Old 4th June 2012, 16:03   #11641  |  Link
ramicio
Banned
Originally Posted by Midzuki View Post
Another possible approach: drop FLAC and "move house" to WavPack
Except problems arise when you have files bigger than 4 GiB. Some filters handle it, some don't. For Windows you can use madFLAC for correct channel assignments, or WavPack's splitter filter and decoder handles files > 4 GiB. Outside of Windows, you're screwed on both fronts. Both codecs still need work, and it's pathetic that they've been basically "completed" years ago despite some problems. All FLAC would have to do is switch to using WAVEFORMATEXTENSIBLE channel masks.
ramicio is offline
Old 5th June 2012, 20:21   #11642  |  Link
Joniii
Stupid question, I have a m2ts file with DTS (delay -9ms). eac3to applied dts delay when demuxing but said a remaining delay of +1ms could not be fixed. I know 1ms is nothing but being a perfectionist, do I have to add -1ms or +1ms with mkvtoolnix when remuxing?
Little confused because the file has -9ms delay but after fixing it, it ends up having +1ms delay.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards
MPC-HC (madVR, LAV Filters, XySubFilter)
Sony Bravia 85X950H/85XH95
Yamaha RX-V685
Yamaha Piano Black NS-777/555/C444/YST-SW315
Joniii is offline
Old 6th June 2012, 02:45   #11643  |  Link
hello_hello
Maybe the extra 1ms delay is caused by some sort of padding used at the beginning of the audio file and that's as close as eac3to could get it? Just a guess....
To answer you question though I'd assume it's a positive delay of 1ms which needs to be added manually.
hello_hello is offline
Old 6th June 2012, 08:25   #11644  |  Link
tebasuna51
tebasuna51's Avatar
Correct the delay without recode is only possible adding/cutting complete DTS frames (512 samples at 48KHz = 10.667 ms each frame).
Here 1 frame is cutted then 10.67ms - 9ms = 1.667ms.
Like audio have 1.667 ms less duration the delay in container must be +1, or +2 if you want, but is unnecesary.
Video frames have a duration of 40 ms (25 fps) then delays of +/- 20 ms are absolutely undetectable.
tebasuna51 is offline
Old 6th June 2012, 20:58   #11645  |  Link
Joniii
Thx for the explanation, I have always wondered why it always leaves +1ms.
Yamaha RX-V685
Joniii is offline
Old 8th June 2012, 17:06   #11646  |  Link
ramicio
Banned
I really wish logging could be disabled. There should be support for some sort of .ini file in the eac3to directory for a few settings, like which method for progress display, and if it's just the hyphen bar, then you should be able to specify how many characters wide your terminal is. Who uses the default width of 80? I don't get why progress numbers need to start a new line. It's difficult for me to judge progress because my terminals are 170 wide, and will likely grow as resolutions keep going up.
ramicio is offline
Old 10th June 2012, 16:16   #11647  |  Link
sl1pkn07
Pajas Mentales...
little question. why not use libmatroska/libebml instead haalisplitter/mkvtoolnix?
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline
Old 11th June 2012, 02:23   #11648  |  Link
mastrandrea
Is this the right tool to convert a 3.0 AC3 track (Front: L R, Side: C) to a 2.0 AC3 track? If not, which software do you suggest me to use?
mastrandrea is offline
Old 11th June 2012, 09:18   #11649  |  Link
tebasuna51
tebasuna51's Avatar
eac3to only accept 5.1 to convert to 2.0.
You can try:
- BeHappy, with NicAc3Source(Down2) like Source and a DSP Normalize.
- BeLight, adjusting azid output like Stereo and Normalize.
Old 11th June 2012, 14:04   #11650  |  Link
ramicio
Banned
FFDShow, GraphEdit, and the WavDest filter. Set FFDShow to mix to 2.0 and normalize the levels.
ramicio is offline
Old 11th June 2012, 19:04   #11651  |  Link
mastrandrea
Thank you both!
Old 15th June 2012, 13:13   #11652  |  Link
mp3dom
I have a question that probably was already answered but I can't find a clear post (most of them refers to dts-hd 6.1 to 5.1 remapping channels). I have a 6.1 interleaved wave with the following mappings:
Left
Right
Center
LFE
Left Surround
Right Surround
Back-Center Surround
I want to downmix to 5.1 with eac3to. Is this channelmap already ok for what eac3to expect, or do I need to switch some channel (like put Back Center Surround between LFE and Left Surround?).
Thanks!
mp3dom is offline
Old 15th June 2012, 13:47   #11653  |  Link
ramicio
Banned
If they are already in a WAV then they are likely in the correct order. WAV has a standardized channel order. Are the surrounds "back" or "side?"
ramicio is offline
Old 15th June 2012, 14:07   #11654  |  Link
mp3dom
The surrounds are all back channels. The interleaved wave was made from 7 mono files (I think using SoundForge or Nuendo)
mp3dom is offline
Old 15th June 2012, 14:08   #11655  |  Link
ramicio
Banned
Well, if you put the files in the correct order to interleave the file, and it has the correct channel mask, then there will be zero problems.
ramicio is offline
Old 15th June 2012, 15:32   #11656  |  Link
Carpo
Carpo's Avatar
instead of reading 583 pages and trying to use the search here that never finds what i'm after, I will ask a question that has already been asked, but is there any chance of eac3to being updated to use LAV filters instead of/ as well as haali?
The Internet: where men are men, women are men, and children are FBI Agents
Carpo is offline
Old 15th June 2012, 15:36   #11657  |  Link
ramicio
Banned
Isn't Haali just a splitter? I see a file in the eac3to directory called avcodec.dll. Is this not libavcodec, which that LAV Filters thing is based off of?
ramicio is offline
Old 15th June 2012, 16:22   #11658  |  Link
Carpo
Carpo's Avatar
it would still need to be made aware of lav and what it can do
Carpo is offline
Old 15th June 2012, 16:23   #11659  |  Link
ramicio
Banned
What?
ramicio is offline
Old 15th June 2012, 16:26   #11660  |  Link
Carpo
Carpo's Avatar
you cant just drop a dll in the folder and expect it to know what LAV is and what lav can do, avcodec-lav-54.dll which is the lastest version that comes with LAV filters may have changed from the version that comes with eac3to and cause errors
Carpo is offline
eac3to
