24th March 2014, 07:58 | #21 | Link |
For 720p->1080p upscaling I'm currently using LumaSharpen pre-resize with nnedi image doubling in madVR. I have it set to low levels. Just enough to take out the softness from upscaling but still being a noticeable improvement. nnedi is a really great upscaler, I highly recommend it if your card can handle it. It's very sharp with basically no ringing or aliasing.
#define sharp_strength 0.5 #define sharp_clamp 0.05 #define pattern 3 Last edited by StinDaWg; 24th March 2014 at 08:01. |
24th March 2014, 14:22 | #22 | Link | |
For a area that is 3 x 3 pixels you could have a kernel like this : Code:
000 010 000 The above kernel samples 1 time from the center pixel and nothing from the surrounding 8 pixels. This yield the exact same picture as before. Code:
000 100 000 Since the kernel is applied to every pixel in the image, you have just moved the entire image one pixel to the left. Easy enough but not that useful Code:
111 111 111 Adding 9 numbers together and dividing by 9 is just averaging them together - and averaging the center pixel by it's surrounding 8 pixels like this blurs the image. This link explains it well and comes with a tool you can play with to make your own convolution kernels For pattern 2 i use a kernel that is : Code:
121 141 121 In the link above try the kernel : Code:
-1, -2, -1 -1, 21, -1 -1, -2, -1 This looks much too sharp which I why I limit the sharpening so it never goes above a certain amount. I think the most important part of a sharpening filter is not so much how you sharpen, but how you decide how much to sharpen. |
25th March 2014, 14:31 | #25 | Link | |
However with the newer MPC builds this problem have gone away and I no longer use it, because other than speed the two patterns (2 and 8) are identical. Pattern 9 is likewise just a slower version of pattern 4. I keep them in the code because it easy to prototype new convolution kernels when you just need to change a few numbers rather than write that code again. Once I'm satisfied with a kernel I can always find the most optimal way to take those samples at a later time. To activate the new limiter you need to modify the code. Looking at it quickly it looks like you can change : Code:
#if 0 //New experimental limiter .. not yet finished Code:
#if 1 //New experimental limiter .. not yet finished Pixels with some contrast are given more sharpening because these are details we want to enhance. And finally pixels with a lot of contrast, we don't wan't to sharpen very much or not at all because they already have plenty of contrast and giving them more makes the image look fake and over-sharpened. Here is a graph of the sharpening with the old clamp (f4) and the new limiter (f2) The X-axis shows difference in brightness to the original and the Y-axis is the sharpening strength. Pixels that are brighter than their surroundings are made even brighter and pixels that are darker are made even darker. Pixel with the same brightness (0,0 in the graph) are not touched It's experimental because I want to find a good formula that allows the user to tweak the max sharpening, when it slopes up in strength and when it slopes down but a good tweakable formula is hard to find. The best I can currently do is tell you to change the / 16 at the end. A smaller divider gives a greater max strength and a greater gives a small max strength. A good limiter formula should be easy to tweak and understand - this one is not (yet). I wonder what limiter formula Didee uses for his LimitedSharpen (I can look at the code but I don't understand avisynth code). In case you are curious - the #elif 0 //SweetFX 1.4 code and #else //SweetFX 1.5.1 code do the same thing. It clamps the sharpening. The 1.5.1 code just does it using 1 instruction less, by moving some of the math into other parts of the code to utilize the available instruction lanes better. I kept the older code around for reference because the new code while faster is also harder to comprehend for anyone trying to understand what the code does. Last edited by CeeJay.dk; 25th March 2014 at 14:52. |
25th March 2014, 21:55 | #27 | Link |
Thanks for the info on convolutions CeeJay.dk I'll play around with it when I find some more time in the next few weeks.
After a quick initial test with experimental limiter it doesn't seem right for me, it's noticeably softer and low contrast edges (mainly faces) is what I notice most. I've noticed banding shows much more with lumasharpen because of it but debanding can solve that mostly. What about if there's very small differences in edges within a large radius don't sharpen, otherwise do?
