Old 15th October 2022, 11:45   #501  |  Link
gpower2
gMKVExtractGUI author
gpower2's Avatar
Originally Posted by tormento View Post
I have just noticed that if you set
{FilenameNoExt} {Language} {TrackName}
and the trackname is empty, it keeps the space after {Language}, leading to a filename .ext format.
Would you please fix that?
Hey Tormento, indeed I could do a final Trim in the filename before appending the extension, thanks for the feedback
gpower2 is offline   Reply With Quote
Old 15th October 2022, 11:46   #502  |  Link
gpower2
gpower2's Avatar
Originally Posted by RyFeR26 View Post
Long time user of this great tool as well for many years, thanks for creating and maintaining it!
I do have a question: would it be possible to add an option to be able to select a specific subtitle language that is then always selected automatically when opening a video file?
Example: when I select Dutch (DUT) as standard subtitle language, opening an .mkv with many subtitles would have DUT selected by default.
Hey RyFeR26, at the moment I don't want to add any more complexity to the UI, by adding more options/settings, as it could lead to a more cluttered design, sorry for that.
Hopefully the right click menu can help you easily select all Dutch language elements.
Old 18th October 2022, 14:25   #503  |  Link
tormento
Acid fr0g
tormento's Avatar
You are the most welcome.
What about having the project on github?
@turment on Telegram
Old 22nd October 2022, 15:13   #504  |  Link
RyFeR26
Selecting via that way works as well, thanks for the reply.
RyFeR26 is offline   Reply With Quote
Old 29th January 2023, 07:24   #505  |  Link
oniiz86
@gpower2 I was wondering if this will be implemented soon in v2.6.4 or not worth the effort until there are a quite a few further refinements needed to be added?
oniiz86 is offline   Reply With Quote
Old 29th January 2023, 13:32   #506  |  Link
gpower2
gpower2's Avatar
Hey guys!
Another new year, another release!
Thanks to @tormento's feedback, I released a new minor version to address the issue with having spaces in output file names when a pattern placeholder is empty.
As always, enjoy!
Download link:
https://sourceforge.net/projects/gmk....4.7z/download
Changelog
v2.6.4
  • Minor code optimizations
  • Add final Trim when generating the output filename (thanks tormento!)
Old 29th January 2023, 16:07   #507  |  Link
filler56789
SuperVirus
filler56789's Avatar
«Your software patents have expired.»
filler56789 is offline   Reply With Quote
Old 1st February 2023, 09:00   #508  |  Link
oniiz86
@gpower2 so very much for the swift update, once again the mods have yet to update the title thread to v2.6.4
Old 15th February 2023, 22:14   #509  |  Link
Bigmango
There are some gui sizing problems with scaling at 150% on hidpi (4k) screens (this is on linux with mono).
See the attached screenshot.
(it displays fine at 100%)
Could you please fix this ? Many
Bigmango is offline   Reply With Quote
Old 16th February 2023, 04:23   #510  |  Link
kedautinh12
Add images to other image sources like https://imgur.io/ or you will waiting for approvaled by moderator forever
Old 27th February 2023, 12:34   #511  |  Link
gpower2
gpower2's Avatar
Sorry for the late reply @Bigmango, unfortunately it seems that mono does not respect the DPI aware code the same way as Windows do, I cannot guarantee I will be able to fix this issue, since I need to setup a new Ubuntu box for testing.
Old 5th March 2023, 04:26   #512  |  Link
badshah
badshah's Avatar
From version 2.6.0 to latest version, all are showing Trojan.Malware.300983.susgen infection after scanning on virustotal
https://www.virustotal.com/gui/file/...21d88c66488d39
badshah is offline   Reply With Quote
Old 5th March 2023, 09:40   #513  |  Link
Zetti
Not now, maybe earlier.
Check the resuilt again.
Zetti is offline   Reply With Quote
Old 10th March 2023, 07:29   #514  |  Link
gpower2
gpower2's Avatar
This is possibly a false positive from the heuristics of MaxSecure, since the rest 59 AV vendors have no issues.
In any case, this is an open source project, so feel free to download and build the source code yourself in case you feel uneasy with the pre-build binaries.
Old 15th May 2023, 18:41   #515  |  Link
Perenista
Does gMKVExtractGUI also have a Mac version? If not, what software would do the same tasks for Mac users?
Perenista is offline   Reply With Quote
Old 17th May 2023, 22:52   #516  |  Link
gpower2
gpower2's Avatar
In theory, it could run via Mono in Mac, but I haven't been able to set up a VM with OSX to test it...
You could try and give it a go and post your results here
Old 28th May 2023, 23:01   #517  |  Link
Lathe
Lathe's Avatar
Hey guys!
As always, enjoy!
Download link:
Changelog
v2.6.4
Hey Bro! I just stumbled on this thread because I was doing a search about MKVExtract seemingly running slower than usual lately. Not a huge deal, but noticeable. I normally don't do anything really exotic with it, usually just extract EAC3 audio tracks to convert them to AC3 for my old OPPO player to be able to play them. If that is all I do with it, should I still try your version here? If I do, do I put your files in its own program folder, or do I somehow associate it with MKVMerge?
Thanks kindly for your advice and help!
Lathe is offline   Reply With Quote
Old 29th May 2023, 01:23   #518  |  Link
gonca
Yes.
The first time you run it, it will throw an error.
Click OK.
Then you get the chance to browse to MKVToolNix.
From here on it is clear sailing.
gonca is offline   Reply With Quote
Old 9th October 2023, 10:12   #519  |  Link
gendalv
Can you add simple filters like: show only entries containing "sub" & "eng" but not "SDH". Or at least the first part of it.
gendalv is offline   Reply With Quote
Old 8th November 2023, 11:03   #520  |  Link
morphinapg
ASXGui Developer
morphinapg's Avatar
Is there any way to get this to work with the Windows Store version of mkvtoolnix? If I find the directory that the exe files are located in, it gives me access denied errors. If I modify permissions on the mkvtoolnix folder (which is a little difficult compared to usual) then it works, but then it breaks mkvtoolnix until I uninstall it and reinstall it again.
ASXGui 2.5 / Installer
Thread / All Downloads
morphinapg is offline   Reply With Quote
extractor, gmkvextractgui, matroska, mkv, mkv extract, mkvextract, mkvextractgui
