Old 18th June 2010, 00:09   #1941  |  Link
rica
First trial result: unsuccesful.
From an Iso file created by ImageBurn.
EDIT: sorry, i need Haali as well, correct?
rica is offline   Reply With Quote
Old 18th June 2010, 00:10   #1942  |  Link
SamuriHL
SamuriHL's Avatar
Nope, don't do that. It should be done only from an original disc. It will NOT work on something that's been touched by tsMuxer.
Old 18th June 2010, 00:12   #1943  |  Link
rica
So, forget it
EDIT: I removed makemkv.
Old 18th June 2010, 00:14   #1944  |  Link
SamuriHL
SamuriHL's Avatar
To each their own. I'm just happy that ffdshow can give us bitstreamed audio and dxva video and subs from these MKV's. I don't care how they're created as long as they work.
Old 18th June 2010, 00:21   #1945  |  Link
rica
Originally Posted by dbone1026 View Post
Any reason to use Solveig over the MPC splitter (Matroska)? Neither support PGS but aside from that MatroskaSplitter.ax has been rock solid. Always good to have choices
I think Samuri gave the right answer:
Old 18th June 2010, 00:24   #1946  |  Link
SamuriHL
SamuriHL's Avatar
I've tried on many of my tsMuxer made movie only ISO's. Not one of them worked. It'll work from an unmodified, full ISO, but, not from a movie only ISO made from tsMuxer. No idea what's up with that.
Old 18th June 2010, 00:31   #1947  |  Link
rica
I'd prefer to wait Solveig guys to implement a new version.
I made the comparison between Haali and Gabest before, as you remember?
I'd say it's a commercial SW finally.
Old 18th June 2010, 07:58   #1948  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Jeez, we're way off-topic now...
Perhaps one of the moderators should split our "non-audio" and "muxing" posts into a new thread
Old 18th June 2010, 11:43   #1949  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Originally Posted by Mosu View Post
mkvmerge will get raw PGS input support in the near future though.
And here's such a build: http://www.bunkus.org/videotools/mkv...-270-setup.exe
Please direct any comment to the mkvtoolnix support thread. Bugs, ideas etc about mkvtoolnix are pretty off topic in this one. Thanks.
Latest MKVToolNix is v83.0
Mosu is offline   Reply With Quote
Old 18th June 2010, 14:18   #1950  |  Link
SamuriHL
SamuriHL's Avatar
OMG, thank you! Will try it out and post feedback in the mkvtoolnix thread.
Old 18th June 2010, 14:55   #1951  |  Link
SamuriHL
SamuriHL's Avatar
@albain
Need some help understanding something.
00000516	0.50900584	[4972]  WAVEFORMATEXTENSIBLE :
00000517	0.50900584	[4972]  subFormat : KSDATAFORMAT_SUBTYPE_IEC61937_DTS_HD
00000518	0.50900584	[4972]
00000519	0.50900584	[4972]  wSamplesPerBlock : 16
00000520	0.50900584	[4972] Valid bits per sample : 16
00000521	0.50900584	[4972]  dwChannelMask : 255
00000522	0.50900584	[4972]
00000523	0.50900584	[4972]  WAVEFORMATEX :
00000524	0.50900584	[4972]  wFormatTag : WAVE_FORMAT_EXTENSIBLE
00000525	0.50900584	[4972]  Channels : 8
00000526	0.50900584	[4972] Bits per sample : 16
00000527	0.50900584	[4972]  Samples per second : 192000
00000528	0.50900584	[4972]  nBlockAlign : 16
00000529	0.50900584	[4972]  nAvgBytesPerSec : 3072000
00000530	0.50900584	[4972]
00000531	0.57470566	[4972] no picture
00000532	0.57473069	[4972] TffdshowDecAudio::deliverSampleBistream Delivering IEC sample format type 1041 - sample size 2468 - buffer length 32768
00000533	0.57481670	[4972] TDXVADecoder::PostProcessFrame  0
00000534	0.57980877	[4972] Media Type Structure
00000535	0.57980877	[4972]  Format type : FORMAT_WaveFormatEx
00000536	0.57980877	[4972]  Sub type : MEDIASUBTYPE_PCM
00000537	0.57980877	[4972]
vs
00000514	0.28720888	[1324]  WAVEFORMATEXTENSIBLE :
