3rd December 2006, 20:12 | #381 | Link | |
Does that make sense? |
3rd December 2006, 20:40 | #382 | Link |
Life's clearer in 4K UHD
Hi Travis,
Thanks for providing a snippet of your source.... From what I can see, it does not contain any "progressive" frames. They are all interlaced
3rd December 2006, 20:42 | #383 | Link |
Here's a larger sample that has over 1500 frames...
http://consumeroo.com/files/memoirs....1080i.test2.ts Thanks! |
3rd December 2006, 20:59 | #384 | Link |
Well for my puposes it does not matter if you provide 405 frames or 1500.... All 29.970 frames are interlaced.
EDIT: Here's a segment taken from a frame: - Cheers
3rd December 2006, 22:15 | #385 | Link |
HDConvertToX author
@travisbell
i have update the TIVTC.dll in latest stable... try downgrading TIVTC.dll with rc4 BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
3rd December 2006, 22:29 | #387 | Link |
HDConvertToX author
@crashed
try downgrading the xvid_encraw build, with ones when aviwriter is not needed. if you cut down a snippet is the problem "reproducible" ? if so mail me a link, i will ping squid_80 BHH
3rd December 2006, 22:58 | #388 | Link |
do you have a link to an xvid_encraw build that i should try?
what you mean down by cut down a snippet? reproducable: well atm it crashes every time, did another 4 encodes, using different settings... Last edited by crashed; 3rd December 2006 at 23:54. |
4th December 2006, 00:01 | #389 | Link |
well it seems the xvid_encraw build included in your build crashes whenever started. But the build from http://forum.doom9.org/showthread.php?t=98469 seems to work, will report back...
4th December 2006, 01:03 | #390 | Link |
I am not sure if this helps, but I selected a directory called e:\movies\output as the output directory. Your program created a new directory in that directory called temp. I can not rename, delete or view the contents of that directory...access denied. So I cannot even add the files to the avimux_gui utility manually to test it.
4th December 2006, 01:11 | #391 | Link | |
Thanks man! I might suggest rolling back to RC6 in your stable releases though. Cheers, |
4th December 2006, 08:58 | #392 | Link |
HDConvertToX author
@weaver4
just kill automkv and temp directory will be free (i must check what handle lock it...) @travisbell THANKS for suggestion ! @crashed mmm... for me is working (the 0.52 build of xvid_encraw) and not only for me... i will indagate BHH
4th December 2006, 10:20 | #393 | Link |
Its really weird, your build crashes on that pc im using to encode every time i start it, your xvid_encraw wont crash on any other machines though. I really dont know what the reason is though. The build that i downloaded (http://forum.doom9.org/showthread.php?t=98469) now runs smoothly. The xvidencraw from celticdruids (http://esby.free.fr/CelticDruid/mirror/XviD/ also works. But when runing the first pass line, it wont encode, ill only get the options display:
(gona run another test to see if i made a mistake though... but the crash of your build is certain on that machine) Last edited by crashed; 4th December 2006 at 11:03. |
4th December 2006, 11:09 | #394 | Link |
test just ran without errors using the celticdruids version of xvid_encraw. Doing an encode with different angle subs, 2 soundtracks and xvid slow now, using that build of celticdruid.
4th December 2006, 13:09 | #395 | Link |
HDConvertToX author
@crashed
so using celtic-druid build is fine for both passes ? BHH
4th December 2006, 14:43 | #397 | Link |
HDConvertToX author
sorry pal but that is impossible ! (or at least a bug within windows...) if you kill automkv all handle will be free
anyway... UPDATE www.64k.it/andres/data/a/AutoMKV060.rar THIS IS AN EXPIRIMENTAL BUILD JUST TO ADD WVC1 SUPPORT. un-rar into automkv folder. be sure that you have all prerequisite to encode in wv1 (quick way is to have installed windows meda player 11) BHH
4th December 2006, 16:09 | #399 | Link |
@buzzqw
I'm still running this test, but at the moment celtigdruid's xvidenxcraw works perfectly fine. I am on the second pass right now, 50% through, but will report once movie is done encoding |
