17th April 2009, 07:14 | #401 | Link |
HDConvertToX author
UPDATE HDC
>fixed chapter extraction >fixed update manual to custom compression test >fixed update Make Report to show audio decoder handling >other minor corrections and cosmetic fixes @Crono141 till resolution and framerate is 0 or null, hdc cannot handle your file. since m2ts with vc-1 here is working , i suggest to REinstall haali/ffdshow tryout (latest version) MPC use own decoder/splitter, so isn't a good test what happen if you use Windows Media Player to open the avs or m2ts ? about the report "e:\rippeddvd\mainmovie\school_of_rock_16x9\video_ts\vts_01_1.vob" i see strange thing in queue.. no dgindex, no first pass , no audio extraction... are you sure you havn't edited the queue ??? BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
17th April 2009, 16:19 | #402 | Link |
WMP won't open the avs, but plays the m2ts natively without a problem. I reinstalled FFDshow and haali and still have the same symptoms in HDC. I am running Windows 7, which may have something to do with why it plays in WMP and MPC and not in HDC.
Is there another switch besides directshowsource that could be used in the avs script? I'm trying the School of Rock 2 pass over again. I didn't mess with the queue at all, but it may have been a fluke. A small bug I've noticed: if HDC completes an encode, and you want to do another, you have to close the program and restart it for the next to work properly. At least that's been my experience, but I've been getting alot of failed encodes so that may have something to do with it. |
17th April 2009, 16:28 | #403 | Link | ||
HDConvertToX author
put the FFMS2.dll in \filters folder in video encoder try checking "Force FFMS2" otherwise i cannot help more Quote:
BHH
17th April 2009, 20:56 | #404 | Link |
buzz, when using copy audio function with truehd files, the extention given to the eac3to job is .ac3, which is then used by tsmuxer to mux with final encoded video. This should be .thd+ac3 so the full hi def audio is copied and used with tsmuxer when creating the final m2ts, and not just the ac3 track. This is so I can copy truehd files, options for ac3 are available if i only require the ac3 core from a truehd file, can this be changed to reflect please Also making sure the correct data is also present in the meta file?
regards |
18th April 2009, 04:35 | #405 | Link |
Hi buzzqw
I think HDC has an error in aac abr audio encoding with nero "D:\HDConvertToX\applications\neroaacenc.exe" -if - -br 64 -ignorelength -of "D:\HDConvertToX\temp\hdencodertox-pid2.mp4" -br 64 means 64 bits/s not 64 kb/s this must be 64*1024 = 65536 or at least 64000 Thanks for this great software |
18th April 2009, 07:05 | #406 | Link |
HDConvertToX author
@spida_singh
thanks, my knowledge of hd audio is still to come @ryc0203 got it, thanks for this bug! BHH
18th April 2009, 07:45 | #407 | Link |
HDConvertToX author
update HDC
>added support for force decoding video with FFmpegSource (alpha) >added in compression test note about CQ/CRF value and what preset used >added support FFmpegSource as audio decoder. For AAC-SBR is a must, if you don't have installed Nero 7 (alpha) >fixed Nero bitrate in abr/cbr mode >fixed extension of true-hd ac3 audio when copying. thd+ac3 is used when muxing in mkv or m2ts, for avi and mp4 is used ac3 >other minor corrections and cosmetic fixes BHH
18th April 2009, 16:53 | #411 | Link |
HDConvertToX author
@Crono141
are you able to open your m2ts with graphedit ? and building a fuctional graph ? BHH
18th April 2009, 17:44 | #413 | Link | |
HDConvertToX author
i like comments like this BHH
18th April 2009, 20:01 | #414 | Link |
The functions:
"Use eac3to the demuxer and decoder" "Force the decoder BassAudio" "Foce FFmpegSoruce the decoder" Does not work when trying to convert mkv (h264/aac) to avi (xvid/mp3). The error message is "unsuported audio format" |
18th April 2009, 21:30 | #415 | Link |
HDConvertToX author
Eac3to need Nero Audio Decoder
Force Bass Audio need audio NOT SBR please check this post http://forum.doom9.org/showthread.ph...94#post1275094 (new ffms2 will be included in next full update) BHH
19th April 2009, 00:25 | #417 | Link |
Fighting spam with a fish
Got a quick mirror up:
http://www.austindwiltshire.com/mirr...0.213.1664.rar |
19th April 2009, 08:32 | #419 | Link |
HDConvertToX author
@Crono141
since it is a problem within your BETA OS and your filters, i can give only a very limited support. try this last one 1) update HDC 2) in graphedit save the GRF 3) use the GRF as input for HDC >added support for GRF (only video, HDC will ask for audio) BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
