2nd March 2017, 12:25 | #1801 | Link | |
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
2nd March 2017, 13:04 | #1802 | Link |
@Magik Mark: Thanks for log file. It looks like there is something wrong with first pass. x265 complains about input file.
I've checked your options and it works, but the 'x265_analysis.dat' file is in current working directory -- you specify '--stats' option but not '--analysis-file' option. My first impression is that it is StaxRip issue with reading/decoding video. |
2nd March 2017, 16:33 | #1803 | Link | ||
The QSVEncC help doesn't contain '2020', you can find the mail address of rigaya on his blog.
http://rigaya34589.blog135.fc2.com/b...tegory-10.html Quote:
Since Mark said it only happens sometimes I would guess it has to do with AviSynth multi-threading and there is little I can do, it would probably also happen when the batch file StaxRip generates is run outside of StaxRip.
2nd March 2017, 16:35 | #1804 | Link |
Don't forget to add in your first page the addition of AMD H.265 encoder.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
2nd March 2017, 16:44 | #1805 | Link |
I've reset it now, staxrip moves the old video encoder profiles to a backup sub menu.
2nd March 2017, 16:45 | #1806 | Link |
No, I meant here, the first page of this thread
2nd March 2017, 16:52 | #1807 | Link |
ah, changed that too, thanks.
2nd March 2017, 20:36 | #1808 | Link | |
If StaxRip works now: Code:
IF '--pass' option THEN add option '--stats "output_file_name.stats"' FI Code:
IF '--pass' option THEN add option '--stats "output_file_name.stats"' IF '--multi-pass-opt-analysis' OR '--multi-pass-opt-distortion' option THEN add option '--analysis-file "output_file_name.analysis"' FI FI |
2nd March 2017, 23:13 | #1809 | Link |
Thanks Ma for clarifying. I hope stax can incorporate that to the new build
2nd March 2017, 23:45 | #1810 | Link | |
3rd March 2017, 07:13 | #1811 | Link |
please help. staxsrip gives an error "cuvid: Parsed header too large!"
please help. staxsrip gives an error at the stage of video encoding. More precisely the error causes the decoder. I tried all the available options.
Error: Encoding using NVEncC 3.06 x64 failed with exit code: 1 (0x1) cuvid: Parsed header too large! failed to init decoder. script: C:\Users\Andrey\Downloads\StaxRip-x64\Apps\NVEncC\NVEncC64.exe --cqp 18:20:22 --codec h265 --output-depth 10 --lookahead 32 --qp-init 1 --max-bitrate 30000 --aq --output-buf 128 -i D:\temp\temp.mkv -o D:\temp\temp_temp\temp_out.h265 |
3rd March 2017, 09:55 | #1812 | Link |
@Ma
Thanks for the clarification. @Mark It will be fixed in the next build. @slushay You can report it to rigaya, is mail address is on his blog. http://rigaya34589.blog135.fc2.com/b...tegory-10.html
3rd March 2017, 11:21 | #1813 | Link | |
thanks
It is now writing a letter to rigaya. |
3rd March 2017, 12:36 | #1814 | Link |
Hello Frank,
A few other apps need to be updated x264 v.2762 MediaInfo v.0.7.93 FFmpeg v.3.2.2 DGIndexNV v.2053 Qaac v.2.62 L-Smash-Works (avs) v.924 Java v.121 Last edited by Alexander; 3rd March 2017 at 12:39. |
3rd March 2017, 14:40 | #1815 | Link |
Hello again.
I don't know how hard is it to add in your Media Info tool just one more column. It's called "Color primaries" and it has a value of BT.2020 when the clip is HDR. I can see that property in "tree" mode.
4th March 2017, 20:26 | #1816 | Link |
NikosD can you tell me what might be the best way to encode 1080i recorded tv channel with many fast motions? Source file is: *.ts, around 6.686 kb/s, 2h long, 6,5GB. I need to produce smaller size file maintaining good quality.
In your opinion, what is the best choice in terms of encoding scheme: LA-VBR Lookahead, VBR only, LC-ICQ (which preset - 17? file is too large), maybe QVBR? Bitrate would be 4.000 kb/s. I got Intel Core i7-6820HQ. Barty |
4th March 2017, 20:29 | #1817 | Link |
From all of my tests using QSVEnc I had decided that plain ICQ even with no lookahead was totally fine.
You could try --scene-change (but not with ICQ IIRC) and lookahead, but I was happy with plain ICQ.
4th March 2017, 20:42 | #1819 | Link |
Are you going to convert your interlaced file to progressive ?
Then I think you can't avoid the 50fps to 25fps conversion. But IIRC, QSVEnc supports interlaced encoding and you could leave it interlaced at 50fps
