17th May 2006, 06:11 | #241 | Link | ||
BeHappy/MeGUI developer
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
17th May 2006, 18:18 | #243 | Link | |
18th May 2006, 01:19 | #244 | Link |
Okay, then don't believe me. You could focus on a possible bug in your program, or you can claim it to be fantasy, it is your choice.
I don't have AviSynth installed in the default location. I will try reinstalling it in the default folder and see if that fixes things. By the way, it would be nice if one were able to export AAC in a .mp4 container, since it has support with more media players. UPDATE: Indeed, installing AviSynth at its default location corrected the error. ANOTHER UPDATE: I had StaxRip installed, and it's possible that it decided to swap the registry link from the AviSynth folder I installed to its own plugins folder. Last edited by SirLamer; 18th May 2006 at 02:43. |
18th May 2006, 08:41 | #245 | Link |
new unstable development build out!
New CT AAC encoder GUI New TimeStretch encoder GUI
18th May 2006, 08:44 | #246 | Link | |
18th May 2006, 13:41 | #248 | Link |
Any chance adding COM automation suport?
18th May 2006, 13:51 | #249 | Link | |
18th May 2006, 14:39 | #250 | Link |
In my case I'm interested to use BeHappy for audio encoding with StaxRip. A CLI might even be better since StaxRip has already generic CLI support. Generally scripting and CLI is always a good thing, don't you think?
There is always a feature missing and scripting is often the rescue here. I've extened dozens of applications for personal use including most of my media apps like MediaMonkey, iTunes, DVBViewer, they all got a huge scripting SDK. BeHappy would then be usable from the command prompt, batch files, and all serious programming and scripting languages. It can already be hacked easily from .NET but it's nicer to use a real SDK, late binding etc. instead of reflection on private code.
18th May 2006, 16:06 | #251 | Link | |
Another good way is - extract only requed parts of the code from BeHappy source and use it directly into StaxRip (MeGUI way). Since your primary code is written in VB.NET and BeHappy is written in C# it's better to create separate assembly and use it from your VB.NET code Anycase keep in mind - BeHappy is GPL-ed so You can modify it as You wish Cheers
18th May 2006, 17:31 | #252 | Link |
Fresh ffmpeg.extension is avaluable @ BeHappy Workspace
18th May 2006, 18:00 | #253 | Link |
How about CLI, don't you think it would be useful? I could help you if you don't want to spend much time with it (start StaxRip with -h to see how I did my CLI, IMHO it's quite nice).
18th May 2006, 18:11 | #254 | Link | |
Avs inline is not very easy-to-use when you need some complex processing - I'm planning to make another architecture, easy to use and extensible... (extension will add or extend command-line switch ) It will be complete different application with it's own extensions and encoders arhitecture... Command line will be close to BeSweet one (maybe it will be even mimic to BeSweet to allow drop-in replacement)
19th May 2006, 08:17 | #255 | Link |
New version is out
19th May 2006, 16:29 | #256 | Link |
Aud-X extension is out
19th May 2006, 22:29 | #259 | Link |
BluRay Maniac
Updated
BeHappy 0.1.9 build 5241
Download Just install and enjoy in encoding Changelog: 18/08/2006: - With little late BeHappy package is updated to BeHappy 19/07/2006 - Added Aften AC3 encoding 20/06/2006: - Added BassAudio plugins & extensions (request by tebasuna51) 17/06/2006: - Updated BeHappy to 23/05/2006 v4 - Updated mp4box to last release - Updated Nero to 1.0.0.2 - Updated CT from Winamp 5.23 Pro - Updated Aud-X 23/05/2006 - Updated NicAudio.extension (support MPG123 ReplayGain) - Added Nero SSE2 Encoder - Added SoxFilter for upmix extensions - New installation by InstallShield 23/05/2006: - Updated BeHappy to 23/05/2006 - Updated Aud-X CLI encoder to 22/05/2006 22/05/2006: - Updated BeHappy to 22/05/2006 20/05/2006: - MeGUI auto updater overwrites my NicAudio.dll (20060314) with some from 2005, in that case DRC not work, so install this new package to return to (20060314) - I forgot to put mp4box need for CT audio encoder. 19/05/2006 -First release Last edited by shon3i; 18th August 2006 at 17:32. Reason: new version |
behappy |
