Old 12th April 2010, 09:34   #61  |  Link
MvB
dings!
MvB's Avatar
Jack, I'm using mkv/x264.
That's a good idea splitting the movie. Thanks.
For this Hidef resolution vo 2560x720 i think it's the best choice qualitywise. The final movie with 2 audio tracks with crf=18 is abour 6-7GB and fits fine on a dvd9 in very good quality.
MvB is offline   Reply With Quote
Old 13th April 2010, 14:15   #62  |  Link
Jack-Bauer
Jack-Bauer's Avatar
Rolling back to anaglyphs..
For those (including me) who are not equiped with 3D hardware yet, please find below a method to play side-by-side movies in anaglyphs. It uses pre-compensation deghosting parameters adapted to your screen and glasses (similar to the so-called ghostbusting from realD).
The method can be used with any rendering technology, from anaglyphs to passive or shutter glasses, as long as you want to improve deghosting.
First, create an AVS file such as:
DirectShowSource("D:\movies\Nurburgring-sidebyside.avi")
Rcomp=0.05
Lcomp=0.07
R = crop(0,0,1280,0)
L = crop(1280,0,0,0)
Rc = merge(R,L.invert(),Rcomp)
Lc = merge(L,R.invert(),Lcomp)
stackhorizontal(Rc,Lc)
Then create this GRF file:
...and set the stereo filter output to "Optimised green-purple anaglyphs". Then import the GRF into your favorite player.
(for the audio graph, you can as well use the Reclock filter if you wish). The GRF file and the Rcomp/Lcomp parameters are always the same, only the first line of the AVS file must be patched for another title.
In my case, I set Rcomp=0.05 and Lcomp=0.07. I also had to lower the black level using ffdshow's picture properties: Luminance offset=-17 (ffdshow video processor is called by the AVS file)
With these values, I get absolutely no ghosting (except in black areas of course, as it is cut off - the drawback of realD's ghostbusting...).
The parameters values depend on your screen type and glasses (I personally used my "Journey to the center of the earth" genuine cardboard green-magenta glasses).
EDIT: You can use my test clip: http://membres.multimania.fr/chrono2...sidebyside.avi (use right click - saveas...)
Close one eye: If you see ghosting, try to adjust the matching parameter. Same for the other eye.
Jack
Jack-Bauer is offline   Reply With Quote
Old 19th August 2010, 22:44   #63  |  Link
MvB
dings!
MvB's Avatar
@jack
Did you get your dual projector setup yet?
Old 24th August 2010, 10:54   #64  |  Link
Jeremy Duncan
Didée Fan
Jeremy Duncan's Avatar
Check out my thread for green magenta: link
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity.
Jeremy Duncan is offline   Reply With Quote
Old 23rd August 2011, 19:34   #65  |  Link
2005sylvain
@jack-bauer except for the last script u can use it with any video program even virtualdub.
And thanks a lot to MvB,doom9 community and Oliver Amato for these nice script !!! I'm having a lot of fun with it and it works very well.
2005sylvain is offline   Reply With Quote
Old 20th November 2011, 18:49   #66  |  Link
MvB
dings!
MvB's Avatar
Nice to hear. Thanks.
deanaglyph