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 |
28th March 2014, 16:34 | #28 | Link |
I've noticed that using this shader boosts contrast, and makes the picture brighter overall. It's especially noticeable on white text, there is a glowing effect. I don't like that. Is there anyway to modify the values to reduce or eliminate the contrast boost while still sharpening? It's not nearly as bad as the Sharpen Complex MPC-HC shader, or even unsharp mask, but it's something that really bothers me and is putting me off from using this full time.
28th March 2014, 22:48 | #29 | Link |
StinDaWg have you tried the experimental limiter? It noticeably reduces sharpening of high contrast edges. I don't notice an overall contrast increase but the high contrast edges are definitely higher contrast with the default clamping.
29th March 2014, 03:54 | #30 | Link |
I tried it, that didn't change the brightness/contrast boost for me. Like I said it's not severe like MPC Sharpen Complex, but it's still quite noticeable. I don't know if this is just a side effect of doing this method of sharpening (unsharp mask), or if there are other methods (Darbee?) that do it without the contrast boosts.
30th March 2014, 18:35 | #31 | Link |
Hello I really would like to try the lumasharpen shader as it has so many good feedback... However I am not sure that I do it correctly as I do not see a huge difference with or without it.... For example if I select it 5 or 6 times consecutively in pre resize there is no difference and it offer the same results than if I would have selected it only once??? Is it normal? If a do the same with sharpen complex the sharpen is so strong that the picture is unwatchable....
Envoyé de mon GT-I9300 en utilisant Tapatalk |
30th March 2014, 19:29 | #32 | Link |
@yok833
You are posting this question in multiple places. That is called cross-posting and it is not allowed here, per forum rules. Please read and follow our rules to avoid strikes. Thank you for your understanding. Follow up to PM if needed, please. |
30th March 2014, 21:22 | #33 | Link | |
The dark or bright edges that strong edges get sometimes. Sharpen Complex and SweetFX both do an unsharp mask filter, but SweetFX limits this using the sharp_clamp. Try lowering the clamp until it no longer annoys you. The idea with the experimental limiter was to reduce that even further but I don't think i have the formula right yet, judging from the feedback. More work is needed in this area. It would also be possible to limit the sharpening in other ways. LimitedSharpen by didee has a min/max option where the filter finds the minimum and maximum values of the surrounding pixels and uses those values as the clamp values that the sharpening is not allowed to go beyond. This is not as fast (SweetFX is written primarily for games so speed is important to me) and it also limits the sharpening, but it should eliminate the possibility of halos. |
30th March 2014, 21:26 | #34 | Link | |
Adding the same filter many times is not the right way to get a stronger effect. |
31st March 2014, 02:39 | #35 | Link |
Agreed, it looks a little surreal in both games and video. It's seems to emphasize bright whites too much. The limiter seems to be a good idea though. I always tend to think sharpeners rely too heavily on higher contrasts. It reminds me of the early SD to BD resizing attempts.
31st March 2014, 07:15 | #36 | Link | |
Post-resize Code:
#define sharp_strength 1.5 #define sharp_clamp 0.015 #define pattern 3 #define offset_bias 1.0 #define show_sharpen 0 |
31st March 2014, 21:39 | #37 | Link |
Has anyone else raised offset_bias and reduced strength?
Currently using strength 1.0, clamp 0.5, pattern 3, bias 3.0 and getting good results. Raising bias seems to have a great effect on lower contrast edges with little effect on high contrast edges. Just what I've been looking for.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 31st March 2014 at 22:13. |
31st March 2014, 22:05 | #39 | Link |
I've been using it pre and post resize for a few months now but trying to switch to post-resize only because on sharpening dirty SD sources pre-resize sharpening creates artifacts. In order to get the sharpening I was able to get from pre+post with post only I have to turn the strength up to 8.0+ which shows a lot of high contrast artifacts until I raised offset_bias and dropped strength.
