | Link | |
5th May 2006, 21:52 | #1208 | Link | |
5th May 2006, 23:13 | #1210 | Link |
Will this big fixed in Besweet? If there is no solution regarding ID Tags and transcoding MP3-OGG, can somebody suggest an alterantive?
Transcoding 7 GB of MP3 to OGG and after that making new ID Tags is a little more work than i love to do Last edited by Thomas_AR; 6th May 2006 at 03:38. |
6th May 2006, 06:54 | #1211 | Link | |
Unfortunately, BeSweet is not the appropriate tool to transcode files having tags. You can test with foobar as alternative. Anyway, lossy-to-lossy transformation is not recommended but you do what you want after all. @Shon3i: yes, it's planned. |
7th May 2006, 00:19 | #1212 | Link | |
Banned
Kurtnoise13,your latest BeLight daily build, 20060505 have one HUGE bug. When i try to encode from WAV, AC3, MP3 to CT AAC+, Belight shows this error message:
With previous daily build, this bug doesn't exist. Please fix this bug. |
7th May 2006, 07:48 | #1213 | Link |
Unregistered User
Where does the HybridGain option dissapeared again, e.g. it is not in the BeSweet OTA mode combobox - only PostGain and PreGain are there?! The default extension for opening files is now set to *.ac3. Could it be something like All Supported Formats (*.ac3; *.wav, etc.). I'm talking about the latest beta.
my subtitle site |
7th May 2006, 08:27 | #1214 | Link | |||
7th May 2006, 18:34 | #1215 | Link |
Unregistered User
@Kurtnoise13: Strange, I was always using HybridGain with no problems. Even now if I type HybridGain in BeSweet OTA Mode combobox I can use it and after restarting BeLight the HybridGain option is there. That's why I want all comboboxes style to be csDropDownList. I'll try with PreGain then. Thx!
my subtitle site |
8th May 2006, 11:08 | #1216 | Link |
What's in a name dude !
i have winamp 5.21 pro installed, i am getting this error when trying to transcode ac3 to he-aac high 160 kbps ct:
BeSweet v1.5b31 by DSPguru. -------------------------- Using azid.dll v1.9 (b922) by Midas (midas@egon.gyaloglo.hu). Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net). Using WA_aac.dll v2.3 by Kurtnoise (kurtnoise@free.fr) Logging start : 05/08/06 , 15:35:08. D:\BeLight\BeSweet.exe -core( -input E:\New Folder\DVD\VTS_03_1 T01 3_2ch 448Kbps DELAY 0ms.ac3 -output E:\New Folder\DVD\VTS_03_1 T01 3_2ch 448Kbps DELAY 0ms.aac -logfile E:\New Folder\DVD\VTS_03_1 T01 3_2ch 448Kbps DELAY 0ms.log ) -azid( -s dplii -c normal -L -3db ) -dimzon( -dllname WA_aac.dll -cbr 160 -mode 2 -high ) -ota( -d 0 -g max ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : E:\New Folder\DVD\VTS_03_1 T01 3_2ch 448Kbps DELAY 0ms.ac3 [00:00:00:000] | Output: E:\New Folder\DVD\VTS_03_1 T01 3_2ch 448Kbps DELAY 0ms.aac [00:00:00:000] | Floating-Point Process: No Error 84: error configuring bsn! Quiting... [00:00:00:000] Conversion Completed ! Logging ends : 05/08/06 , 15:35:08. pls help! |
8th May 2006, 11:58 | #1218 | Link | |
Check if enc_aacplus.dll is in your BeLigth-BeSweet folder (not only in winamp folder). |
