7th August 2007, 12:59 | #1261 | Link |
Mr. Sandman
i meant the vfw builds are not good to be used with megui
im sorry, but im not sure i correctly understood what you mean
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 7th August 2007 at 13:02. |
8th August 2007, 13:25 | #1265 | Link |
L.A.M.E. developer
There seems to be a little problem with audio encoding:
Starting job job1 at 13:15:46 Starting preprocessing of job... Preprocessing finished! Calling setup of processor failed with error Required file 'C:\Program Files\megui\tools\encaacplus\encaacplus.exe' is missing. Looking for job processor for job... Processor found! There is no encaacplus.exe, but only enc_aacPlus.exe |
10th August 2007, 07:56 | #1268 | Link |
Updated to newest megui 0.2.5.1007 today and now everytime i try and load an avi into the avisynth script creator it causes megui to crash and this is the error code i receive when i click vew details..ive never had a problem in the past using the script creator and then using an avi for the source file
Problem signature: Problem Event Name: APPCRASH Application Name: megui.exe Application Version: 0.2.5.1007 Application Timestamp: 468b58e7 Fault Module Name: StackHash_2a66 Fault Module Version: 6.0.6000.16386 Fault Module Timestamp: 4549bdc9 Exception Code: c0000374 Exception Offset: 000af1c9 OS Version: 6.0.6000.2.0.0.256.1 Locale ID: 1033 Additional Information 1: 2a66 Additional Information 2: 6451a58300378d3769e578402fe758f6 Additional Information 3: 205a Additional Information 4: 950d3000e02e7a6a4a34d87b655ae806 Read our privacy statement: http://go.microsoft.com/fwlink/?link...3&clcid=0x0409 |
12th August 2007, 01:07 | #1270 | Link |
Since berrinam hasn't been around for a while, here is a build with the prerender job bug fixed, since a couple of people seem to need it: http://www.mediafire.com/?8ncvvuy1gjn
I also added a "Do all and close" button to the AVS cutter which will just add cuts, save the cutfile (with same name as AVS) and close without all the dialogues (provided there are no issues). If it's worth it I'll submit patches to SF, but in the mean time get them here: http://www.mediafire.com/?ddr9logmzin |
12th August 2007, 08:45 | #1271 | Link |
I have 2 problems with my MeGui - it's a clean install with the new computer and all - 0.2.5.1007 the 1st problem I experienced with my old computer as well - I load an avs script - the picture comes up with the "player" thingy in the middle of the video clip - and once I click on the "X" it freezes - what I do is I click on enque, exist megui, re-enter it and just hit start on the queue. The 2nd problem - the REAL problem, is that now 99% of the times, it will hit 99.97% in the encode - and will not go any further. It drives me crazy. Could somebody please help or refer me to somebodys post similiar to this or something? Thanks. Edit1: I did a search and this one guy seems to have had the same problem I'm having: http://forum.doom9.org/showthread.ph...ht=megui+stuck I'll try to remove the VSFILTER stuff as well and see what's up, that might solve the 2nd of my problems... Though, I'm not quite certain what I'll be doing to make it work with it, since I DO need the subs attached lawl... ATM - out of my head, I am guessing I might need to add japanese to this computer - as I had it on my previous one... Speculations... Last edited by DarkT; 12th August 2007 at 11:47. |
12th August 2007, 22:03 | #1272 | Link |
avc freak
hello,
when i start megui my screen starts flickering. Also when i get the preview when creating the avisynth script, and when i press crop, the black border dont turn white as they normally do. It happened when i installed staxrip. Staxrip was complaining about all kinds of wrong versions of programs and started downloading. It did work for me so i uninstalled it. I reinstalled megui and did the update. The codecs/decoders i have installed are ffdshow, coreavc and ac3filter. I have avisynth 2.5.7 Does any one know what the problem is and how i can fix it? thanks |
16th August 2007, 18:45 | #1273 | Link |
Firstly, hats off to the MeGUI team for the latest version, particularly updating the various components... its nice not having to manually download the latest versions of all the stuff. Also, its nice to have Cef's x264 build, and the new Mencoder build is sweet, too.
On to my issue: Using pre-render run with 1-pass constant quality. I've been doing most of encoding on my work laptop, since it has multiple cores... but recently my company installed a low-level encryption software that slows the HD access a bit, so I've been running various speed tests. One of the things I did was to run a CRF 22 encode two different ways: one with a separate pre-render run (2-part job), and one with a straight encode (1-part job). I realize that pre-rendering won't save you time on a 1-pass job, but comparing the results was kind of shocking: the 1-part job was 4 hours shorter. Job 1-1: 6:20:27 = 380.45 minutes Job 1-2: 5:34:08 = 334.13 minutes Total: 11:54:35 = 714.58 minutes Job 2: 7:50:58 = 470.97 minutes What accounts for this big difference? Does it have anything to do with using CRF? |
17th August 2007, 09:24 | #1274 | Link |
I'm trying to use VobSubber feature with last stable release.
The problem is that MeGUI just stops because it can't find vobsub.dll in system32. I can't find any information about this error. Any idea ? VSFilter.dll is in the AviSynth plugins directory. But what about vobsub.dll ? Where can I download it ? Thank you. Last edited by Deckard2019; 17th August 2007 at 09:41. |
17th August 2007, 12:03 | #1275 | Link |
Well I Would Like Rip A DVD Movie Which Is Of 4.36GB NTSC To X264 With MKV And Keeping ND AAC As The Audio.......And After Creating The d2v Files......Which One Do U Prefer To Encode First Audio Or Video?......And Its 3CD Rip....So I Need To Split It Into 3 Equal Sizes ...I Mean 700MB X 3......How To Split It Using MeGUI......And I Also Like To Mux The Chapters And The Subtitles........Well Does .srt Sublties CAn Be Muxed? Or The Orginal SubTitle Files Is Only Recommended... .....After Muxing All Theses Stuff Will I Get 700Mb Exactly... Is There Any Chance For The File Size To Get Increased.........
17th August 2007, 14:09 | #1276 | Link | |
Maximum bitrate too high
I opened MeGUI this morning, downloaded/installed the prompted update, and now I am getting the following error when I choose my profile:
"Sorry, the selected profile exceeds the AVC level you have specified Maximum Bitrate is too high" This is my profile used for encoding for PS3: Quote:
17th August 2007, 14:48 | #1277 | Link | |
Mr. Sandman
17th August 2007, 19:35 | #1278 | Link | |
21st August 2007, 15:46 | #1280 | Link |
Mr. Sandman
I've updated xvid_encraw (squid_80) and xvidcore.dll (celtic druid) with the latest versions available in both stable and development megui autoupdate trees. i've did some testing and it seems it's all ok, but if you encounter any problems with those, please shout here.
megui |
