6th February 2016, 09:26 | #20361 | Link |
OGM is a broken format, I wouldn't expect many improvements, sorry.
6th February 2016, 23:47 | #20362 | Link | |
I assume, and hope, the w3fdif filter is different.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
7th February 2016, 10:46 | #20363 | Link |
I have tested all of betas in 0.67 series and catch such an issue with some of sources.
704x576 AVC (High@L3 CABAC / 4 Ref Frames) Release version LAV 0.67 just fine, but beta versions are buggy. Last edited by Alexey1975; 7th February 2016 at 11:04. |
7th February 2016, 11:50 | #20364 | Link |
As always, please provide a sample, otherwise there is nothing I can do.
7th February 2016, 11:59 | #20365 | Link |
Excuse me, here it is http://www.ex.ua/98151805 the stream dump.
(DVBViewer 5.5.2.0 + MadVR 0.90.4 + LAV 0.67.0.76) Last edited by Alexey1975; 7th February 2016 at 12:05. |
7th February 2016, 12:10 | #20366 | Link |
Sorry, but your link doesn't work.
7th February 2016, 12:20 | #20367 | Link |
Sorry, try this link https://yadi.sk/i/RfCr6RnMoSDhL
7th February 2016, 12:41 | #20368 | Link | |
7th February 2016, 12:55 | #20370 | Link |
It breaks only in DXVA2 mode apparently. I get the same issue with 0.67.0 however, and with 0.66 and 0.65.
Same problem with Microsofts DXVA decoder. Seems like either the stream is not compatible with DXVA for some reason, or its a hardware/driver issue.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 7th February 2016 at 13:00. |
7th February 2016, 13:06 | #20371 | Link |
Just right now I rollback to the release version and it works just fine. I hope this strange things don't float up into the next release - I just want to help the beta testing. Thank you for attention.
7th February 2016, 13:16 | #20372 | Link |
From what I can tell it never worked with DXVA2, same result in all recent release versions.
And like I said in my previous post, same result using the Microsoft decoder as well. Software Decoding is perfectly fine however.
7th February 2016, 14:19 | #20375 | Link | |
One simple explanation would be that earlier LAV versions for some reason just didn't use DXVA for you, because Software decoding works. In any case, unless I can find one DXVA decoder that actually works, I have no proof that its actually supposed to work, and no starting point where to start poking.
7th February 2016, 15:00 | #20376 | Link | |
7th February 2016, 17:29 | #20378 | Link |
Hello.
Intel (HD6200) also working just fine.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
7th February 2016, 21:38 | #20379 | Link | |
One thing that differentiates those two interlaced H.264 files, from all the "common" files that work fine using Nvidia HW decoder is this according to MediaInfo: Color primaries : BT.601 PAL Transfer characteristics : BT.470 System B, BT.470 System G Matrix coefficients : BT.601 My other H.264 interlaced samples are BT.709, but I really don't know if that means something.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
7th February 2016, 21:53 | #20380 | Link | |
