29th April 2010, 12:22 | #1761 | Link |
4:2:0 hater
Here's the patch and a ICL11 build of the last revision with it applied:
Patch: http://www.mediafire.com/?jtjnfgendgm Build: http://www.mediafire.com/?4u2ygtjxjnj Have you found any problems with audio switching with this patch? Or only improvements compared to trunk? |
30th April 2010, 08:32 | #1762 | Link | |
Media Control author
It happens if you have a xonar. I suspect the audio renderer to blacklist the upstream filter (haali) : when haali is used, ffdshow bitstream filter receives a decoding error from the audio renderer. When MPC splitter is used, it works fine though. Maybe you should try to use earlier versions of arcsoft (and haali too) to confirm this |
30th April 2010, 09:44 | #1763 | Link | |
30th April 2010, 14:34 | #1764 | Link | |
2nd May 2010, 14:19 | #1765 | Link | |
When i change audio stream in Bitstream DTS, i can switch 1 to 2 but if i go again in 1, the movie stop. I'm thinking that it was a PB within MP but with your last release : ffdshow_rev3390_20100430_msvc2008.exe it's seems that it solve this issue Thx. Seb. Edit : : i'm an idiot man lol, i just see that you have put a few thread ago
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. Last edited by Sebastiii; 2nd May 2010 at 14:21. Reason: I'm an idiot |
3rd May 2010, 09:22 | #1768 | Link |
Hello,
Just some little questions : I want to play some 5.1 HD audio tracks on my 2.1 system (Logitech Z-2300, one jack goes to speakers+sub). Which settings are good : 2/0/0 Stereo or 2/0/0 Stereo + LFE ? Does the Dolby Surround/ProLogic and Dolby ProLogic II simulate the surround speakers on a 2.1 system ? Thanks Last edited by Guest; 3rd May 2010 at 15:07. Reason: rule 12 |
3rd May 2010, 18:53 | #1769 | Link |
Playing an m2ts with true-hd in it, using ffdshow audio decoder 3397, when I seek, audio either completely stops, or audio plays at like 10000% as if its trying to catch up to where I seeked to.
Without ffdshow this doesn't occur. Any thing I can post here to help or is this a known problem. |
3rd May 2010, 19:00 | #1770 | Link |
4:2:0 hater
Try this build: http://forum.doom9.org/showthread.ph...13#post1395813
4th May 2010, 11:40 | #1771 | Link |
I have a Question for the Xonar users.
Does anybody have a solution for mkv files with 2 audios in it? If I disable the audioswitcher in mpc-hc it plays both audios at the same time. If I enable the audio switcher it breaks the bitstream, because its not using arcsoft render. thx and greetz |
4th May 2010, 18:03 | #1772 | Link | |
6th May 2010, 14:47 | #1773 | Link | |
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
10th May 2010, 13:32 | #1775 | Link | |
I've tested with the 27/03/2010 and 19/12/2009 builds of Haali. I'm going to test with CoreAVC in case it's a MPCVideoDec or ffdshow video decoding issue. @Albain, I've pm'd you with a log. Thanks! |
10th May 2010, 22:41 | #1776 | Link | |
So i've tried the Xonar, the ATI 5450, an Ion board, a Core2 board, fresh builds, previous versions of both Haali and ffdshow, however i always the get the same video/audio lag with Haali / DTS-MA bitstream combo. I'm sure Haali has works before with DTS-MA bitstreaming in the past, however i'm starting to think maybe not?! Been testing from mkv so gonna have a go with m2ts. |
10th May 2010, 23:17 | #1777 | Link | |
11th May 2010, 14:01 | #1779 | Link |
I'll have to get the latest ffdshow/mpc-hc. I'm nowhere near up to date. I just got back from vacation so I can't promise I'll get to it today but I'll see what I can do.
