Old 24th November 2008, 15:15   #301  |  Link
rack04
Does anyone have a sample m2ts or evo with subtitles that I could experiment with? Here is one that I initially tested but it's really to short to get any good practice with.
rack04 is offline   Reply With Quote
Old 24th November 2008, 15:47   #302  |  Link
GZZ
You can create your own bluray subtitle in TSmuxer from at SRT file or if you have a HD-DVD/Bluray you can demux a subtitle from.
GZZ is offline   Reply With Quote
Old 29th November 2008, 11:54   #303  |  Link
Zorg
<b> and <i>
Is it possible to add to TSmuxer the bold and italics processing in srt files? I'd guess it's not a big problem.
EDIT: Apparently it was not I found a version of TSmuxer 1.8.8 which is able to do this! (unofficial?I thought there was 1.8.4b so far...)
http://www.videohelp.com/download/tsMuxeR_1.8.8b.zip
Zorg is offline   Reply With Quote
Old 13th January 2009, 09:28   #304  |  Link
wangchuanyan1982
have you successed?
Originally Posted by Rectal Prolapse View Post
I'm wondering if this is possible yet.
I've tried ripping the data from a bluray disc's .m2ts file. I believe that PIDs starting from 1200 are the subtitle streams, but I have no idea what to do with them.
Anyone have any information on how to convert them to SRTs? Or where I can find the format specifications for them?
i am doing the same work ,could you support some info for me ,thank you
wangchuanyan1982 is offline   Reply With Quote
Old 13th January 2009, 19:27   #305  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
http://www.videohelp.com/tools/SUPread
I think supread is what your after.
B4tm4n is offline   Reply With Quote
Old 14th January 2009, 17:35   #306  |  Link
Rectal Prolapse
wang, don't worry about that - supread or suprip will work for you.
Rectal Prolapse is offline   Reply With Quote
Old 15th January 2009, 08:01   #307  |  Link
wangchuanyan1982
have some problem with pgs
i want to know the format of pgs ,
15 85 6e 0 0 0 c0 0 85 67 3 5f 0 95 0 92 ff 1e 32 0 c3 4b ff 0 0 0
the above ii think is first line of the sub bitmap,how can i translter it ,
15 is identifier
85 6e is the size of section
0 0 ls one line end
but how ls the RLE in this ,i can not guess it ,could you help me ?thank you very much!
Old 15th January 2009, 08:03   #308  |  Link
wangchuanyan1982
More:
00 03 = The next 3 pixels use color index 0.
00 01 = The next pixel is color index 0.
So, basically, 00 is reserved as an RLE command. To get the color 0 you need to do the above.
Given the above, here are some examples:
00 47 80 00 00 00 42 0F 0E 14 00 84 FE 14 0E 00 0F
Breaks down into:
00 47 80 = 1920 pixels of color 0.
00 00 = end of line, go to the beginning of the next line.
00 42 0F = 527 pixels of color 0
0E = pixel at x location 528 is color 14.
14 = pixel at x location 529 is color 20.
00 84 FE = the next 4 pixels are of color 254.
14 = the next pixel is color 20.
0E = the next pixel is color 14.
00 0F = the next 15 pixels are color 15.
This will go on until 1920 pixels for the line have been specified, and shall end in a 00 00 pair.
Now, not all subpictures will be 1920 pixels across - this depends on the header before the bitmap info.
16 0 13 7 80 4 38 40 0 0 80 0 0 1 0 0 0 0 2 11 3 6c
17 0 a 1 0 2 11 3 6c 3 5f 0 95
14 1 42 0 0 1 da 80 80 ff .......3f 10 80 80 a7 40 6e 80 80 ff
what about this ?some different?
Old 16th January 2009, 22:14   #309  |  Link
Rectal Prolapse
Oh - you didn't clarify you wanted to know the binary format of a .sup file.
Unfortunately you will need to purchase the full Blu-ray specification - the information I posted is incomplete!
You could look at the MPC-HC (Media Player Classic - Home Cinema) source code for how to decode the PG streams though. Look for the thread here on doom9 about that player:
http://forum.doom9.org/showthread.php?t=123537
Old 19th January 2009, 04:13   #310  |  Link
wangchuanyan1982
thank you
thank you
Old 8th March 2012, 05:30   #311  |  Link
Rectal Prolapse
New tool for Blu-ray sup files:
http://forum.doom9.org/showthread.php?t=164370
Old 25th October 2016, 12:49   #312  |  Link
Nibbio
Nibbio's Avatar
I need the same answers. Thank you for the topic, guys.
To exchange video urls without third party interference use www.urlcrypt.to
Nibbio is offline   Reply With Quote
