17th October 2015, 12:30 | #33661 | Link | ||
But I don't use any of these sharpening filters, so you should ask the smarter guys about them
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
17th October 2015, 12:45 | #33663 | Link | ||
And I'm not sure that you need both x and y scalinfactor check but just one, if you prevent the change of aspect ratio. Code:
if (scalingFactor.x < 1.0) "< 1.0" elseif (scalingFactor.x = 1.0) "1.0" elseif (scalingFactor.x > 1.0) "> 1.0 < 1.5" elseif (scalingFactor.x > 1.5) and (deintFps <= 30) "> 2.2 <= 30fps" elseif (scalingFactor.x > 1.5) and (deintFps > 30) "> 2.2 > 30fps" else "Default"
17th October 2015, 12:51 | #33664 | Link | |
@madshi: I've narrowed it down to decimals not working in profile rules - the script is marked as valid (green "tick"), but rules don't work. To give an example: if (scalingFactor.x>1) "Profile 1" works correctly, while if (scalingFactor.x>1.0) "Profile 1" doesn't work and if (scalingFactor.x>1.5) "Profile 1" doesn't work either. |
17th October 2015, 12:54 | #33665 | Link |
madshi is german, did you try "1,0" instead? It would technically be the german way to write it.... =p
17th October 2015, 13:15 | #33668 | Link |
And I messed up the intervals check earlier, here's the proper one:
if (scalingFactor.x < 1.0) "< 1.0" elseif (scalingFactor.x = 1.0) "1.0" elseif (scalingFactor.x <= 1.5) "> 1.0 < 1.5" elseif (scalingFactor.x > 1.5) and (deintFps <= 30) "> 2.2 <= 30fps" elseif (scalingFactor.x > 1.5) and (deintFps > 30) "> 2.2 > 30fps" else "Default"
17th October 2015, 13:17 | #33669 | Link | |
Doesn't matter if FSE, D3D9 or not. With a GPU queue of 8, it looks normal. But it can't be a problem with performance or video memory, it must be some weird coincidence. |
17th October 2015, 14:01 | #33671 | Link | |
It will start at the botton and then push itself into the active box after a while. Here is a sample below that happens consistently for me. https://www.dropbox.com/s/ivp11mz3s0...281%29.7z?dl=0
Core i7 4790K@4.6Ghz - Asus Maximus VII Formula - AMD R9 290X 4GB Crossfire - Windows 10 Pro x64 |
17th October 2015, 14:32 | #33672 | Link | ||||||
17th October 2015, 15:09 | #33673 | Link | |
'Delay playback start' is also on by default here, and all queues are full, I use 12 and 8, present in advance also at 8. Deinterlacing is off, and I also checked with default flush settings to rule that out as I have "don't flush" everywhere, didn't help. I use MPC-HC and it only happens during first 4-5 seconds and stops as soon as you see the Universal globe, so it doesn't bother me much, but if I were using MPC-BE that would be another matter (see my first post), that's why I thought I should let you know. |
17th October 2015, 16:00 | #33674 | Link | |
With style using Calibri bold, size 18, MPC-HC internal subfilter renders the O character at a fixed 1.8cm size. XySubFilter renders it at 1.5cm with black bars (2.40:1 aspect ratio), 2.0cm with no black bars (16:9 aspect ratio). Tried with both MPC-HC and Kodi.
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM |
17th October 2015, 16:27 | #33675 | Link | ||
17th October 2015, 16:37 | #33676 | Link | |
So it's probably not a bug in madVR, but the exception treatment with SM maybe could be better? But if it's really due to a weird encode, it might not be important imho. |
17th October 2015, 17:11 | #33677 | Link |
I am using software decoding. DXVA Copy-Back is affected in the same way.
Memory consumption using DXVA native seems totally different. Quickly reaches ~50k but barely reaches 53k by end of sample even with all the maximizing<>100%zoom I can do. No, not right now. |
17th October 2015, 18:25 | #33678 | Link | |
Edit: I checked, yes, the correct behaviour (in my opinion) happens with internal subs renderer, in MPC-HC with "position subtitles relative to the video frame" unchecked. If there's already a way to get the same behaviour in XySubsFilter, I'd be interested to know it. If there isn't, as per above, I'd like to understand the logic behind the behaviour. Is there any time when changing subs size according to aspect ratio would be desirable?
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM Last edited by ashlar42; 17th October 2015 at 18:47. |
17th October 2015, 19:52 | #33679 | Link | ||
But that was not my question. I wanted to know if you get the same varying font sizes with that option CHECKED, not unchecked. I explicitly wrote "Try with it checked". |
17th October 2015, 20:56 | #33680 | Link |
I am going to do some more testing and report back. Would you please elaborate on your statement that DXVA is superior to CUVID? And why copy-back, why not native? Shouldn't native be faster? Thanks.