00000515	0.28720888	[1324]  subFormat : KSDATAFORMAT_SUBTYPE_IEC61937_DTS_HD
00000516	0.28720888	[1324]
00000517	0.28720888	[1324]  wSamplesPerBlock : 16
00000518	0.28720888	[1324] Valid bits per sample : 16
00000519	0.28720888	[1324]  dwChannelMask : 255
00000520	0.28720888	[1324]
00000521	0.28720888	[1324]  WAVEFORMATEX :
00000522	0.28720888	[1324]  wFormatTag : WAVE_FORMAT_EXTENSIBLE
00000523	0.28720888	[1324]  Channels : 8
00000524	0.28720888	[1324] Bits per sample : 16
00000525	0.28720888	[1324]  Samples per second : 192000
00000526	0.28720888	[1324]  nBlockAlign : 16
00000527	0.28720888	[1324]  nAvgBytesPerSec : 3072000
00000528	0.28720888	[1324]
00000529	0.28730148	[1324] TffdshowDecAudio::deliverSampleBistream Delivering IEC sample format type 1041 - sample size 2468 - buffer length 32768
00000530	0.28738225	[1324] Media Type Structure
00000531	0.28738225	[1324]  Format type : FORMAT_WaveFormatEx
00000532	0.28738225	[1324]  Sub type : MEDIASUBTYPE_PCM
00000533	0.28738225	[1324]
See in the first one is say "No picture"? What does that mean?
Old 18th June 2010, 15:11   #1952  |  Link
clsid
That's probably video related.
MPC-HC 2.2.1
Old 18th June 2010, 15:16   #1953  |  Link
SamuriHL
SamuriHL's Avatar
I agree. But the interesting part is that's the difference between the mkvmerge created file (bottom log) that breaks up and doesn't play and the makemkv made file (top log) that works flawlessly. They SHOULD be identical because I took the makemkv made file and used that as input for mkvmerge. Using haali, the mkvmerge file doesn't work. Just trying to figure out why.
Old 18th June 2010, 20:05   #1954  |  Link
liquidskin76
liquidskin76's Avatar
I was thinking a month or so ago... I could have sworn haali worked during the beta testing for ffdshow HD audio bitstreaming.
Do you remember samuri, seb, rica?
I've tested old builds of haali and ffdshow (right back to the first release of HD audio bitstreaming) however no luck.
liquidskin76 is offline   Reply With Quote
Old 18th June 2010, 20:08   #1955  |  Link
SamuriHL
SamuriHL's Avatar
No, it never worked. For DTS-HD MA anyway. It works fine for TrueHD. And it works fine for DTS-HD MA MKV's made with MakeMKV. I can't get Haali to split DTS-HD MA m2ts/ts files so I can't test that. Honestly, at this point, I'd be SUPER FREAKING PSYCHED if the MPC splitter was updated to handle PGS subs in MKV's. I'm seriously.
Old 19th June 2010, 07:23   #1956  |  Link
SeeMoreDigital
Indeed...
When was MPC's splitter (or splitters) last updated? I ask because PGS subs in .M2TS files appear to work!
Old 19th June 2010, 11:50   #1957  |  Link
dbone1026
Originally Posted by SeeMoreDigital View Post
Indeed...
I submitted a feature request on the MPC HC thread regarding adding support for PGS with the MPC splitter. Hopefully someone is listening!!!
Cheers,
Damian
Blog - http://www.adigitalhomeblog.com
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
dbone1026 is offline   Reply With Quote
Old 19th June 2010, 14:30   #1958  |  Link
SamuriHL
SamuriHL's Avatar
Yea, it supports PGS in m2ts, just not MKV, so, "in theory" it shouldn't be too difficult to add it.
Old 19th June 2010, 21:43   #1959  |  Link
DrNein
What can cause LPCM to playback slow while video is normal speed? It is happening with both ffdshow and MPC-HC internal transform filter. HD bitstream is normal.
DrNein is offline   Reply With Quote
Old 20th June 2010, 21:44   #1960  |  Link
Sebastiii
Casimir666 has added support for MPC Matroska Splitter for PGS sub today
Thanks to him
And it's working great
Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355.
Sebastiii is offline   Reply With Quote
